Author Topic: replacing clutch plates  (Read 2169 times)
Offline rab1dwolf
« on: March 12, 2006, 02:51:04 PM »
Well I've decided to replace the clutch plates on my '82 650sc.  Only one little problem...theres this weird locknut in there that my book says needs a specialty tool to remove.
Its not listed on the parts companys i use and have a feeling its probably bloody expensive.
What do you guys use to get this off of there? any suggestions would be good.
oh also put the 4-1 mac exhaust on and its BEAUTIFUL my god i love it
edit: finally managed to find other threads on it...never mind:)
« Last Edit: March 12, 2006, 03:42:32 PM by rab1dwolf »
1982 cb650sc nighthawk.  the work never stops.
Offline m00ntan
Re: replacing clutch plates
« Reply #1 on: September 11, 2006, 07:39:52 PM »
Could you share, please?
CB750K4
CB550K1
CM400C
Offline rab1dwolf
« Reply #2 on: September 11, 2006, 08:56:41 PM »
well there is actually a little tool for it.
I ended up buying one that was too small so i dremeled it to fit.
but they are out there if you go to a good honda shop they should be able to find it.  hint: make sure to measure your nut.
Offline scunny
  • don't call me expert
« Reply #3 on: September 12, 2006, 12:15:09 AM »
I made my own from a 15/16 socket ( only because I had 2 of them), used a thin bladed 4 inch grinder, took bugger all time and worked a treat. I do believe these are available to buy eg Z1 enterprises, but the time frame and shipping made me become a tool killer. by the way,this was on my 650 motor so you should be sweet, you may even be able to use an inch socket
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline Buber
  • A bit of spanner spinner, but definitely not a
  • #820 on old mailing list.... :)
    • Mountain Chalets in Polands
« Reply #4 on: September 12, 2006, 05:51:41 AM »
There is a special wrench, but it's easy to make it yourself. I just dremeled bits off a 24 size socket wrench and it works.
Don't bother buying special tool for that. Aha, and you will need to block the drivetrain to unscrew it. For me a block of wood at the rear wheel did it....
Regards!
Welcome to my mountains!
Mountain Chalets
Offline dusterdude
« Reply #5 on: September 12, 2006, 10:22:38 AM »
which nut should i measure? ;D
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline scunny
« Reply #6 on: September 12, 2006, 11:39:44 AM »
the left nut is usually the largest Duster ;D
            VTR1000F3
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
« Reply #7 on: September 12, 2006, 12:37:01 PM »
...unless you are left handed.
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Offline dusterdude
« Reply #8 on: September 12, 2006, 01:31:32 PM »
ill check it later
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline hymodyne
« Reply #9 on: September 12, 2006, 03:20:47 PM »
is this tool necessary a 500/550 ? "72-76?
who sells clutch plates for the 500K? (besides david silver spares). I'm also looking for new valves guides and springs for the same engine
hym
Offline Ernie
  • Dead again,could I get a
« Reply #10 on: September 12, 2006, 03:26:22 PM »
this might be what your looking for http://www.z1enterprises.com/detail.aspx?ID=2161  ;)
Its all happening !
my 1978 CB550K.......>>>
http://gallery.sohc4.net/main.php?g2_itemId=4440
Offline m00ntan
« Reply #11 on: September 12, 2006, 04:45:36 PM »
Thank you, I followed the Haynes method and bent one of those toy ten pegs down two sides of a 1-1/16" socket, chocked the wheel with a 2x2, held the brake and put it in fifth gear.  Worked like a charm.  CB750K4.
CB750K4
CB550K1
CM400C
Offline m00ntan
« Reply #12 on: September 12, 2006, 05:29:48 PM »
BTW:  Are clutch plates supposed to resemble something from a BBQ grill?
CB750K4
CB550K1
CM400C
Offline burmashave
  • Forum Immoderator
    • burmashave.net
« Reply #13 on: September 12, 2006, 07:26:23 PM »
For what it's worth, I generally use a hammer and drift for custom nuts.  Just put the drift near a corner of the nut and tap.  Sears has an inexpensive brass drift set, and I use them often when I need to bang on something metal.
Quote from: SOHC Digger, RIP
'77 CB750k
