Author Topic: 1976 CB550 Front Disk size (for disk lock)  (Read 2303 times)
Offline Nortstudio
  • Not nearly an
  • Just getting started...
    • MotoPreserve
« on: October 16, 2010, 09:19:39 AM »
Hey there,
My new purchase of a 1976 CB550 is arriving tom'w - needs LOTS of work, so I will be seeing you all soon :).  Seller has agreed to ride her to me, since I will not be able to get the reg/plates until sometime next week.  Although the bike is not really something I would worry about getting stolen, in it's current visual state, I figured I should buy a disk brake lock at least, to have a some peace of mind.
Can anyone tell me what the size is I would need for the stock front brake?  The disk locks I have found come in 2" and 3", and the size of the pin for the holes (10mm I suspect).   The parts list I have for the bike doesn't have the size, and I would love to have it on hand when it gets here.
Thanks!
1976 CB550K...in progress
1975 CL360...eventually custom
2009 Husqvarna TE610
a blog about wrenching in Brooklyn, NY
“Success is dependent on effort.”
~Sophocles
Offline Shenanigans
  • Right turn?
Re: 1976 CB550 Front Disk size (for disk lock)
« Reply #1 on: October 16, 2010, 01:49:47 PM »
Unless your disk has been modified from stock and drilled, Then they are solid. No holes like anything "modern" (well anything newer that 1980  ;D )
And I might be wrong but dont all disk locks work by clamping though one of those holes?
Offline CB750faces.com (Lecram)
  • CB750faces.com
    • Buy High Quality Honda gauge parts online!
« Reply #2 on: October 16, 2010, 02:05:08 PM »
You can also use this one and lock your bike at the rear sprocket (don't forget to remove the lock when you start to ride  ;) )
https://www.kryptonitelock.com/products/ProductDetail.aspx?cid=1000&scid=1003&pid=1198
« Reply #3 on: October 16, 2010, 02:09:29 PM »
+1. Plus this comes with a theft insurance policy*!
*see special notes for NY residents.
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #4 on: October 16, 2010, 02:32:55 PM »
Thanks so much folks.  When you say at the rear sprocket, do you mean thru the spokes near the sprocket?
Appreciate your help.
~Sophocles
  • CB750faces.com
« Reply #5 on: October 16, 2010, 03:16:15 PM »
No, the sprocket does have several holes in it (see pic). You can use one of these holes. Your lock gets dirty by the chain, so you'd better use a small back to store the lock after use.
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #6 on: October 16, 2010, 03:33:28 PM »
Gottcha. Sorry for the confusion.
If only you all could see hoe different my back wheel looks from the example in your photo!  Cleanliness, wise :)
It will be an uphill battle getting her looking a little finer, but that's half the fun...
Thanks for the tip.
~Sophocles
