Author Topic: Dyna coil firing order  (Read 11597 times)
Offline COMB2
« on: October 28, 2010, 08:33:11 pm »
Am I missing something here? On the dyna coils dc1-1 which spot does the plug wires go to? Got 1&4 on the left  and 2&4 on the right but what cylinder goes to what spot on the coil?
Online scottly
Re: Dyna coil firing order
« Reply #1 on: October 28, 2010, 09:34:30 pm »
The "firing order" is exactly the same as with the stock coils. Not meaning to be rude, but you are asking a VERY basic question on an advanced forum, kind of like walking into an advanced astronomy class and asking "why is the sky blue?". ;)
  • Moderator
« Reply #2 on: October 29, 2010, 01:19:14 am »
Yes, the sky IS blue and the question IS in the wrong forum but what he heck.
COMB2 might be a very atractive young lady (no information available) and you've just blown your chance of a date scottly. ;D ;D ;D
Like scottly says, it's the same as the standard set up.
Sam. ;)
Offline COMB2
« Reply #3 on: October 29, 2010, 03:56:45 am »
Can someone move the question to the dumb area? I want to make sure I put the correct plug wire the the correct cylinder. Like on the left coil how do I know what plug outlet fires at 1 and which at 4? Do you just got to test to find out?
Offline mick7504
« Reply #4 on: October 29, 2010, 05:03:39 am »
Here is the clue.
Have look at wiring colour codes to each coil.
It is straight forward and self explanatory.
You can do it.
http://www.hondachopper.com/garage/cb750k1_wiring_diagram/cb750k1_wiring_diagram.html
If I was you
I'd be worried about me.
Offline Bill/BentON Racing
    • BentON Racing
« Reply #5 on: October 29, 2010, 05:22:15 am »
When 1 fires so does 4.Same for 2&3.That's why you have 2 coils ,not 4.Read up as suggested.1&4 wire interchangeable as is 2&3.Good Luck,Bill..Firing order a different thing.
BentON Racing Website
BentON Racing Facebook
Offline bear
  • Leeton in Australia
« Reply #6 on: October 29, 2010, 05:40:35 am »
Jeez you blokes are hard.
1&4 fire together, 2&3 fire together it doesn't matter which lead goes to which cylinder as long as you have 1&4 hooked up to 1 coil & 2&3 hooked to the other.
I assume the wiring is not colour coded so if it doesn't fire it is probably 180 deg. out.
Just swap the power wires to the coils, no harm done.
Brian
« Last Edit: October 29, 2010, 05:44:20 am by bear »
Offline lordmoonpie
    • Moonpie
« Reply #7 on: October 29, 2010, 05:42:46 am »
+1 on what Bill says. Each coil has two plug outlets - both fire at the same time so you connect one coil to  pots 1 and 4 and one coil to pots 2 and 3. Bingo.
Think the rest of you guys are a touch harsh perhaps? Maybe got out of bed too early? Just remember we were all noobs with no experience once and there's no such thing as a dumb question just dumb people who don't ask the questions they want to....  ;)
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline lordmoonpie
    • Moonpie
« Reply #8 on: October 29, 2010, 05:45:08 am »
Oh and for the record, I'm installing my first Dyna ignition now and it is getting right on my tits where it says in the instructions "connect to the same wire as the standard coils connected to" or some such guff - if you never had standard coils or a standard loom on the bike this is about as much help as a hole in the head!
There now - I've set it up, just wait a few weeks and I'll be asking my own dumb ass questions  ;D
1994 Ducati 888 SP5
Offline bear
« Reply #9 on: October 29, 2010, 05:48:11 am »
Hey Mr Pie,
How goes the Hy-Vo motor?
HP@RW?
Brian
Offline lordmoonpie
    • Moonpie
« Reply #10 on: October 29, 2010, 05:56:53 am »
Hey Mr Pie,
HP@RW?
