Author Topic: Sticky gearbox  (Read 1546 times)
Offline lassenc
Sticky gearbox
« on: March 11, 2006, 01:00:58 PM »
Within the last 500km I've done, my gearbox seem to have become more sticky.
I'm running 10/40w oil, non-synthetic.
Sometimes my gearshiftlever sticks a bit when I've gotten it down in first gear.
What should I do? Change the shifter seal and oil as a start?
« Last Edit: March 11, 2006, 01:02:31 PM by lassenc »
How exactly do you teach abstinence though?
It's like beating a dead cow, it's fun, but it doens't really get you anywhere.
Re: Sticky gearbox
« Reply #1 on: March 11, 2006, 02:23:40 PM »
The shifter seal just keeps oil in the bike.  If it leaks, replace it.  It won't change how the transmission shifts.
Change the oil is a good plan.  10/40 is fine.  Use an oil that is blended with an additive package designed for motorcycles, not autos.  A dragging wet clutch preloads the transmision gears, making the shift process less than free moving.
You should check your clutch adjustment, as well.
Offline lassenc
Re: Sticky gearbox
« Reply #2 on: March 11, 2006, 02:48:51 PM »
Clutch is welltuned, I'll change the oil then :)
supersport_CB400F
Re: Sticky gearbox
« Reply #3 on: March 11, 2006, 03:14:41 PM »
The engine is getting hot…..sort your pipes out also  ;)
Offline Magpie
Re: Sticky gearbox
« Reply #4 on: March 12, 2006, 09:08:37 AM »
I found this article in the tech library when trying to fix an noisy clutch, crunchy shifting and hard to find neutral. It helped mine, may be good for yours. A good read if nothing else.
http://sohc4.us/node/44
Cliff
cd811
Re: Sticky gearbox
« Reply #5 on: March 12, 2006, 10:55:55 AM »
thanks magpie...good article...helll I just threw my plates in...time to go back to the shop ;D
