Author Topic: Tri-bar headlight cover  (Read 3339 times)
Offline GRock
« on: October 04, 2010, 07:45:03 PM »
Hey all,
I picked up a tri-bar headlight cover (the kind they had in the '40's) and can't get it to work on my headlight because of those three lass tabs on the front of the lens. It holds the cover up off the surface and you can't get the light assembly back together. I tried to dremel the tabs off but cracked the sealed beam. Bought a new headlight (from Jerryscycles.com) that has the smaller H4 bulb inside but the convex shape of the headlight is to shallow and the cover still doesn't fit right. I didn't think this was going to be a problem at all but it is turning into a real pain in the a**! What have people used in the past? I like the look of the cover better than the integrated units plus the covers costs a fraction of the integrated units. All the sealed beams I have seen have those damned glass tabs on them. What are those things for anyway?!? I've checked the post but none of the tri-bar posts have covered this.
Thanks guys!
Greg
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
Re: Tri-bar headlight cover
« Reply #1 on: October 04, 2010, 11:40:31 PM »
we like photos ;)
Offline eideteker
« Reply #2 on: October 05, 2010, 05:44:57 PM »
Instead of using a cover, why not use the real thing? - http://www.thehoffmangroup.com/autoloc/details.lasso?itemid=MUSTHL2
"Spit on the tip of your finger, lube the inside of the hole, and then wiggle it around and twist a bit back and forth as you apply pressure." - mystic_1
1973 CB500K - not bad for a first bike
2009 SFV650 - torquey, reliable 90° V-twin
Offline GRock
« Reply #3 on: October 06, 2010, 03:55:16 AM »
Because I think what they charge for the "real thing" is ridiculous and I like the how the cover looks better. The tri-bar is just a cosmetic thing, right? I took some pic last night, I'll see if I can't get them online tonight.
Offline ksmith0034
  • When I grow up I want to be a
    • Please subscribe to my motovlog
« Reply #4 on: October 06, 2010, 05:29:44 AM »
Will this plug right into my CB750 wiring without modification?
It took 10 years but she's finally done!
Stocker 2 Rocker CAFE conversion
My YouTube channel HERE:
https://www.youtube.com/MotoCafeRacer
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #5 on: October 06, 2010, 07:44:11 AM »
It uses an H4 bulb, will probably take a little modifying at the wire ends to put an H4 cap on it.
Looks there is no info on wattage on the bulb included, I assume it probably is a 50/60W bulb.
« Last Edit: October 06, 2010, 07:46:52 AM by Dukiedook »
Offline ksmith0034
« Reply #6 on: October 06, 2010, 10:00:37 AM »
Does anyone own one of these bulbs?  I would love to see the back of it.
Offline ksmith0034
« Reply #7 on: October 07, 2010, 08:44:09 AM »
Does anyone have experience hooking one of these up?
Offline eideteker
« Reply #8 on: October 07, 2010, 06:50:13 PM »
Keep trying to reinvent the wheel, let me know how it goes for you.
Offline ksmith0034
« Reply #9 on: December 07, 2010, 11:07:46 AM »
Anyone own one of the lights from Hoffman?
Offline Anti-Johnny
  • 75 cb750k
  • Poser
« Reply #10 on: December 07, 2010, 11:35:59 AM »
That hoffman one looks like a fair deal. I just paid $30 for a super bright halogen that I am not too happy with. drats.
music
Offline ksmith0034
Offline Anti-Johnny
  • 75 cb750k
  • Poser
« Reply #12 on: December 07, 2010, 12:03:08 PM »
There are a lot of guides and threads on here about switching to an H4 setup. please update when you get it and put it in. When its time to replace my light, id be interested in going this route.
music
Offline AnthonyMichael
« Reply #13 on: December 07, 2010, 12:28:24 PM »
I have one of these and was putting it on my 750K8. It was a pain in the ass to get it in the casing because directly on the back side of the bulb are these little squarish nubs that fit into recessed nubs on the housing. I didn't notice these at first and wondered why I couldn't get it to fit snugly. Once I figured it out I realized that since there's really only one way to position it with the nubs that the actual tri bar isn't aligned properly. It's at an angle. It's like if you took the mercedes logo and rotated it 45 degrees clockwise that's how it looks. Kind of annoying to be honest.
Also those bulbs have a plastic cupping around the back that doesn't fit right into the housing so we had to dremel it off last night to make it fit.
Pain in the ass if you ask me.
Offline ksmith0034
« Reply #14 on: December 07, 2010, 12:31:44 PM »
Thanks for this insight.  Do you have any pics?
« Reply #15 on: December 07, 2010, 12:40:07 PM »
Ok, this is me holding it up vertical as if it would be on the bike. See how with the nubs it's now rotated to the right?
Had to cut this to fit into the casing, other bulbs dont even have that wall
These are the nubs I mentioned
Offline ksmith0034
« Reply #16 on: December 07, 2010, 12:53:18 PM »
Thanks for the pics.  Can you cut some new recesses in the housing to accept the nubs so the light sits properly?
Offline Cqyqte
« Reply #17 on: December 07, 2010, 12:55:09 PM »
Those glass nubs are locator tabs that are used to postion the light in the correct orientation so the light is directed in the right manner to meet DOT specifications.  If they are not used then the light could be directed to the left into on coming traffics eyes blinding them.
« Reply #18 on: December 07, 2010, 12:57:55 PM »
Understood but I think the tabs are different for each model of bucket/bracket.
It even says on the light "TOP" and top is clearly 45 degrees to the right.
And yes I imagine you can dremel out some nobs for sure. I didn't even think of it.
Offline Gaither
  • '77 CB550F
« Reply #19 on: December 07, 2010, 03:30:53 PM »
Somebody used to sell just the "Tri-bars" as an add-on accessory for cars - without the light. Sorry, I can't recall who. It was one of those things that almost tempted me (in the '50's) but I never quite got around to.
I'll bet they are still out there somewhere. They were fairly common on some imports - mostly on sports cars.
You might try a Goggle and find 'em.
Gaither ('77 CB550F)
Offline Anti-Johnny
  • 75 cb750k
  • Poser
music
nomad
« Reply #21 on: December 07, 2010, 04:48:45 PM »
Are these a true plug-n-play for the CB750's?  Or would they require a little "notching" as well?
http://cb750cafe.com/parts.php?id=46&PHPSESSID=08dc3d74eaab763d33f96382a88d55fe
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #22 on: December 07, 2010, 04:51:06 PM »
Why ask here?  Just email Carpy ...........
Offline Anti-Johnny
  • 75 cb750k
  • Poser
« Reply #23 on: December 07, 2010, 04:54:40 PM »
I would do a little digging. All the accessories that he doesnt make himself can be found much cheaper other places.
music
nomad
« Reply #24 on: December 07, 2010, 04:56:21 PM »
Because I thought there may be a chance someone here may have installed one of these and could give a quick answer... rather than bugging Carpy.  If no one here has an answer, then yes, I'll email Carpy.
