Author Topic: CB750 forks on my '71 CB500? How can I tell?  (Read 5978 times)
)joshf(
« on: March 08, 2006, 07:59:29 AM »
So someone on this forum mentioned that the forks that are on my CB500 now look like they might be off of a CB750. How can I tell? Would the PO have modified the triple tree or anything else to make them fit if they are 750s? They really arent as nice as they look in the pic. She shine is just a plastic cover that the PO rigged up. The actual tubes are pretty rusty. If they are 750 forks would that explain why they are "extended" or would they have had extended tubes put in them as well. Also wondering if I should keep the lowers and just replace the tubes with stock lenght ones. I have a set I could rob the tubes and boots from. Any suggestions would be cool. Thanks.
Re: CB750 forks on my '71 CB500? How can I tell?
« Reply #1 on: March 09, 2006, 08:14:23 AM »
Those tubes are definately extended, send me a closer picture of the brake caliper and mouting and i will tell you which it is
Offline Ted Nomura
« Reply #2 on: March 09, 2006, 01:41:06 PM »
Your CB500 looks like it has the early CB750 brake calipers (note the silver color) which came from 1969-1970 CB750s. Standard CB500Ks have smaller disc and brake calipers, which was also standard on 1971-1974 CB450Ks and 1975-1976 CB500Ts, with different brake lines. They also seem to be the same units mounted on the 1977-1978 CB750Ks. 1970 CB450K had early CB750 front brakes. Fork tubes are interchangable but the fork lowers are not.
1969 Honda CB750, two 1970 CB750, two 1972 CB750K2, 1971 CB500, 1975 CB550, 1976 CB400F, 1968 CL450, 1973 CL450, 1974 CB450, 1970 1/2 SL350K1, 1971 SL350K1, 1972 SL350K2, 1972 CL350, 1972 CB350, 1983 CB1000C, 1976 Kawasaki KZ900A4, 1976 KH500A8, 1979 KZ400B, 1983 ZN1300, and so on and so on...
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #3 on: March 09, 2006, 01:57:39 PM »
           I too would like to know how you can tell the difference in forks. Between the CB450 (I know,
   DOHC), 500,550, & 750 how do you know which is which? I have read on here that the 750 tubes are longer than the 500 or 500 but, by how much? Does anyone know the measurements or identifying features of the different ones? I'm sure there are others who'd like to know as well. Any info would be appreciated. Later on, Bill
Member # 1969
Offline Ted Nomura
« Reply #4 on: March 11, 2006, 01:44:55 PM »
Diameter of the CB750, CB550, CB500 and CB450 are the same in most cases but lengths are different. But my CB400F forks won't fit because it's smaller and narrower. Looks like his 1971 CB500 got the extended CB750 forks(about 6") because the previous owner probably exchanged his CB750 chopper forks with stock CB500 units to make the CB750 look more stock, but the 1971 CB500 can be just as valuable if it can be returned to stock because it still has the standard mufflers. Of course if he doesn't want them, I'll gradly take it because I too have a stock CB500 that needs original mufflers to make it complete. You might want to check ebay although I haven't seen early CB500 forks and wheels on the sale list lately but I noticed some parts bikes with them. Forks for the 1971-1975 CB500 and CB550Ks are mostly the same.
« Last Edit: March 11, 2006, 01:53:24 PM by Ted Nomura »
