Author Topic: Honda CB100 Question  (Read 2138 times)
Jeramy
« on: October 18, 2010, 03:51:30 PM »
Need some advice on my 72 Honda CB100.
I want to put a different style handlebar on it but the throttle is made for the original high bar. It has a groove that throttle sits in on the bar. What can i do to put a lower bar on it? Do i just need a new throttle? if so, which one would work? Or is there another way to go about this?
thanks in advance! appreciate any and all advice here.
Offline Coyote13
Re: Honda CB100 Question
« Reply #1 on: October 18, 2010, 09:02:32 PM »
If I'm reading you correctly, all you need to do is find a dimpled set of bars that are the same diameter as the ones you already have. Shouldn't be much of a problem, but if you change bar height drastically you'll probably need different cables as well, just a heads up
'78 CB750K.  Throttle ripper.
'71 CB100.  Grocery getter.
'01 XL883.  Panty dropper. Gone but not forgotten.
Offline 333
  • Time for change
« Reply #2 on: October 18, 2010, 09:22:44 PM »
Yes, you need a whole new throttle assembly.  You'll never find anything like the stock one.  Aftermarket is probably your best bet.  Being a thumper will make matching the carb end of the cable easier, and switching out will be more reliable than the stock setup.  Personally, I like the cleanliness of the stock setup.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline 73hutch
« Reply #3 on: November 14, 2010, 03:06:57 PM »
i'm going to have the same issue when i start rebuilding a cb100 that is in pieces. i thought about finding the bars i like and then cutting out the rectangle for the throttle.
78-550k
72-cb100
63 c100
75 xl350
84 gl1200
