Author Topic: Calling On The Big Dogs HELP  (Read 1038 times)
Offline MattFreeman
  • What Have I Done?
« on: October 01, 2010, 02:05:25 PM »
In the upper right hand corner you'll find the cause for tomorrows hangover.
Can this be fixed? The flat spot is about 25mm wide and 10mm deep.
The pistons are individually fit for 811 pistons and the rings are gapped.
I could really use some good news. I assume (I'm an ass) that the piston never gets this far south but I can't imagine it's good nonetheless.
« Last Edit: October 01, 2010, 03:30:25 PM by MattFreeman »
Re: Calling On The Big Dogs HELP
« Reply #1 on: October 01, 2010, 02:59:24 PM »
Offline MattFreeman
  • What Have I Done?
« Reply #2 on: October 01, 2010, 03:11:56 PM »
Offline Hondawggie
  • Flimmy-Flammy, Hambone-Sammy -- I'm a Bigole
« Reply #3 on: October 01, 2010, 03:15:12 PM »
I have some experience rebuilding a 4-cylinder, 4-stroke top end (a 1977 kz1000).
Look at the taper in that other cylinder to the left of the bent one.  That taper is machined in there to accommodate re-installing the pistons into the cyclinder -- without that taper at the bottom of each cylinder's bore, it is difficult to get the pistons inserted into the cylinder so you can lower the cylinder onto the block.  (I know this because the machine shop that did the bore job on my kz1000 forgot to machine a taper at the bottom of the 4 barrels.  Still got the pistons in there, what a female dog that was.)
So it is hard to tell from your picture -- is the bent part 100% limited to the tapered part of the bore?
One thing you can try:  take the cylinder to a machine shop and have them check it.  Maybe, if the bend is in fact impinging into the piston's region of travel, the machine shop can do a 'bore' job by choosing a bore that is the same size as the cylinder so when they bore that cylinder, they will cut away any metal that is in the bent 'flat' part that impedes piston travel and the bore won't affect the good part of the cylinder.
If a machine shop tells you that is not possible, I'd say to see if removing that cylinder's liner and installing a new one is less expensive than buying a new cylinder (may not be, I'm not sure -- I've seen some pretty cheap cylinders on ebay in the past year).
« Last Edit: October 01, 2010, 03:17:05 PM by Hondawggie »
« Reply #4 on: October 01, 2010, 04:27:12 PM »
the pistons do go down into the casing a lot,you still have to feed the piston into it,a competent machine shop may be able to fix it,it might need resleeving though.bugger.
Offline mick7504
« Reply #5 on: October 02, 2010, 02:06:29 AM »
Here's a cylinder that looks to be in good nic.
It's out of an auto but that makes no difference.
The price is right and might make a good starting point.
http://cgi.ebay.com/ebaymotors/Honda-CB-CB750-Automatic-Original-Cylinder-CB750A-76-78-_W0QQcmdZViewItemQQhashZitem5d2a6d3090QQitemZ400143757456QQptZMotorcyclesQ5fPartsQ5fAccessories
If I was you
I'd be worried about me.
Offline KB02
« Reply #6 on: October 02, 2010, 05:00:32 AM »
Worse case scenario: Resleeve that one and rebore for your 811.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline Kevin400F
« Reply #7 on: October 02, 2010, 05:14:20 AM »
As said above: resleeve and rebore is the only good option.
So tell us, did you drop the block?
