Author Topic: Towing a motorcycle with a motorcycle  (Read 3784 times)
Offline Laminar
  • Retsam
« on: September 28, 2010, 10:06:13 AM »
Just posting the idea here, looking for suggestions and discussion. Say there's a bike I want to buy that's 230 miles away. I have metalworking tools, a welder, and a mechanical engineering degree. What do you think about fabricating a way to tow a bike with another bike?
Offline Raef
Re: Towing a motorcycle with a motorcycle
« Reply #1 on: September 28, 2010, 10:18:02 AM »
I know guys that tow campers with motorcycles.
I'm thinking a 2 wheel dolly, a smaller version of one you would use to tow a car
footprint, two bikes back one on a dolly
and since the forks rotate there would be no need to make the wheels on the dolly turn .
« Last Edit: September 28, 2010, 10:22:14 AM by raef »
Offline myhondas
  • Not really such a
« Reply #2 on: September 28, 2010, 10:46:27 AM »
Take the chain off the towed bike and put the front wheel on a small dolly. Your biggest problem is tipover of the towed bike. You will either have to have a wide spread on the front dolly or hook up outriggers (training wheels on the back of the bike) to prevent tipover.
1974 CB 750 K4 SHOWROOM
1965 C100 CUB 50 (PIT BIKE)
1996 VF 750 CD daily rider
SOHC# 5105 11228
Offline Laminar
  • Retsam
« Reply #3 on: September 28, 2010, 10:47:28 AM »
Just go to Pensky or U-haul and rent a PU truck for the day.  Make sure you get unlimited mileage.
I did that for my last bike and don't want to again. For the cost of a day or two of truck rental, I could get a hitch for my car and just get a trailer for $15. I have a couple friends with pickups but one needs an exhaust and one needs a new hub.
I'm looking for something unique.
The towed bike has a shaft drive.
Offline Gordon
  • 750K1, 550K2
« Reply #4 on: September 28, 2010, 10:55:05 AM »
How 'bout just building a small, one-rail trailer?  Seems with your knowledge and tools it could be done fairly easily.
Offline Steve F
« Reply #5 on: September 28, 2010, 10:59:34 AM »
How about this?  :D
Offline myhondas
  • Not really such a
« Reply #6 on: September 28, 2010, 11:13:44 AM »
Just have to make sure it is in neutral then.
SOHC# 5105 11228
« Reply #7 on: September 28, 2010, 11:32:34 AM »
Make sure it has an oil circulation pump attached to the shaft then.  Or, you will ruin the trans/shaft gears operating it without lube.
Offline Gordon
  • 750K1, 550K2
« Reply #8 on: September 28, 2010, 12:52:39 PM »
Okay.  For the rear, make a two-wheel dolly that clamps to the wheel to get the rear off the ground so you don't have to worry about removing chains or destroying a shaft drive.  Then for the front, instead of a typical ball hitch, make something that bolts to the rear axle and has a bar that you can clamp the bottom of the forks of the towed bike to.  Of course then you'd have to make a mount somewhere to put the front wheel.
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #9 on: September 28, 2010, 01:04:53 PM »
I would only recommend towing for a significant distance with a Goldwing-sized bike or larger.
I'm not sure our 750 trannies are up to that kind of task.
I would recommend the U-haul truck rental route also.
« Reply #10 on: September 28, 2010, 02:10:45 PM »
After you finish building dollies you will probably get in a wreck anyway. Find a good ole boy with a pickup.
Offline Laminar
  • Retsam
« Reply #11 on: September 28, 2010, 02:51:09 PM »
My Sabre has 120hp/75lb-ft tq with a 3.40 Nighthawk rear end - it wouldn't have any issues pulling another bike.
Well, that wasn't my question.
Offline myhondas
  • Not really such a
« Reply #12 on: September 28, 2010, 05:58:34 PM »
what size bike are you planning on pulling?  The only problem that I see you having is the shaft drive still connected to the tranny. I still believe that a wide front dolly or a narrow one with rear outriggers will do the trick.
