Author Topic: can a kickstart be installed on a 750 dohc  (Read 8353 times)
Tank
« on: October 09, 2010, 11:36:52 AM »
hey guys and gals im looking for an answer to the question can a kickstart be put on a cb750 dohc thank you
Offline HondanutRider
Re: can a kickstart be installed on a 750 dohc
« Reply #1 on: October 09, 2010, 03:55:49 PM »
Not unless you are VERY inventive.
Offline Bodi
« Reply #2 on: October 09, 2010, 08:52:55 PM »
certainly it's possible. It's not going to be easy... actually it's definitely going to be a fricking nightmare...  and what's the point? You can always bump start it if you really hate electric start.
« Reply #3 on: October 10, 2010, 04:00:29 AM »
umm?what for?the dual starters of the 70s were mainly because people "might not trust"the modern electric ones,plus batteries of the day wernt as good as these days,i think its a pointless idea.,something a troll might post.
« Last Edit: October 10, 2010, 04:03:11 AM by dave500 »
« Reply #4 on: October 10, 2010, 09:59:01 AM »
 I dont consider it a pointless idea..
 I have a 750 Sizuki tscc motor here I would like to put in a CB 750 as a tracker.. but no kicker..
 I have never owned a non kicker (or pedal start), and dont plan on changing soon..
 So for the track there is 4 options, push start, roller start, electric start using  remote battery, or modding a kicker.
 But every motor is different, so if I could mod the Sizi, it would not be the same on the Honda DOHC..
Offline gerhed
« Reply #5 on: October 10, 2010, 01:29:08 PM »
Here's a starting mechanism that I built a while back.
All you need is another bike that starts easily.
You put the rear wheel on one side of the roller rig.
The bike you want to start is on the other side.
With the easy starting bike running and
turning the rollers you just drop the clutch on the other one
and it starts right up.
Maybe something like this would be helpful.
          83 XL600R in CB360 Frame
« Reply #6 on: October 10, 2010, 01:59:28 PM »
I guess you would have to open up an SOHC and your DOHC and see what real changes were made. They may be close enough for you to transplant the kickstart mechanism.
« Reply #7 on: October 10, 2010, 02:28:55 PM »
 Like gerhed showed is easy to make, then power by truck/car/bike or small motor..
 I was thinking, leave starter in, use two welding jacks, on cables..... connect to  motor, then pull out when started.. ;D
Offline The_Crippler
  • Work in progress.
« Reply #8 on: October 10, 2010, 03:24:26 PM »
Approves.
Offline weekend_junkie
  • I bet you think I'm some
  • Member # 15859
« Reply #9 on: October 11, 2010, 02:25:53 PM »
Having been a DOHC guy for a while now, I'm not sure where the kick lever would go into the cases with the clutch basket in the way.
Can you still use the skateboard?
Dan
Offline gerhed
« Reply #10 on: October 12, 2010, 08:53:06 AM »
That project actually consumed 9 skateboards.
---------Got a little out of control.
  • Work in progress.
« Reply #11 on: October 12, 2010, 10:29:35 AM »
How did you acquire the boards?  Were the words "you kids" and "my lawn" ever uttered?
Tank
« Reply #12 on: October 17, 2010, 10:03:56 AM »
just a question a simple no or a ya but its going to be very hard and a lot of work would be just fine. thanks to all that sayd just that. and a thank you to all that took the time to answere with a nonproductive answere the people that try to help have a name for that i hope someone helps you as much as youve helped me
cheers
