Author Topic: K vs. F camshafts  (Read 1502 times)
Offline superchode
K vs. F camshafts
« on: March 09, 2006, 09:03:27 AM »
to rebuild the engine after the camshaft seized to the blocks i picked up a used camshaft and valve towers in good condition from a breaker.
trouble is, i don't know if it's a K or an F shaft. it'll definately fit... but i'd like to know what the difference is between the two types of camshafts and what i should expect if it does turn out to be a K shaft. could i measure it to find out?
Re: K vs. F camshafts
« Reply #1 on: March 09, 2006, 09:39:41 AM »
You can expect slightly less lift and duration if it's a K cam.
Offline superchode
« Reply #2 on: March 09, 2006, 10:03:18 AM »
any definitive way to sort which type i've got? i've got micrometers and calipers. should be able to sort the pitch... at least roughly.
Offline scondon
  • Mmmm......tasty bugs
« Reply #3 on: March 09, 2006, 10:45:59 AM »
    Which F model engine (F0-F3) are you rebuilding ?   I've got a K8 and F3 cam at home and can probably measure the lift on each for comparison.
Offline superchode
« Reply #4 on: March 09, 2006, 11:23:12 AM »
it's a '78 F. guess that makes it an F3.
Offline scondon
« Reply #5 on: March 09, 2006, 11:29:31 AM »
   Yep, that's what I have at home. I'll post what I can this evening  (6 hours from now).
Offline scondon
« Reply #6 on: March 09, 2006, 06:53:11 PM »
Well 'chode, I was hoping to have something "definitive" to post after measuring the cam lobes using my POS caliper (POS=Piece Of S***), but I'm afraid what I got might not be exact enough for you to determine which type of cam you have. Here's what info I got when using the caliper to measure the intake lobe from base(no lift) to highest point of lobe(maximum lift).
F3 cam:    36.2mm
K8 cam:    35.8mm
Roughly .016" more lift on the F3 cam
The lobe profiles differ but are most notable on the exhaust valve close(F3), it slams shut quickly.
Each cam is stamped "R-2" but the K8 cam is stamped with "F" at one end, the F3 cam is stamped "J" at one end.
Here is the spec sheet for your F3 and K8 cams. I hope this helps :-\
Offline superchode
« Reply #7 on: March 10, 2006, 06:07:28 AM »
thanks for the info, i'll scope my cam out tonight at the shop
