Author Topic: top end disaster, a winter rebuild is in order  (Read 2738 times)
Offline JBMorse
    • Travel Blog
« on: October 01, 2010, 02:06:20 PM »
After returning from my summer long cross country trip, my CB500 engine was in bad shape.  We'd lost 1st gear completely and I had a leaking head gasket.  I have a stuck engine and had planned to combine my good parts and make a good engine again, with a 1st gear!  Well, a cb500 engine popped up on craigslist for $50 nearby, and I thought it was worth going after.  When I got it I saw it was in (apparently) nice shape, though I didn't know the history or compression numbers.  Everything looked nice and when I took the valve cover off the cam lobes and bearings looked nice too.
So, after practicing engine removal by taking the stuck one out of my parts bike, I swapped my new engine into my bike and it ran great!  Sounded great, was oil tight, smooth, everything!  Great score right?!  I went for a few short rides and took it to work.
Well last Wednesday night on my way home with the g/f riding on back, we had just left somewhere and I revved it up to 4k or so and I heard a most horrible clanky sound.  At first I thought a branch had caught in the spokes so didn't think much of it, but the sound didn't go away immediately, instead it continued for about a minute. Things smoothed out and the bad grinding stopped, but the motor wasn't running right and I realized I only had 3 cylinders working.  I finished the 8 mile ride home and began the investigation.
I got home and figured out it was cylinder #2 that wasn't running.  I pulled the plug and oh my, the thing was mashed!  I had never seen anything like it.  When I explained the incident to my dad he was sure something had been sucked into the intake and ended up in the combustion chamber.  Something smashed that spark plug to bits.
Well I pulled the valve cover and found all the valves held in place where they should be (my dad told me to look for a broken valve retainer).  I attempted a compression check but couldn't because pulling that smashed plug out did a number on the spark plug threads.  I could see through the spark plug hole, though, that something wasn't right inside that cylinder.
So, having never been below the valve cover on any engine, I proceeded to tear down the top end.  Here is what I found:
Soooo..... a broken piston and severely damaged valves and seats in that cylinder.  The exhaust valve had been broken to bits, when I pulled the head I dropped it because the end had broken off!  And the last pic shows the remnants of something metal in the intake manifold.
My dad shook the muffler expecting to find pieces of a bolt or something, but all that came out was a piece of that broken exhaust valve.  Still, I think his theory of an uninvited metallic object coming into the combustion chamber makes sense; when I pulled the air filter out there was a bolt and nut in there that was left over from when I had installed the engine!
So it's a mystery to me what happened exactly, but what is clear is that the top end needs to be rebuilt.  So here are some newbie engine rebuilding questions:
1. First off I cannot get the cylinder off for the life of me.  I've whacked it with a rubber hammer, put a screw driver in the provided pry-points, and even tried a method I found here of stuffing some rags in the cylinders, re-attaching the head and trying to kick start it.  When I did this, not only did nothing move but I feel I nearly broke the kick start mechanism.
2. Since the combustion chamber of that head is toast, I'll have to toss it.  Sad because the cam bearings looked real nice.  I have two other cylinder heads to choose from, and am wondering if the cam bearings turn out to be no good in them, can they be replaced or reground?  The manual refers to this, but I don't know if they mean replace the bearings or the head itself.  Here's what it says:
"Inspect the camshaft bearing surfaces.  Camshaft bearing surfaces should be smooth and shiny.  If it is scratched or excessively worn, it should be replaced."
3. I want to do a re-bore while the cylinders are off.  There are some kits on ebay for reasonable prices, but I don't know how much over I'll need to go.  How do I figure this out?  Currently there are .25, .75, and 1.00 over kits for around $150.
4.  Are the honda ring compressors specific to the model?  I happened to find two honda ring compressors like they show in the manual, but with a different part number.  I don't know how much bigger or smaller one could be and still be useful for this bike.
Those are all my questions for now.  I'm sure I'll have more.  Perhaps I'll post a project thread and concentrate questions there.  If you can't already tell, I've never rebuild an engine of any kind, but I've done tons of searching here on the forums and have a pretty good idea of what I'm doing.  We'll see!
Jeremy B
1971 CB500K
Offline Bob Wessner
  • "Carbs Suck!"
Re: top end disaster, a winter rebuild is in order
« Reply #1 on: October 01, 2010, 02:46:44 PM »
Wow, sorry to hear about this. Having never opened one up either, I might follow your thread in case I ever need it [fingers crossed].
Offline Kframe
  • Life is good!
« Reply #2 on: October 01, 2010, 03:04:37 PM »
That's some amazing damage!   :o
I wonder if another theory on the cause could be a too lean burn blowing a hole through your piston?
Although, the remaining top of the piston doesn't look melted, so....   Not really sure.
What was that about finding a bolt in the aircleaner?  Did you find that earlier and leave it in there, or are you saying you found it during this current teardown?   ???
