Author Topic: Results of highway run... HOT  (Read 1576 times)
Offline beaniam
« on: October 28, 2010, 09:54:38 AM »
Took my recently almost finished 78 750k on about a 40 mile run, half freeway miles today.
Does great regular riding and cruising however after I got off the freeway from my 20 miles of about 75mph running and stopped at the red light I noticed it was pretty hot.  I don't have an IR thermometer but to the point of smoke coming out of the valve cover breather and 0 oil pressure at idle (was holding about 30 on the freeway as I kept checking it).  Blip the throttle to about 1500 - 2000 and oil pressure went to about 20.  Today is only about 70 degrees out.
Once I continued cruising regular driving and it cooled off it was fine.  Oil pressure went back up to a safe point.  I've got 4-1 and pods with 115 jets.  I have an aux oil cooler that I never put back on after pulling the engine a month ago.  My plan is to put 120 jets in, the aux oil cooler back on, drain the 10w40 oil and replace it with 20w50.  At regular riding idle I've got about 30psi oil pressure.  Cold idle 60.  Anything else I should try, or go with this plan first and see how it does?
« Last Edit: October 28, 2010, 10:00:19 AM by beaniam »
Offline Cuts Crooked
  • Cowboy Biker
Re: Results of highway run... HOT
« Reply #1 on: October 28, 2010, 10:05:07 AM »
I'm running 120 mains on my 78K with pods, but I've got a stock exhaust system. You might want to consider going to 125s with that aftermarket exhaust you are running on that thing.
What do your spark plugs tell you?
« Last Edit: October 28, 2010, 10:28:47 AM by Cuts Crooked »
Cuts Crooked
CB 750K8
Old Bikes 'n Old Guns are my first two loves :)
Offline beaniam
« Reply #2 on: October 28, 2010, 10:11:19 AM »
Wasn't able to do a plug chop but looking at them now they are dark tan, slightly sooty.  But that's after some 35mph putting around.  I'm thinking it really doesn't like the 115's at those highway rpms.  I'll order some 125's and see how it does on the 120's.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #3 on: October 28, 2010, 10:57:29 AM »
A few of us here with 78s have found success with 138mains with your set up.
Offline beaniam
« Reply #4 on: October 28, 2010, 11:01:19 AM »
Wow that big?  I'll do some experimenting and drilling with my old extra mains
Offline beaniam
« Reply #5 on: October 28, 2010, 06:34:46 PM »
I'm curious what sort of mpg do you get running 138's?
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #6 on: October 28, 2010, 11:24:02 PM »
I think we had it figured to 45-50mpg on the trip to Sturgis.....and who really cares ;D  It's a bike, I was never interested until my riding partners said something about no gas stations for a few hundred miles coming up, so we kept track on the next tank.
Offline beaniam
« Reply #7 on: October 29, 2010, 06:12:43 AM »
That's better than I get now.  I'll drill out my old set to 138 and see how it goes.
