Author Topic: Dyna 2000 troubles  (Read 1393 times)
Offline Jim F
  • go baby go
Dyna 2000 troubles
« on: October 16, 2010, 11:32:11 AM »
As my project is getting close to being finished, I have a problem that I need help with
I am running a Dyna 2000 with Dyna 3 ohm coils
it was pretty east getting everything wired up after a little help.
Went to start the bike and number 2 cylinder didn't fire. After a couple of minuets, it started to catch
and finely fired.
pulled the bike back in to the shop and pulled all the plugs, grounded to the valve cover.
Now the strange thing is that When I started to check out connections, voltage etc etc
everything checked out per the instructions from Dyna
all plugs are firing (Grounded on the valve cover) everything is good
went over on the other side of the shop, did a little work
came back an hour later and 2/3 are not firing.
as far as I know everything is plugged in, voltage is good and the grounds are grounded
I have also hooked up 3 different sets of coils with the same results. 1/4 fire every time and 2/3 are inconsistent
any opinions and thoughts greatly appreciated
thanks
Jim
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Re: Dyna 2000 troubles
« Reply #1 on: October 16, 2010, 12:00:42 PM »
Is there a specified gap for the triggers? I would look at that..
Offline wookie
  • I would get up if i knew i fell
« Reply #2 on: October 16, 2010, 07:27:18 PM »
did you static time it?  You may need to adjust the plate and or rotor.  2 and 3 are adjusted from the rotor under the allen heads.
Offline Jim F
  • go baby go
« Reply #3 on: October 17, 2010, 08:20:35 AM »
 I re-checked the timing and its dead on (Using the LED on the box)
I contacted Dyna with this and am waiting for the reply.
Thanks
Jim
Offline Doctor_D
« Reply #4 on: June 04, 2011, 09:52:45 PM »
I'm having issues like Big Jim had last fall.  A single cylinder is dropping out... but not the same one every time.
Using an infrared thermometer, exhaust pipes for 3 out of 4 cylinders will all be about 500f, and the random offender will be running 130f or so.
The problem has varied between coils, which check out OK.  Starting to think the Dyna2000 controller is going.
Jim: How did this story end for you?
« Last Edit: June 05, 2011, 12:26:15 PM by Doctor_D »
Take care,
David
1978 CX500
1971 Norton Commando
Offline grcamna2
« Reply #5 on: June 05, 2011, 09:32:24 AM »
I would try testing All the components to spec and see if they measure up w/ a good
meter and factory specs for the Dyna triggers,etc. If they All check out ( & double
check out) you may nail it down to a defective Dyna Black box.
