Author Topic: Cylinder head removal CB750  (Read 17634 times)
Offline RupertB
  • Roll on spring - the rain gets warmer then...
« on: October 15, 2010, 12:16:08 PM »
Here's the point when you find out who your friends are! - Now then, I tried to remove the cylinder head of my 74 K4 750 motor and ended up removing the head and barrels together which isn't a problem as the whole lot is coming to bits anyway, but I now have to separate the head fromthe barrels obviously.
The fins bear witness to a previousowner who has used the time-honoured 'tyre lever and brute strength' method, but I'd rather avoid that for obvious reasons!
I have removed all the nuts including the ones that sit in by the spark plugs, and also removed the bolts front and rear in the centre of the block, but there are meant to be a few other bolts somewhere in the head, looking at the Clymer manual they seem to be under the rubber bungs under the cam blocks. However looking beneath those bungs the bolts seem to be missing so - do I go for a bit of leverage and hope, or are there more hidden bolts I should look out for? And even when all bolts and buts are removed, is the head sticky to get loose?
Good news is that the pistons are 74mm so I have an 810 Yoshi engine. Rumour turns to fact - hurrah!
Author of 'Prisoners Property and Prostitutes' by Tom Ratcliffe. Most readily available from Amazon as a paperback and electronic Kindle edition.
Offline gnarlycharlie4u
  • Far from being an
Re: Cylinder head removal CB750
« Reply #1 on: February 26, 2011, 01:54:13 PM »
I hate to bump an old topic but I'm having a similar problem. PO seems to have glued the crap out of the cyl to head gasket so now I'm pretty clueless as to how to separate the two. I've tried being gentle (rubber mallots, pieces of wood, plastic prypar) but nothing seems to be even making a dent.
Any suggestions?
bollingball
« Reply #2 on: February 26, 2011, 02:08:21 PM »
There are a couple of stronger pry points on the rear of the head look for two little tabs on the head just below the intake ports they line up where the bolts go through the jugs this is the strongest pry point. If you don't buy another tool you should consider HondaMans book it covers this and a ton more tricks that you usually only get with time.
  • Far from being an
« Reply #3 on: February 26, 2011, 02:34:24 PM »
I tried those pry points already but the thing just isn't budging. RTV is some strong ish apparently. I do definitely need to get hondaman's book. I wish I bought it when it came out like I planned to.
Maybe I just need to stop pussyfooting around and give it some serious force.
Offline RupertB
« Reply #4 on: February 26, 2011, 03:59:09 PM »
My project has gone on hold until I have enough money to make a substantial move forward on it, but it is at a point with the top end now stripped and everything (fairly) neatly boxed and sorted. I did eventually get the head off but it wa unusual - I treble and quadruple checked I really really had got every bolt removed, and with gentle prying and leverage round and round the base of the head - more times than I can remember - got one end of the head to lift away, but every time I went to work on the other end the freed and sat back down again. So I put a thin lath of wood through over cylinder number three, then managed to slide a ratchet strap inboard of that, before lifting the strap just enough to let the weight of the block pull on the joint. With a little more gentle (and I mean really gentle) leverage with wood rather than metal (because thin wood breaks first when you lose your temper!) it eventually separated. I think the biggest stick point was actually the round hollow peg thing which looks like an oilway, but my engine hasn't run for over 15 years, so there ain't no oil in there!
If you are still awake after that - hope it helps!
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #5 on: February 26, 2011, 04:18:03 PM »
Hmmmm maybe heat 'em up pretty good in ur oven (plan on a day when the Mrs is out).  If that doesn't free them up, try to draw a fine guitar string through the joint.  If all the bolts are out, there shouldn't be any metal to prevent the string from passing through.  Take care not to "saw" with the string, just try to push it through when hot.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
srook
« Reply #6 on: February 26, 2011, 10:29:02 PM »
You can also try to use cedar shims.  If you can get one started you can pound it in which will drive the head and barrels apart without damaging the gasket surfaces.
Scott
Offline markb
  • When I finish my current project I might be a
« Reply #7 on: February 27, 2011, 05:38:13 AM »
I would double check to make sure the four bolts under the rubber pucks aren't there.  There's only four of them under the six pucks and sometimes they're hard to see.  It's hard to believe that someone would do that rebuild and "forget" to put them in.  It can't hurt.  ;)
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
« Reply #8 on: February 27, 2011, 05:51:59 AM »
I use the tiniest of chisels as a wedge. A 1/4 inch hardened chisel, tap it into the head gasket area till you hear the head separate then work around. All obvious caveats, all bolts out etc.
Also I'm thinking a heat gun couldn't hurt.
  • Far from being an
« Reply #9 on: February 28, 2011, 08:33:45 AM »
I'm wondering if sticking it in the freezer would help any?
