Author Topic: Flasher unit constant buzzing means?  (Read 4813 times)
Offline beaniam
« on: October 01, 2010, 04:43:02 PM »
Finished getting the motor back and hooked up in my 78 cb750 and when I turned the ignition on to test the starter the flasher unit started continuously buzzing.  I don't have to use the indicator it just keeps buzzing.  Does that mean the flasher is bad, low voltage, or I screwed wiring somewhere getting the engine back in?
Offline MasterChief750
  • Detonation
Re: Flasher unit constant buzzing means?
« Reply #1 on: October 01, 2010, 04:57:33 PM »
im having the same exact issue, i need some answers on this as well.
1976 CB750 K - Drag Bike
I AM THE STIG
Sam is THE STIG
he said i can be STIG3 tho
Offline beaniam
« Reply #2 on: October 01, 2010, 05:18:55 PM »
I'm going to pull apart the switch unit tomorrow.  I just put on drag bars and had to rewire it but it worked fine after.  2 days later and it starts buzzing.  Maybe something is shorting out in the switch.
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #3 on: October 01, 2010, 06:06:11 PM »
I just disconnected the buzzer, it was annoying.
  • Detonation
« Reply #4 on: October 01, 2010, 06:14:08 PM »
yeah mine worked perfectly fine last year before tear down. trying to find the problem. im hoping its low voltage or something like that.
I AM THE STIG
Sam is THE STIG
  • Detonation
« Reply #5 on: October 01, 2010, 06:14:49 PM »
the turn signal relay is what triggers the buzzer. the bizzer isnt the issue it would be the relay that controls it.
I AM THE STIG
Sam is THE STIG
Offline beaniam
« Reply #6 on: October 01, 2010, 06:52:12 PM »
Was bugging me so I just went out and worked on it.  2 wires in the turn signal switch were crushed and shorting out against the handlebar.  Must have fried the flasher though, it just flashes once.  Swapped in the electronic one from my nx650 and it works fine.
  • Detonation
« Reply #7 on: October 01, 2010, 07:46:31 PM »
ill have to get another relay and see if that fixes mine
I AM THE STIG
Sam is THE STIG
Offline Bodi
« Reply #8 on: October 02, 2010, 04:39:42 AM »
Flasher or buzzer?
The flasher makes the lights flash. If the stock one is buzzing then you probably have a crushed/shorted wire somewhere. It buzzes when it is carrying a high load current, and it won't last long like that. If it buzzes all the time then check wiring to the signal switch or the switch itself. If it buzzes only on one side then check first for a lamp that has been damaged or burned out in a way that shorts it out.
The buzzer is connected from one side signal lamp wire to the other. It buzzes when one lamp is on. If it buzzes all the time and no lamp is on then it's connected wrong.
Offline cb750k7
  • My CB AKA Charlie Brown...(K8 frame with K6 engine
« Reply #9 on: October 02, 2010, 05:59:33 AM »
Had the smae issue,  change the relay and it will stop...
Found real friends here !!!