-K
2007 Triumph Bonneville T100, ARK'd, Pods, TOR's, Napoleon's, Innovate G5 Air/Fuel Gauge, Ignition Relocation by D9, Stebel Nautilus, Avon Roadriders
1984 Honda Shadow VT700c, Stock
1974 Honda CB550K, In rehab
1986 Honda Helix
Offline fantino
« Reply #3 on: October 01, 2010, 03:13:03 PM »
Reminds me of this thread, though not quite as amazingly catastrophic:
http://forums.sohc4.net/index.php?topic=74448.0
Sorry to hear about your accident dude :-(
Offline MasterChief750
  • Detonation
« Reply #4 on: October 01, 2010, 04:14:45 PM »
ouch that sucks good luck i hope she runs again.
1976 CB750 K - Drag Bike
I AM THE STIG
Sam is THE STIG
he said i can be STIG3 tho
« Reply #5 on: October 01, 2010, 04:23:12 PM »
if you rebore it and use XL125 pistons they have a dome,ive done this and had the combustion chambers machined to accept them,this cost me 70 bucks,if you go that way the head might be salvagable?
Offline Kframe
  • Life is good!
« Reply #6 on: October 01, 2010, 07:39:42 PM »
Would that also work on a 550?
Just curious.
K
1986 Honda Helix
« Reply #7 on: October 01, 2010, 07:57:03 PM »
no the 550 has a bigger bore,the xl slugs have the same pin location and bore as the 500,the cb ones are flat topped,heres an xl125 piston next to a stock genuine honda one.
« Reply #8 on: October 01, 2010, 08:37:57 PM »
JB, your motor "sucked a valve"! The valve head broke off of the valve stem, and rattled around in the combustion chamber until it punched a hole in the piston. What's left of the valve head may have found it's way into the crankcase...
« Reply #9 on: October 01, 2010, 08:48:08 PM »
ide be inclined to strip the entire bottom end,if not at least drop the pan off.
Offline JBMorse
    • Travel Blog
« Reply #10 on: October 02, 2010, 01:02:48 PM »
Hmm interesting idea on the xl125 pistons.  I can get a piston kit for a reasonable price, though, and I've got two other heads that might be good.
It sure seems like the valve just broke, but I didn't realize that could happen just like that, with no indication or warning.
My biggest problem now is that I can't get the cylinder off.  I've heated it up and everything, and if I bang anymore or any harder I'm just going to destroy the fins.  I have no idea what to do ???
I'll keep y'all posted on it.
1971 CB500K
Offline Brian G
« Reply #11 on: October 02, 2010, 02:27:05 PM »
My thinking is that Scottly's right - I'd say that part of the exhaust valve broke off and hammered a hole in the piston. If the engine had stood for a long time, there may have been corrosion on the valve stem which caused it to stick open long enough that it got whacked by the piston.
Whatever, the damage is done. And to make things worse, you're a victim of gasket goo on the base gasket. I don't know why people feel the need to use hardening adhesives on engine gaskets - I did my wife's CB550 with barely a smear of Never-Seez on the base and head gaskets and they work just fine - and I know they will come off if I need to remove them again in future. I'll get down off of my soapbox now... ::) ::)
Ring compressors are, as far as I'm concerned, optional. Again, I did the 550 without a compressor at all - but I may have been just lucky. It certainly takes two of you - a friend to lower the barrels as you ease the rings in place - there's a chamfer on the bottom of the liners that helps.
I wish I knew of a trick to get the barrels off. All I can suggest is to try getting the sharp edge of a fox wedge (or wide bladed screwdriver) started and then tap gently. Perhaps others know of a trick.
Anyways, sorry to read of your problems. Good Luck with the adventure ;)
Regards,
1975 Honda CB400F
1978 Honda CB550K
1979 Honda CBX
1969 BSA Rocket 3
1976 Kawasaki KH400
2008 Kawasaki C14 Concours
Offline Soos
« Reply #12 on: October 03, 2010, 05:51:36 AM »
Sorry to hear your loss there!!
I think I might have a cb500/cb550 mixed motor you could get some parts from if interested.
Got the motor in a trade, was told PO had never gotten it to run.(nor the guy I traded with)
tore into it(wanting a 550 motor to use as a piston test station).
Bore was the same as a 500. The cylinders have "500cc" stamped on them.
Head does not match 550 head pictures I can find, but does look like a cb500 head.
BUT serial # on the cases indicates the lower is a 550.
I can't use this setup unfortunately(will be keeping the lower half for a possible 650/550 mod though)
I'll part with everything above the lower cases for $5.00 + shipping if interested.
cylinders, pistons, head, cam, nuts, bolts, covers etc.
PM me if interested
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline funkdr5
« Reply #13 on: October 03, 2010, 07:20:53 AM »
kframe - too lean will burn a hole in the piston?!!  how long would that take?
