Author Topic: Amen Savior Plunger frame spring install ?????????  (Read 5124 times)
KingCustomCycles.com
« on: October 17, 2010, 12:50:09 PM »
Does anyone here have first hand experience installing the plunger springs in the suspension of an old school Amen's Savior frame?  I have spring compressors, have made two different special tools, and I still have no idea how this is supposed to go together.  Thanks all!!!
Re: Amen Savior Plunger frame spring install ?????????
« Reply #1 on: October 17, 2010, 01:15:12 PM »
There is a special tool for putting them in, I sold mine to a member on here.
  Cant remember exactly what was there, but it worked well.. Might be able to build one, if there is no other options..
Offline CycleRanger
  • No comment about being an
srook
« Reply #3 on: October 17, 2010, 07:39:08 PM »
"Special tool"  Its a threaded rod with a big washer and a nut on it.  Install is the same as reverse.  The pdf that was posted explains it all.  BTW they are still a pain in the ass to assemble/disassemble even with the "special tool".
Scott
Tank
« Reply #4 on: October 17, 2010, 07:54:28 PM »
when i did my old one i just notched out 2 chunks of wide angle iron and drilled i hole on each end put a chunk of threaded ready rod and nuts and washers the hole thing cost me all of $5.00
heres a fast drawing i did if it helps it saved my life
« Reply #5 on: October 18, 2010, 06:28:15 AM »
Tank, that was exactly the tool I made first.  I ended up using the instructions on hondachopper.com and got it together last night.  I am planning to put locating bolts in the rear as they have in the front.  This, combined with new bushings top and bottom, should result in a tight and reliable plunger. Thanks for the help guys.
Offline tango911
« Reply #6 on: October 18, 2010, 07:07:47 AM »
i heard all Jesus disciples rode in a honda,  they were all in one accord.  :P
CURRENT STABLE:
1969 Honda Dream 305 (black)
1974 Mach III kawi 500 smoker
K2 (project)
K2 Original fixer up
K0 original fixer up
2006 CRF250R