Offline MasterChief750
  • Detonation
« Reply #10 on: February 28, 2011, 08:41:29 AM »
theres aligning pins(lack of a better word) between the barrel and head. i ended up trying to pry but it failed miserably and cracked a fin. i ended up dropping it about a foot onto a carpet pad on the concrete and it came apart
1976 CB750 K - Drag Bike
I AM THE STIG
Sam is THE STIG
he said i can be STIG3 tho
  • Far from being an
« Reply #11 on: February 28, 2011, 08:54:44 AM »
Yea I broke a fin too... I suppose I might as well try the drop since I have nothing to lose.
  • Detonation
« Reply #12 on: February 28, 2011, 08:58:59 AM »
thinking back i tried the drop for a bit then ended up holding the barrels and hitting it against the ground
I AM THE STIG
Sam is THE STIG
  • Far from being an
« Reply #13 on: February 28, 2011, 09:02:52 AM »
I've tried setting it on it's side on the bench with the cyl hanging off. Then put a foot on it to stabilize it and smacked it with a plastic maillot till I broke the maillot :-/
Offline RupertB
« Reply #14 on: March 03, 2011, 02:54:44 AM »
I can't see heat hurting as long as it isn't too localised, and I can't see cold being a problem with the same caveat.
My engine had been put together without the bolts under those rubber bungs which is pretty ignorant, but then I don't know if it has actually run since then or not.
I lke the guitar string idea - I think some persistent gentle prying with a thin chisel, or maybe a feeler gauge perhaps? I unintentionally started getting it to lift at one end and had the dangerous but useful extra facility of leverage the length of the block, but the possibility was always there of bending those locating lug/tube things.
Don't know if I fancy dropping it from any height, even onto carpet. Sounds a bit too much 'sh*t or bust', with too great a likelihood of 'sh*t' than I would like.
Good luck anyway!
Keep us posted please.
  • Far from being an
« Reply #15 on: March 03, 2011, 10:19:31 AM »
update: cyl head is removed. I just went at it with a LOT of pbblaster, atf, brake cleaner, and a putty knife.
verrrrrrrrrrry gradually
Offline RupertB
« Reply #16 on: March 03, 2011, 12:00:00 PM »
Hurrah! Doesn't it seem obvious when it is done, but impossible before. Machines 0, Humans 1.
  • Far from being an
« Reply #17 on: March 03, 2011, 12:13:32 PM »
yea painfully obvious. actually that was my original thought but I couldn't find a good clean putty knife that wouldn't score the head
  • Detonation
« Reply #18 on: March 03, 2011, 12:38:04 PM »
oh jjust a little tip. get a can of carb dip and put it in a pan ad soak the gasket surfaces on the jugs and head in it. makes the old gasket a million times easier to get off.
I AM THE STIG
Sam is THE STIG
Offline fmctm1sw
« Reply #19 on: March 03, 2011, 01:15:28 PM »
We were already down 1-0 after I scratched up a 550 top end trying to get it apart  :D
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
  • Far from being an
« Reply #20 on: March 03, 2011, 02:37:34 PM »
I of course didn't find any pans big enough until AFTER I got the mofo off. haha.
Offline stueveone
« Reply #21 on: December 31, 2011, 05:30:35 PM »
Figured I'd post what worked for me:
I used a wonder bar in between the cylinder and head and twisted it with an adjustable wrench rather than prying it up and down. After about 2.5 hours trying other methods, I was shocked how easy this worked (though I'm sure the dead blow probably loosened it a little!)
« Reply #22 on: December 31, 2011, 08:43:43 PM »
I use a very sharp knife and slice the head gasket into 2 layers, and pull them apart as I go.
Offline chewbacca5000
  • I polish covers!
« Reply #23 on: January 01, 2012, 01:14:29 PM »
I just got done taking the head off my 1973 CB750 and had a heck of a time getting 2 of those little outside screws out from under the rubber bungs. On the head I have 10mm won't fit down there.  Had to use vice grips, screwdriver and a rubber mallet.
Trust me they are there.  They may be covered with grease and dirt, but they are there.  With all the bolts out and a few taps of a rubber mallet the head came right off.  I would keep hunting for more fasteners.  I don't know how many times I have tried to remove an oil pan and missed that one bolt holding a cable and my pan would not come off.
Good Luck!
« Reply #24 on: January 01, 2012, 01:52:31 PM »
Danger Will Robinson!
Yes there are 4 in a row under the #1,3,4,and 6 biscuits.
These should be removed BEFORE removing the head nuts. Once the head nuts are removed the swell of the gasket and the cylinder head serve to increase the torque on those dudes tremendously. To the point where you can barely, if even, get them out. You may want to consider reinstalling the cyl/head assy, onto its studs, tighten the nuts back down, then remove the 4 under the bungs.  This can be done easily with the pistons off.
If you have a long Phillips bit, you could use an impact driver on them.
« Last Edit: January 01, 2012, 01:54:51 PM by MCRider »
