Author Topic: seafoam?  (Read 1201 times)
Offline orkid1989
  • “Life is too important to be taken seriously.”
seafoam?
« on: October 03, 2010, 11:47:07 AM »
i was wondering how exactly to use seafoam on my 71 cb750. ive used it on cars and boats before but never on a bike so i want to make sure i do it right. i know in a car i usually just put about 50% in the gas, 25% in the oil, and 25% through the vacuum line. so what would be the proper use in a bike?
“Experience is the name every one gives to their mistakes.” Oscar Wilde
Offline GammaFlat
Re: seafoam?
« Reply #1 on: October 03, 2010, 12:03:13 PM »
I don't think I'd put it in the oil of these bikes.  Put some in the gas per the recommended dosage.  I think it's something like 1.5 oz per gallon...  To suck in your vacuum port doesn't accomplish much for your carb.  It may clean up your combustion chamber some though.  It's used in the boating industry to "de-carbon" your combustion chamber to avoid ring damage.
K6
85 Goldwing
Offline orkid1989
Re: seafoam?
« Reply #2 on: October 03, 2010, 12:13:07 PM »
o ok so just stick to putting it in the gas then. i guess it would be a pain in the ass pouring it through all 4 carbs evenly at the same time
Bad Man
Re: seafoam?
« Reply #3 on: October 03, 2010, 04:51:05 PM »
I think plenty of folks use Seafoam in the oil, though I have heard Marvel is also great. I use Seafoam just before an oil change.
Try searching "Seafoam" within the forums and you'll find many threads like this one: http://forums.sohc4.net/index.php?topic=23774.25 - they talk about putting Seafoam in oil on the second page.
I think the major difference is that Seafoam acts as an additive when put in a full tank of gas, but acts as a cleaner when put into your crankcase just prior to changing the oil (and filter!).
« Last Edit: October 03, 2010, 04:53:24 PM by Bad Man »
Offline Duke McDukiedook
  • Space Force 6 Star General
Re: seafoam?
« Reply #4 on: October 03, 2010, 05:00:31 PM »
Some people put it in run it for a VERY short while and then do an oil change, you don't want to keep it in your oil for very long, it is basically naptha with a couple of other additives.
Markcb750
Re: seafoam?
« Reply #5 on: October 03, 2010, 05:04:22 PM »
I am with the just before an oil change crowd, about 100 miles.
I "hope" it is helping to keep the piston rings clear of carbon.
