Author Topic: Drag bars and modern master cylinder tight fit!!  (Read 1813 times)
Offline going4speed
« on: October 29, 2010, 06:16:55 PM »
I just installed drag bars on the cb750k with the cb900 master cylinder.  I then installed my brake line and I cannot get this setup to work.
I have the brake hose coming out of the master cylinder and pointing toward the back of the bike and then i makes a dramatic turn down to the junction 3 way.  When I turn the handle bars the brake hose makes contact with the tank.
How are other people running this setup?
« Last Edit: October 29, 2010, 06:25:14 PM by going4speed »
Offline pidaster
Re: Drag bars and modern master cylinder tight fit!!
« Reply #1 on: October 30, 2010, 06:05:24 AM »
Maybe a different brake line that has a curved fitting or use some risers for the bars.
'76 CB750K
'82 CB450SC
'06 Vulcan 900
'98 Kawasaki Police 1000
'73 CB350 twin
Offline pidaster
« Reply #2 on: October 30, 2010, 06:05:45 AM »
For brake lines, check out slingshotcycles.com.
'76 CB750K
'82 CB450SC
'06 Vulcan 900
'73 CB350 twin
Offline steam-powered man
  • Not the eggman, Not the walrus, I am the
  • Where are you going? I was going to make Espresso
« Reply #3 on: October 30, 2010, 06:15:21 AM »
would bar risers help?
searching for a dr350se
Offline going4speed
« Reply #4 on: October 30, 2010, 06:34:14 AM »
Bar risers would likely help but I was trying to go stock.
The brake lines I have are from sling-shot and they are fantastic quality.
Just need a new grommet for the lower.
Offline wildcatmahone
  • Poseur
« Reply #5 on: October 30, 2010, 07:23:24 AM »
Hey just drill the stem nut and route the line down through the steering stem.
Offline Really?
« Reply #6 on: October 30, 2010, 10:52:08 AM »
Does Z1 have a 90 degree bend that would go down?  Can you not route the hose forward instead?
I have mommas going forward and then under the tach.
« Last Edit: October 30, 2010, 10:54:00 AM by TipperT »
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline going4speed
« Reply #7 on: October 30, 2010, 08:08:59 PM »
mommas?
Offline Really?
« Reply #8 on: October 31, 2010, 10:08:21 AM »
I should have probably added one more word to that, lol.  Momma's bike.
iPhone 3G pic with garage door closed, so its a bit grainy.
