Author Topic: What is the primary advantage of rotary-winged aircraft  (Read 5877 times)
Offline zzpete
  • You better get an
  • 1969 CB750, 1971 CB750
« on: October 18, 2010, 04:56:05 AM »
This should be an easy quiz for those who have even a modicum of knowledge about aircraft.
The answer may surprise you.
"What is the primary advantage of rotary-winged aircraft over fixed-winged aircraft?"
[img width= height=]http://i472.photobucket.com/albums/rr90/prundle4/Sohc/MailAttachment.jpg[/img]
I got it wrong, too.........................
"One of the things that make motorcycling so great because it never fails to give you a feeling of freedom and adventure." - Steve McQueen
Offline medic09
Re: What is the primary advantage of rotary-winged aircraft
« Reply #1 on: October 18, 2010, 10:26:56 PM »
I'll ignore that they shouldn't be hotloading.  And the props on a fixed wing can have similar effect, depending on where the door is.
Mordechai
'78 CB750K
'07 aprilia Caponord
Santa Fe, NM
Offline Grnrngr
« Reply #2 on: October 18, 2010, 10:33:04 PM »
heh...so THATS hot loading? I can see why they call it that.... ;D
'72 CB750-K2 "PopCycle"
'73 CB750-K2 "Barney"
'77 CB750A
'83 Virago 500 (red)
'83 Virago 500 (black)
