Author Topic: single/dual filament taillight  (Read 1294 times)
comcrx
« on: March 08, 2006, 06:15:49 AM »
I ordered a got a new taillight yesterday and it only has a red & black wire, so I'm assuming its a single filament, which means its a brake light only, right?
is there a way to put a dual filament fixture in there so it would work as a running light also? I'd really like to use this style on my bike
:edit: sorry for being 'that guy'. I just took it apart to check and I was wrong, it will work. I guess it just grounds to the metal of the fender. sweet!
« Last Edit: March 08, 2006, 06:27:15 AM by comcrx »
Offline dusterdude
Re: single/dual filament taillight
« Reply #1 on: March 08, 2006, 08:26:39 AM »
pull the bulb and see if it has 2 contacts on it,if so,it is both tail and brake lights.the manufacturer has it made so it will ground itself on the metal fender.if you need a ground just run a wire from the lite housing to a good ground on the bike.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
comcrx
« Reply #2 on: March 08, 2006, 08:46:46 AM »
yeah, I was thinking I should just run a ground wire from the original 3-wire set to the set screw that holds the light socket in the housing
thanks!
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #3 on: March 08, 2006, 02:38:06 PM »
Running a ground wire to the frame is always a good idea.
Insures a solid ground, no matter what surface the light is being mounted too...