SOHC# 5105 11228
Offline MidTNJasonF
« Reply #13 on: September 28, 2010, 06:19:34 PM »
flat bed side car rig. Front wheel chock on the back of the platform and a channel for the wheels. Put the towed bike on backwards so its bars are over at the rear of the tug bike.
I have seen that setup at least twice and have part of a platform built and hanging on the shop wall. I am just waiting to get my hands on a good tug to set it up on. I had the crazy idea to take my race bike to the track on it. I will probably try and find a older wing as a tug.
1972 Honda CB450
1973 Honda CB350
1996 Suzuki GSF600N
1996 Suzuki GSF600S
Offline Laminar
  • Retsam
« Reply #14 on: September 28, 2010, 07:34:56 PM »
Ascot VT500FT. Under 400 lbs.
Offline the technological J
  • deliciouso!
« Reply #15 on: September 28, 2010, 08:30:37 PM »
i think it is possible but... i would reserve a moving truck at the location of the bike ride my bike there and throw them both in the back of the uhaul... then drop it off once i get home
94 ST1100..Gone
72 750 K2 Stay tuned!
Offline myhondas
  • Not really such a
« Reply #16 on: September 28, 2010, 08:51:48 PM »
I don't think he is asking for advice on how to get it to wherever. I think he is aware of options like u-haul and trailers and pickup trucks.... what he wants is a way to tow a bike with a bike. Keep the non-productive solutions to his question to yourselves.  ;D
SOHC# 5105 11228
Offline gregimotis
  • poet laureate; SOHC4.
« Reply #17 on: September 28, 2010, 09:05:24 PM »
  • deliciouso!
« Reply #18 on: September 28, 2010, 09:27:38 PM »
ride up with someone on the back of your bike that can drive it home!!?   ;D
 just kidding.... hows this for some inspiration
http://www.retriever-na.com/Retriever_gallery.htm
« Last Edit: September 28, 2010, 09:35:38 PM by thegabrielj »
94 ST1100..Gone
Offline Grnrngr
« Reply #19 on: September 28, 2010, 09:48:05 PM »
Wish I knew where to find it, but back in 72 or 73, in one of the motorcycle mags (Big Bike?) there was a pic of a guy towing a 24ft sailboat with his Honda 750. No doubt the power's there, it's the braking ability you need to be aware of, but a bike on a trailer should be a lot lighter than a sailboat...
http://www.becauseweride.com/links/cycle/trailers.htm
'72 CB750-K2 "PopCycle"
'73 CB750-K2 "Barney"
'77 CB750A
'83 Virago 500 (red)
'83 Virago 500 (black)
Offline KeithTurk
« Reply #20 on: September 29, 2010, 06:05:32 AM »
Guzzi Doug used to pick up bikes from out of state with a side car rig....   motors for it varied from 550's to 750's but always Hondas... cause he wanted to get home....   he brought back all kinds of junk on that contraption....  Fun stuff...
He's also featured on Adventure rider as "wrong way around "....
Offline Laminar
  • Retsam
« Reply #21 on: September 29, 2010, 07:14:45 AM »
My gosh, you actually get it!
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #22 on: September 29, 2010, 08:38:51 AM »
We towed a bike with a bike last night, only a couple miles, though. Just wrapped a rope around the steering neck and tied the other end to the center-stand lift handle.
That said, no way would that work for 230 miles, and we had to have someone (me) ride the towed bike.
Seems to me a set of wheels off both sides, about 2 feet out, a fork brace with a tow attachment (ball joint) a couple inches in front of the axle, a 4 foot long solid bar and a way to activate the brakes on the towed bike is all you'd need. (and, of course, a tow attachment at the center of the back of the towing bike with a ball joint.)
No.
Offline Gordon
  • 750K1, 550K2
« Reply #23 on: September 29, 2010, 12:03:27 PM »
Sturdy tow-rope.  Wings securely mounted to the towed bike.
Just don't slow down or stop until you get home.
Offline joerizzo0
« Reply #24 on: September 29, 2010, 12:12:44 PM »
I like the side platform idea!! i want one!
1976 cb400f
