Author Topic: Gas leak puzzler??  (Read 2797 times)
Offline MikeJW
Gas leak puzzler??
« on: September 28, 2010, 01:51:32 pm »
Last time I rode my 1972 750K was Saturday morning. Since then, it's been on center stand on a large concrete pad. A couple months ago, I completely rebuilt my petcock. After I put it back on the tank I removed my carbs and set the float levels as carefully as I could. About noon today, I noticed a wet spot on the concrete on the right side; not under the bike but beside it. Tracing the origin of the leak, I found it came from the front opening in the bottom of the airbox. I took the bottom half off and found about a half oz of gas in the bottom of the airbox. What the heck?? I did a SEARCH and only found one other mention of such a thing and it didn't seem to be similar circumstances to mine. Can anyone explain this to me, please?
MikeinMemphis
1972 CB750K2
Offline Bob Wessner
  • "Carbs Suck!"
Re: Gas leak puzzler??
« Reply #1 on: September 28, 2010, 02:04:31 pm »
Perhaps a speck of something stuck between the float valve and its seat in one of the carbs? What is the condition of the fuel tank interior, is the petcock filter still in place?
Offline MikeJW
« Reply #2 on: September 28, 2010, 02:09:39 pm »
To answer in reverse order; yes, I bought every part for the petcock that was available, including a new petcock filter screen. If there was something interfering with one or more fuel shutoff valves, why isn't it leaking out the overflow tubes? I think the inside of the tank is clean. This bike has never set up, unridden for long periods in its life.
Mike
1972 CB750K2
bollingball
« Reply #3 on: September 28, 2010, 02:12:05 pm »
Bob how does it get in the airbox I thought it would go out the overflow tubes I have heard other people complain of this but I do not understand it.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #4 on: September 28, 2010, 02:19:54 pm »
I don't quite understand that part myself, though I too have seen references to it, particularly with the bike on its center stand which would elevate the rear somewhat. I was really just addressing a possible source for the seepage from the carb.
Offline MikeJW
« Reply #5 on: September 28, 2010, 02:26:52 pm »
I always park it (at home) on the center stand and I always turn the petcock off when it's not running. Trying to understand the leak but also concerned about how gas is even getting to the carbs with a recently rebuilt petcock turned OFF
Mike
1972 CB750K2
Offline Johnie
« Reply #6 on: September 28, 2010, 02:52:48 pm »
So when you rebuilt it did you also replace those gaskets on the 2 screws that hold the petcock to the tank? If so, what did you replace those with? Fiber, rubber or what?
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline MikeJW
« Reply #7 on: September 28, 2010, 03:03:09 pm »
No, I didn't, for two reasons:
1. I couldn't find replacements
2. mine seemed (looked) in pretty good shape
Mike
1972 CB750K2
« Reply #8 on: September 28, 2010, 03:52:21 pm »
Have you checked to see if the overflow tubes are blocked?
Offline MikeJW
« Reply #9 on: September 28, 2010, 04:29:53 pm »
Yes, checked, they are not blocked. Actually, my first thought.
1972 CB750K2
Offline Johnie
« Reply #10 on: September 28, 2010, 04:37:58 pm »
Oshkosh, WI  USA
Offline MikeJW
« Reply #11 on: September 28, 2010, 05:01:54 pm »
Thanks, Johnie. That was a good thread and may be what I am experiencing. Where did you get those tight-fitting fiber washers? Sounds like I need to get some. Thanks
Mike
1972 CB750K2
Offline Johnie
« Reply #12 on: September 28, 2010, 05:14:07 pm »
Mike
I got them at the local hardware store. Bring a screw in with you. Like I said, mine were a tight fit that I had to screw the gaskets on past the threads. But I used them on 3 bikes and none leak.
Oshkosh, WI  USA
Offline MikeJW
« Reply #13 on: September 29, 2010, 08:12:13 am »
Well, I went to remove my petcock this morning and when I pulled down on one of the fuel hoses (the forward one), the whole little brass outlet tube came out of the petcock and stayed inside the hose. This may not be my main problem but obviously a factor. Now, my question is- should I try to cement it back in the petcock some way or start thinking about a whole new petcock? From some of the posts, I assume it can be difficult finding exactly the right petcock for a particular tank. Any suggestions? Thanks
MikeinMemphis
1972 CB750K2
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #14 on: September 29, 2010, 09:05:54 am »
I believe the brass outlet nipple is a press fit (someone will chime in if I'm wrong). If it is, you should be able to gently tap it back in to the petcock base. Just make sure you don't mangle it.
Offline j squared
  • www.iliketogofast.com
    • ILikeToGoFast
« Reply #15 on: September 29, 2010, 09:15:01 am »
I did that exact same thing on one of my hoses this past weekend!  Pissed me off, thought i had to buy a new petcock haha.  In a fit if rage i hammered it back in and hooked the line up and it seems all is well, so Im glad they are just press fit and I was actually OK :)
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #16 on: September 29, 2010, 09:21:41 am »
You lucked out. Usually, rage = mangle, guess how I know.  ;)
Offline MikeJW
« Reply #17 on: September 29, 2010, 09:39:04 am »
Great, thanks, guys. I hope you're right. I've been sweating trying to figure how to hold it in the petcock. My fuel hoses have always been a tight fit...hard to get on, even harder to get off.
Mike
1972 CB750K2
bollingball
« Reply #18 on: September 29, 2010, 09:47:52 am »
You can chuck it up in a soft jaw vise and start in with fingers then get a Popsicle stick on the end tap the wood gently
Offline MikeJW
« Reply #19 on: September 29, 2010, 10:04:59 am »
I tried putting it into the petcock and it went in far too easily. No tapping required...thumb pressure only. Makes me think it needs some type adhesive on it when putting it back. Just don't know what the best choice would be ???
1972 CB750K2
bollingball
« Reply #20 on: September 29, 2010, 10:27:55 am »
You said it went "far to easy" but did it go all the way or do you think some of it broke off. If you think all is lost then you have nothing to loose clean everything good put it back in as far as it will go and  JB weld it using nothing larger than a pencil  or a piece of #12 copper wire it won't take much once you do this you are committed
Offline j squared
    • ILikeToGoFast
« Reply #21 on: September 29, 2010, 10:29:19 am »
If mine comes out again the next time I pull the line off I plan to use some red loctite in there, and failing that, some good ol JB Weld.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #22 on: September 29, 2010, 10:31:46 am »
Follow Bollingball's advice. If you just pushed it in with your finger, it's probably not seated tightly.
Offline MikeJW
« Reply #23 on: September 29, 2010, 11:11:52 am »
No, none of it broke off. It went all the way in, just too easily. I think it would still leak if used as is. A word of warning to anyone reading this. JBWeld is NOT resistant to gasoline. After awhile, it will break down and just become a mess. That's even if you let it harden for a couple days before exposing it to gas. I have thoroughly proven this to myself in the past and don't plan to try it again. There must be some sort of automotive gasket compound that will harden up and resist gas. I just have to find it.
1972 CB750K2
« Reply #24 on: September 29, 2010, 11:33:56 am »
There is a variant of Locktite that will withstand gas, I think.
Loctite red 271 for example.
http://www.loctiteproducts.com/products.shtml
