Author Topic: 85 virago question  (Read 1244 times)
Offline mmtsquid
85 virago question
« on: October 13, 2010, 08:08:56 AM »
Friend recently bought an 85 virago 700, and it was running REALLY rich - to the point gas was dripping out the exhaust, and there was some gas in the oil. (I know, YIKES!!!)
Compression is solid, but removal of the carbs revealed the the idle mix screws were 5 turns out from seated (twice the recommended factory setting).
Could this have been enough to cause it to run that rich?
77 CB550K4
Offline gane
  • Gane
Re: 85 virago question
« Reply #1 on: October 13, 2010, 07:25:54 PM »
M, No...the TK carbs on your' friends' Virago had "issues",  Gas in the oil (crank case & exhaust) is usually due to a float valve problem. (in order of occurance) 1 stuck/sticking float valve (at needle)2.leaking o ring at float valve seat. 3. sticking float (at pin.) Typical failure is a float valve /s fail to seal,  & fuel pump overpowers  float valve/s & pumps raw gas thru carb & into head. Thus gas in crankcase &/or exhaust..... High mileage viragos of this vintage would also wear out the throats of their emulsion tubes & needles causing them to run "rich" at normal throttle settings.( to the point they were un-availible for years) Your' fuel screw settings are probly screwy due to PO's attempt to correct for dirty pilots. On these bikes it's important to note that jetting was "staggered", double check diaphrams for leaks, & that on re-install carbs are "seated".fuel screws are often "finiky" w/ the "sweet spot" being within a 16" of a turn. luck G
Offline mmtsquid
Re: 85 virago question (solved)
« Reply #2 on: October 15, 2010, 07:53:52 AM »
Well, whatever the problem, it's all good now!
Reinstalled carbs, changed oil, and fired it up.
It smoked like CRAZY for about 10 minutes, but now it runs great, plugs are a nice tan color.
77 CB550K4
