Author Topic: Faded paint restore?  (Read 1615 times)
Offline 6pkrunner
« on: March 10, 2006, 05:01:28 PM »
Okay this time I did do a faded paint restoration search and couldn't find anything. However with my keen powers of observation that is meaningless.
I just got a 1974 up flake sunrise orange tank and sidecases off of eBay. The pieces are in really good- the owner removed them in the early 80s or so, but the tank has some fade on the right side (guess from leaning on the sidestand into the sun.) Does anyone have a good solution for restoring faded pieces?
 I have a 1975 Anteres Red tank that has a gas stain that I tried some rubbing compound on and it doesn't take a lot of effort to go through the paint and into the silver primer. While I have a flake orange paint kit from dondirtbiker, that is for the K3 replica I'm making.
These pieces I had to get as they were in very good shape and I'd like to try to bring 'em back alive.
And as an aside I still haven't heard from my painter on the K2 Candy Gold application yet. I will post pictures when I get them back - three weeks now.........
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
Re: Faded paint restore?
« Reply #1 on: March 11, 2006, 05:51:04 AM »
Paint the bike black and be done with it !  ;D
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: March 11, 2006, 06:19:34 AM »
Once a candy starts to fade, about the only thing you can do is keep it from getting any worse.  In order to restore a finish you have to remove the outer damaged layer, but with candy finishes, removing any part of the outer layer will affect the color of that area by letting more of the base color show through.
« Reply #3 on: March 11, 2006, 10:16:42 AM »
The sun bleaches and destroys the pigments that reflect the color you see.  I believe it is the UV wavelength that breaks up the color and changes it's reflective properties.  It is destruction on the molecular level and I know of no existing technology, technique, or practice that can reverse the molecular change.
The candy colors were made by tinting clear with small amounts of color pigment.  Then repeating these coats with successive layers of tinted clear until there is enough shading and darkening to yield the desired color.  There may or may not be a true clearcoat as a final layer.
Some metalflakes are done the same way; with tinted clear (candy) layers over the metalflake base.
The fading is the result of the pigment choice that was used when the paint was applied and sunlight.  There are modern pigments today that resist the sun's damaging effects.  But, there are no techniques available today the allow you to replace only the existing damaged pigments with the new ones without repainting the subject.
You can over-paint, or strip and paint.
Maybe you can experiment with dyes.  But, I don't see how you could get the "depth" appearance of the original finish, as the original finish is not permeable, except for light.
Hmm, maybe a laser technology could do it.  How much money do you have for development of the restorative technique?  A mil or two might do it.  Interested?
 ;D Cheers,
