Author Topic: drum brake light switch  (Read 930 times)
cbcoker
« on: March 10, 2006, 06:24:49 PM »
I have a 72 cb350f and it had drum brakes all around. the problem is that the brake light switch is missing. since, I believe, the 350f's came with disk I am not sure of where to even begin searching for this part. if in fact the original 350f's did come with drums up front, does anyone know of a part number. the switch is so small that I can't find another that will fit in its spot. i ordered a right hand assembly off of a 73 cb350f and it doesn't have a switch because its hydraulic. any advise it considered helpful, thanks...s
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
Re: drum brake light switch
« Reply #1 on: March 10, 2006, 06:38:22 PM »
If I'm not mistaken you are referring to the Little spring/rubber widget on the brake lever mount on the Handel bar.
When I started my 72CL350 restoration the front brake handel did not light up the rear light. Having mucked around with it over the winter I saw that the rubber pin with spring was broken off. I used another one from a spare bike but have not started bike yet so I don't know if I sorted it out yet.
Could a CL350 switch work?
I have no experience with the front drums until now, but that's my thought on the problem.
I can take a photo if it helps at all.
lefty
« Reply #2 on: March 11, 2006, 08:46:54 AM »
look for a magura lever perch w/built in drum brake switch in thier off-road catalog or on-line-lefty
lefty
« Reply #3 on: March 11, 2006, 08:47:42 AM »
oh-dennis kirk-lefty
cbcoker
« Reply #4 on: March 11, 2006, 09:51:23 AM »
thanks, I check into that but need to get the bike running first. but I am always looking for answers to future problems...thanks again lefty...sean
