Author Topic: Re: 77 cb750a Hondamatic cafeish Starting to look like a bike again!!  (Read 5740 times)
Offline ryani
« Reply #25 on: December 23, 2010, 08:22:51 PM »
Well I got the bike rewired today and it actually fired!!!!!! After a bit of kicking and screaming she finally roared to life.  It seemed to idle very high after it warmed up and I couldnt adjust it down with idle adjust screw.  Any suggestions on what to look at first???  Thanks
Offline knowsnothing
« Reply #26 on: December 23, 2010, 08:34:08 PM »
Sounds like an air leak.  Try squirting some wd-40 or something on the boots.  If the rpm changes, you have a leak.
1978 CB750k Blue - for sale
Offline ryani
« Reply #27 on: December 23, 2010, 08:36:13 PM »
Sounds good.  Thanks for the tip.  As much as a problem as it was to get the airbox boots onto the carbs I could believe that would be the prob.  I'll check with wd-40 tomorrow morning.
Offline ryani
« Reply #28 on: December 26, 2010, 09:41:40 AM »
Air leaks and voltage drains!!!!  Woohooo!!   Well I got out to the garage quick.  Didn't spend alot of time because my fingers were freezing.  Anyway I did a quick amp check with the key off and found when I unplugged the voltage reg the amp draw went to 0!  I wired it up as per the instructions but I'll have to do some investigating tomorrow.
Offline ryani
« Reply #29 on: December 29, 2010, 06:46:44 PM »
Well I ordered a two sets of mains and two sets of idle jets today along with a new accel pump diaphragm.  I'm going to run velocity stacks due to the fact that I can't get new intake rubbers and have many leaks.  Just going to richen everything up and let er rip!!
I think I found my drain problem.  It has something to do with the ford voltage reg.  When I disconnect it my amp draw falls to 0.  Its back feeding some how.  Maybe a diode in the ignition   (black lead) will take care of it.
Got my new taillight built.  I made it out of old indicator lights that I got from an old control panel at work.  Fits the bike i think.
The seat is at the upholstery shop as of yesterday.  I was looking at an old yamaha rd350 for my next project at this mechanics shop and viola!!! he had a guy that does seats!!
« Reply #30 on: December 29, 2010, 06:54:45 PM »
I like your tail light idea.  I was gonna use some of those same lights, but blue, to do the old hot rod trick of blue dot tail lights.
Offline ryani
« Reply #31 on: December 30, 2010, 07:30:01 AM »
Thanks!  I ordered a led taillight for the bike but thought it just didn't fit the old girls style.  I found some parts and work and bought an 1157 light socket at the auto parts store and came up with something different.
Offline ryani
« Reply #32 on: January 10, 2011, 04:43:12 PM »
Got all my new jets installed yesterday.  Went up on the pilot needle and main.  Hopefully I can get it to run well enough with bench sync I did to really get a good test on the charging system.  Baby steps are better than no steps I guess.
