Author Topic: signal Problems  (Read 1433 times)
klroywshere
signal Problems
« on: April 28, 2005, 12:03:40 AM »
 :(  Am Rebuilding an Honda 1981 650 c custom the signals don't work tho when I turn them on the oppisite of the direction i SWITCH go's out and the other stays lit.  no flashing no sound.  Could it be the signal relay switch. and if so does anyone know where I can get one to put on? got clymer workshop book ordered but was just wondering where on the bike the relay is located I know the book will tell but just kinda ancious to find out.  Oh Yea the rear signals don't seem to work but the tail light and break light does.
« Last Edit: April 28, 2005, 12:09:39 AM by klroywshere »
Offline Glenn Stauffer
  • Administrator
    • The SOHC/4 Owners Group
Re: signal Problems
« Reply #1 on: June 21, 2005, 01:05:57 PM »
Have you checked your flasher?  Is the battery fully charged?  Trace the wires; clean all of the wire connections and the switch.  If it still doesn't work, replace the flasher.  Go to an auto parts store and look for a solid state flasher that will fit OK - check the greenspun archives since someone may have posted the part number for something that will work.
