Author Topic: Jeep coil to test my Yamaha LS2?  (Read 1518 times)
Offline canttuckmyshirt
« on: March 08, 2006, 08:54:24 AM »
I'm working on a 1972 Yamaha LS2 2-stroke twin 100CC!
I got the carbs, clutch, brakes, tank, everything fixed. New plugs, points, condensers... I'm only getting one cylinder to fire. I wanted to try hooking up a new coil. Can I use a automotive coil for testing? I have coils from MSD and from stock 4.0l Jeep. Can I use these to test (or permanently)?
I could always try swapping them, but I'd rather not mess with the cylinder that is working.
Thanks!
72 CB500, Abe Henry wheels
77 CB550, resto-mod
04 S2000, LS1 V8
Offline dusterdude
Re: Jeep coil to test my Yamaha LS2?
« Reply #1 on: March 08, 2006, 11:24:56 AM »
you can use the auto coil to test with,as far as permanently using it would depend on the resistance situation.you will need to know if the yamaha requires an internal resistance coil or external resistance coil and then check your auto coils,the resistance numbers should be darn close.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
chopper1959
« Reply #2 on: March 08, 2009, 09:40:04 AM »
 did it work ? I am having the same problem with my 72 ls /
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #3 on: March 09, 2009, 07:34:02 PM »
        Good to know that someone has one of those LS2s. I had one quite some time back. Pretty decent looking bike AND it would haul me pretty well at the same time. Kinda reminded me of a "Baby" R5 Yamaha. ;)
Member # 1969