Brian
Shhhh Brian! My original ignition setup was,errr pants so have switched to a Dyna 2000 courtesy of the most wonderful Mr Rieck. Now all I have to do is fit it and get it runnign again, then off to the dyno for a bit of carb tweaking and a HP graph I hope....problemn is, not sure whether to mount the 1 and 4 coil on the left or the right side of the frame  ???
1994 Ducati 888 SP5
Offline mick7504
« Reply #11 on: October 29, 2010, 05:57:19 am »
After a couple of more beers mate we'll be all nice and loosened up.  ;)
If I was you
  • Moderator
« Reply #12 on: October 29, 2010, 06:17:46 am »
Talk about beer ;D I just went to the local supermarket to do my months shoping.
A 24 pack of 440ml cans of Boddingtons normaly costs £14.48, today it was £10 but you were restricted to 3 cases. I did my shop, loaded the car and went in for another three cases. ;D ;D ;D
Sam. ;)
« Reply #13 on: October 29, 2010, 06:25:01 am »
The party's at Sams, woo-hoo.
Offline COMB2
« Reply #14 on: October 29, 2010, 06:42:40 am »
Ok that is what I wad looking for maybe I worded it wrong. Thanks
Offline mick7504
« Reply #15 on: October 29, 2010, 06:58:39 am »
A 24 pack of 440ml cans of Boddingtons normaly costs £14.48, today it was £10 but you were restricted to 3 cases. I did my shop, loaded the car and went in for another three cases. ;D ;D ;Dget our drivers licen
Sam. ;)
We'll be there to help out with that carton Sam.  ;D
We're paying about the equivalent of 18 Quid for light beer when it's on special and about 25 Quid for the the good stuff.
We have to get our drivers license scanned now here in Darwin to see if your on the banned drinkers list.
Still working hard at that.  ;D
Seriously, there's some boofheads that can't handle it and it's big trouble.
That Mexican Corona is around about 30 Quid for a carton of 24 but after 6 of them you're full of knowledge.  ;D
If I was you
« Reply #16 on: October 29, 2010, 08:11:08 am »
Sam. ;)
That'll last about a week. ;)
  • Moderator
« Reply #17 on: October 29, 2010, 11:34:13 am »
That's right Murphy,...one week into 2011. :D :D :D
I've cut right down. 8)
Sam. ;)
Offline bear
« Reply #18 on: October 29, 2010, 04:07:35 pm »
Come on fellas don't forget to support your local publicans.
The way things are going I'm going to be living on sayo biscuts and Vegemite.
Brian
Online scottly
« Reply #19 on: October 29, 2010, 05:33:19 pm »
Hey Mr Pie,
HP@RW?
Brian
I believe the 1-4 coil is normally mounted on the left side, so I would do it that way to avoid confusion.
« Reply #20 on: October 29, 2010, 05:43:25 pm »
Brian
And in the dark mate with no insulation...... ;)
Online scottly
« Reply #21 on: October 29, 2010, 06:22:38 pm »
Sorry if I came off as harsh. It was not a dumb question, you just asked in the wrong place, and at the wrong time, as someone had just posted a question about spark plugs on a thread about exotic wheels...
« Reply #22 on: October 29, 2010, 06:33:53 pm »
Yeah.....saw that.......wonderful thing drugs...... :P
Online scottly
« Reply #23 on: October 29, 2010, 06:45:15 pm »
Now for a dumb question, also on the wrong forum...
Just what the hell is Vegemite??? I've heard of it, but what is it? And what are sayo biscuts?
« Reply #24 on: October 29, 2010, 07:01:44 pm »
Sao biscuits are a type of puffy water cracker usually eaten with tomato or cucumber or something like that
Vegemite is a yeast extract that has a dark meaty type flavour, it should only be spread lightly as it has a strong taste, i sometimes use it as a beef stock alternative when cooking stews and the like.
http://www.arnotts.com.au/our-products/products/crackers-and-crispbreads.aspx
http://www.howdoyoulikeyourvegemite.com.au/?go=profiles
