I might be wrong about this, so double check the info...but I believe that you can not use the top triple tree from 76 or earlier with a bottom of a 77/78. Whether it's a K or F doesn't matter. So make sure you both have later triple trees before you swap. I'm pretty sure this is right since cycle x's website saw the top alone can only be used on 69-76's. Obviously if you by the complete triple tree, it works on any year bike.
So BryceGP, what exact top are you looking for? A 78K or F? I ask because from your gauge picture that looks like a 78 K, but you keep saying you are looking for an F. Can you snap a pic of the lower triple tree?
Sharpinkski, you're looking for the top to a 76K then right?
I have some triple trees in my shop, if your swap won't work, I might have a tree for both of you. I definitely have 77/78 K and F triple trees, not so sure about the earlier model, but I might.
