Author Topic: Timing chain joiner links?  (Read 2326 times)
354
« on: October 06, 2010, 08:04:02 PM »
I need to replace the timing chain in my '74 cb350f, and i thought rather than pull the engine out and split the cases i would  put a joiner/master link in a new chain. does any body make one? would it stay together with a joiner rather than all one?
Thanks!
Offline Triffecpa
Re: Timing chain joiner links?
« Reply #1 on: October 06, 2010, 08:20:39 PM »
there are a couple of different master link designs for cam chains.  There is a press fit one and one where you rivet over the pins to hold the side plate in place.  I have used both on my race bikes that regularly see redline and then some and have never had a problem.
I would go ahead and replace the chain while you are at it though and make sure that you buy, or get with the chain, the proper masterlink.
CB350F cam chains aren't real easy to find, but you can find ones for the CB750 for less than $30.  The chains are identical to the 350F ones except that they are about 10 links longer.
Cut the existing chain with bolt cutters, safety wire the new chain to the end of the old one and pull the new chain thru as you pull the old one out.  Then you can lay the two ends of the new chain across the sprocket and figure out exactly how many links to remove.  Grind the pins off and pull the side plate off and you now have a shorter chain.
Tracy
Offline scunny
  • don't call me expert
« Reply #2 on: October 06, 2010, 08:31:47 PM »
I've just done this on my 650, it has the hyvo chain but the principal is the same. mine was a press fit, I asked a mechanical engineer who specialises in chain and transmission drives about the reliability of the press fit joiner and he said you actually compromise the liks integrity if you try and peen the end over. this doesn't apply to the "soft links"
cut away as Triffecpa said and draw the new chain thru.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
354
« Reply #3 on: October 06, 2010, 08:41:57 PM »
Thanks! Do you know where i can get a chain and joiner or what size of joiner to order? Bike bandit has Tsubaki chains for 350f for 30 couple dollars, but no joiner.
Thanks
Offline scunny
« Reply #4 on: October 06, 2010, 08:53:57 PM »
David Silver Spares has them, do a google, great people to deal with.
            VTR1000F3
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
Offline tmac
« Reply #5 on: October 06, 2010, 09:12:07 PM »
Try Z1 Enterprises.
354
« Reply #6 on: October 06, 2010, 09:26:35 PM »
Hey, i checked out David Silver Spares...lotsa good stuff, should i get their DID chain or genuine Honda (and a soft link)? What can a fella use to rivet the joiner without spending a fortune?
Thanks!
Offline fmctm1sw
« Reply #7 on: October 07, 2010, 04:27:02 AM »
This is exactly why I come here just about every single day.  Great tip...
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Deltarider
« Reply #8 on: October 07, 2010, 07:44:18 AM »
Genuine Honda is D.I.D (219T-82L)
CB500K2-ED Excel black
