Author Topic: car tire and rim  (Read 1731 times)
Tank
car tire and rim
« on: October 31, 2010, 06:21:05 PM »
hey im looking to mount a sprocket and rotor to a car tire and rim does any one have any advice on how to do this (what rim is best, bolting or welding) ive seen a few pictures and a few first hand but the first hand ones were a honda drum welded into a rim id like to use a rotor if passable. id also like to use a pretty wide rim and tire. thank you in advance
cheers Audy
Offline Gordon
  • 750K1, 550K2
Re: car tire and rim
« Reply #1 on: October 31, 2010, 08:06:19 PM »
What car is this for?
Tank
« Reply #2 on: November 02, 2010, 08:49:05 AM »
my sohc 750 chopper project
Offline Ricky_Racer
« Reply #3 on: November 02, 2010, 03:25:10 PM »
Tank, most auto rims (including spoked versions) are offset to the inside. 15" rims used to be used on early chops but I haven't seen any of these wheels available for a long time. Perhaps early (1930's) Ford are centered.
You'd probably be better off asking at www.hondachopper.com or at the Jockey Journal. By all means, let us know what you find out.
FLASH! Check the Honda Shadow Aero 1100!   ;D  RR
« Last Edit: November 02, 2010, 03:54:36 PM by Ricky_Racer »
Offline donny
« Reply #4 on: November 02, 2010, 05:15:37 PM »
2007 Husqvarna self propelled lawn mower    1976F    1971K    1974K      1990 FXRS-SP
Offline lone*X
« Reply #5 on: November 02, 2010, 07:02:46 PM »
How about this hub.  Build your own.
http://www.freepatentsonline.com/7437812.pdf
Remember, you also have to mount a brake in addition to the sprocket or belt.
« Last Edit: November 02, 2010, 07:06:42 PM by lone*X »
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
« Reply #6 on: November 02, 2010, 07:21:01 PM »
 ET wheels has a cool 10 spoke mag that is real reasonable and 15 inch.
 I would be interested in doing the machining to make one work on a 750.. think I am not too far away from you. Radir make a front in an 18 that is similar but I think 12 spoke and a lot more money.
 The ET would look good on a chopper, could maybe run brake & sprocket on one side.
« Last Edit: November 02, 2010, 07:22:58 PM by 754 »
Offline bradweingartner
  • 74 CB 550 x2
« Reply #7 on: November 02, 2010, 08:44:26 PM »
Maybe it's time do a single sided swingarm/solid rear end?
That way you can use a stub shaft and unit bearing from a car. Use a lightened non-vented auto rotor, and mount the sprocket on the body of the CV housing.
Offline ridered67
« Reply #8 on: November 03, 2010, 04:50:49 AM »
An offset car rim should work ok.  just use spacers to center it in the swringarm, put your sprocket on the "flat" side of the rim and then set your caliper and rotor "inside" of the recessed side of the rim.  Actually a rim with a large offset may work better as you would be able to completely bury your caliper and rotor.  Check out Cragar rims.  They make a steel series of rims called Soft Eights in a large variety of sizes.  They are just basic steel wheels but they are cheap and you could experiment with them.
I would bolt your sprocket and caliper to a solid piece of round metal welded to the rim.
Good luck figuring out wheel bearings!
« Reply #9 on: November 03, 2010, 06:08:32 AM »
 Monocoque Racing wheels come in 16 inch and are halves bolted together, any offset you want. I  built a wheel in the 80s uding their wheel halves.
Offline swellguy
  • An electric cattle prod is a
  • Divorce is so expensive because it's worth it.
    • http://ksphotos.com
« Reply #10 on: November 04, 2010, 01:05:22 AM »
if you googled "swedish chopper" you'd find lots of examples.
This project started in confusion and will end in disarray.
http://forums.sohc4.net/index.php?topic=76471.msg852227#msg852227
« Reply #11 on: November 04, 2010, 09:50:07 AM »
A lot of drag bikes use "car tires" check dragbike.com to see how they are doing it!
Offline buttcan
« Reply #12 on: December 08, 2010, 08:41:29 PM »
Ask Tommy. He'll know. www.tommy@lowridersbysummers.com
Inevitability: The realization that no matter how hard you try you'll never be as cool as a bull riding monkey...
