Author Topic: Recommendation For a Newer Bike, $1500?  (Read 842 times)
Offline OakBehringer
« on: October 13, 2010, 12:22:21 PM »
A friend of mine is looking for a newer bike that will be in the $1500 range. It will be his first bike, something in the ~450cc-650cc range would be wise for him to learn on. He does not want to do his own maintenance, so finding a newer bike that more mechanics will be willing to work on is important. Reliability is key. Hoping to find something that has the classic "cruiser" look. He's 6'2" so a Rebel or LS650 won't cut it.
Suggestions?
Thanks!
Adam
p.s. bikes dated post late 70's are out of my range of expertise, thus the cry for help.
« Last Edit: October 13, 2010, 12:38:24 PM by OakBehringer »
1974 350 Four - SOLD
1966 CL160
1981 XS650
1972 CT70
Finished CB350F
HELLS BANANAS
Offline kirkn
Re: Recommendation For a Newer Bike, $1500?
« Reply #1 on: October 13, 2010, 01:53:40 PM »
Honda 750 Nighthawk - intro'd in 1991 thru whenever they quit (IF they quit).  750cc DOHC basic.  750 yeah, but very user-friendly power characteristics should be fine for him.  They'll easily go 50k miles.
Suzuki 600 Bandit, but might not be able to find one that inexpensive.
Suzuki SV650 but ditto price
Kawaksaki Ninja 250 with a set of bar risers, but knees might still be too pinched.
Suzuki DR350 or DR650 dual sports.  Reliable as an anvil.
I'm sure there are others.  Those just are off the top of my head...
Kirk
« Last Edit: October 13, 2010, 01:56:08 PM by kirkn »
Offline Alan F.
« Reply #2 on: October 13, 2010, 04:32:35 PM »
Yup, 91-2003 with very few minor changes through the run, like the drain plugs at the bottom of the fork sliders disappeared in like 96 or something.
I'm the 3rd owner of my 92 750 NH, $1300 off of craigslist 3 years back.  It's an appliance, hydraulic lifters and cam chain tensioner... so no adjustments to make. Chain drive. Carbs are pretty simple up 2 sizes on both jets and set airscrews to stock for a Vance & Hines 4:1
Mine has a little over 45K and it came to me with 31K miles.  Lets see, Rotella 15-40, purolator filters, stock air filters, Sintered brake pads, same brake rotor as early CBR600/1000 and ST1100 so plenty of them around to tear up with rough brake pads, no worry about enough stopping power with the single disk either.
Be sure to replace ALL of the bushings in the front forks when you have them apart to change seals, not very cheap but very worthwhile and use OEM Honda seals too they're the best, 10wt fork oil is good.  Michelin Pilot Activ tires are the hot setup, you can go with a 150 on the rear with no issues.
Plus you can probably find one of these bikes with low mileage in great shape, it was considered a wimpy bike in its day because sportbikes were what everyone wanted then, so lots of them are well preserved. $1500 should get you one under 10K miles.
PM me if you need a manual, I have a spare I can part with cheaper than you'll find a new one.
Alan
« Last Edit: October 13, 2010, 04:34:08 PM by Alan F. »
