Author Topic: powdercoating carbs  (Read 6150 times)
Offline millerza
  • Zach Miller
  • 750K8 fixing rebuild probs
powdercoating carbs
« on: October 08, 2010, 12:36:01 PM »
Does anyone forsee problems powdercoating 78k carbs. Stripped down of coarse. O-rings removed. Will check valves be OK??  Im kinda worried about temps/between the brass and alum. Looking at 400degF, maybe 450degF for degassing. Anyone have any thoughts. Going with an aluminum color.
« Last Edit: May 25, 2011, 01:21:52 AM by millerza »
bollingball
Re: Any problems powdercoating carbs
« Reply #1 on: October 08, 2010, 12:42:32 PM »
On the PD42b you have a plastic part on the acc. pump check valve. I would be concerned with all the little holes :o
Offline gmonkey
« Reply #2 on: October 08, 2010, 12:44:16 PM »
You're powder coating aluminum carbs in aluminum color?
Big pile of 76 CB550F parts
'98 FZR600 purring like a chain-smoking kitten!
Offline millerza
  • Zach Miller
« Reply #3 on: October 08, 2010, 12:47:48 PM »
yea the check valve is worrying me.
whats wrong with that color? dont have to worry bout tarnish
Offline gmonkey
« Reply #4 on: October 08, 2010, 12:54:27 PM »
Can you polish and clearcoat them?  Wouldn't have to worry about temperatures and probably a lot cheaper.
« Reply #5 on: October 08, 2010, 01:07:48 PM »
+1
the old clear will come off with carb cleaner and some elbow grease. (dont use steel wool)
Buff.  clear.  done.
on the cheap and in 1 day.
Offline angeldeville
  • You meet the nicest people on a Honda!
« Reply #6 on: October 08, 2010, 01:14:28 PM »
Potmetal bodies and baked on electrostatic powder, are a bad idea, too many precision orfices to get plugged up.
76' cb750f custom
69' cb750 sandcast
69' CT90
Amen Saviour 750 Chopper frame
and enough parts to build about 6-7 more bikes
Offline millerza
  • Zach Miller
« Reply #7 on: October 08, 2010, 01:17:40 PM »
I could. But this is what I want. Id just as soon paint as I would polish and clear. This color is duller/darker than polished alum.  Im not wanting flashy(chrome) look, just tough coating with good looks.    I think the check valve is the only problem, and I can leave that part for paint or just polish. Ill have one carb done at a time, and check results.
Throat/orfices will be well covered/prepped. holes plugged. (The carbs will be assymbled when coated). Just no gaskets/parts inside. Fewer orfices to cover
« Last Edit: October 08, 2010, 01:22:42 PM by millerza »
« Reply #8 on: October 08, 2010, 01:19:34 PM »
Potmetal doesn't polish, unfortunately this is one spot on our beloved bikes that can't be prettied up, although you can chrom plate a few parts and make em look ok.
« Last Edit: October 08, 2010, 01:24:54 PM by angeldeville »
76' cb750f custom
69' cb750 sandcast
69' CT90
Offline DavePhipps
  • Reading the entire Hi-Perf forum
    • Hillside Technology
« Reply #9 on: October 08, 2010, 01:23:25 PM »
I  thought carbs were aluminum. What is potmetal?
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #10 on: October 08, 2010, 01:25:43 PM »
Offline gmonkey
« Reply #11 on: October 08, 2010, 01:26:41 PM »
There's a small nylon "nub" that guides the throttle valve and keeps it from rotating.  Don't know if that would like the temps either.  or is that what bollingball is talking about?
If you want dark aluminum, soaking them in simple green makes the carb bodies darker.  I'll try to get a picture of mine when I get home, maybe you'll like it.
« Reply #12 on: October 08, 2010, 01:27:55 PM »
What is potmetal?
Listen to Black Sabbath - Master of Reality!!!  :D
Offline DavePhipps
« Reply #13 on: October 08, 2010, 01:32:36 PM »
http://en.wikipedia.org/wiki/Pot_metal
Just read that  after asking. It still doesn't answer the question about the carbs being aluminum or not. I'm about to  use acid on my carb that  doesn't effect aluminum but will dissolve other metals. So, I'd hate to see my carb dissolve.
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline gmonkey
« Reply #14 on: October 08, 2010, 01:35:22 PM »
I'm pretty sure they're aluminum.  He wants a different color and surface properties.  Would you want to test that acid on some rough part of the carb body anyway?
Offline DavePhipps
« Reply #15 on: October 08, 2010, 01:54:18 PM »
Good point. Sorry, I'm so tired I can barely think straight.
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
« Reply #16 on: October 08, 2010, 02:03:07 PM »
I'd show them to my powder coat guy. If they're any good they'll tell you.
Offline rachet
  • '77 CB750 F2
« Reply #17 on: October 08, 2010, 02:14:08 PM »
+1
And I'm curious because I would like to Powder coat the carbs some other color, like Black.  If Powder coating is a bad idea, what about chroming?
No high temps, but obviously it would be in every orifice of the carb.
Thoughts?
But I need Tacos!  I need them or I will explode!
Offline markb
  • When I finish my current project I might be a
« Reply #18 on: October 08, 2010, 02:26:23 PM »
Not sure but don't electroplating processes stay out of holes unless there is an anode in it?
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Offline rachet
  • '77 CB750 F2
« Reply #19 on: October 08, 2010, 02:29:52 PM »
That's what she said!!!
Sorry, I work in an office and that's still funny around here.
Seriously though, that's a great question.  I might look into that.
Offline millerza
  • Zach Miller
« Reply #20 on: October 08, 2010, 03:06:17 PM »
not sure what youre talking about? slides are out of carbs
bollingballs talking accelerator pump
Offline gmonkey
« Reply #21 on: October 08, 2010, 03:16:38 PM »
Unless 78 carbs are significantly different than the early ones, if you look down the round bore in the top of the carb body where the throttle slide travels, on one side there will be a small plastic bit sticking out.  There's what looks like a rivet on the outside that holds it in place but you can see plastic in the center.  There should be a a slit down the throttle slide that this guide goes into.
Offline MADCB400F
  • My 74 CB750
« Reply #22 on: October 08, 2010, 04:18:16 PM »
One more suggestion would be find some one with a soda blaster and medium grit soda,  it makes them look new after they have been blasted, or buy one for a multitude of uses later down the road if you already have a compressor.
Offline millerza
  • Zach Miller
« Reply #23 on: October 08, 2010, 09:35:00 PM »
so I dont see anything nylon in here
Offline millerza
  • Zach Miller
« Reply #24 on: October 08, 2010, 09:45:02 PM »
so there is plastic under this brass square?
is there a check valve here? any plastic?
fyi pic   the carb as i plan to coat it, before plugging holes and throat
those allens where a mistake(rust) got kit from stainlesscycles
