Author Topic: Sandcast #97 restoration  (Read 202939 times)
Offline MoMo
  • Ride like you're invisible
Re: Sandcast #97 restoration
« Reply #825 on: February 03, 2019, 12:28:03 PM »
Exquisite, the bike that is...Larry
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #826 on: February 03, 2019, 02:45:29 PM »
You braved the Artic conditions? That’s dedication!
I would love to have been there
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #827 on: February 03, 2019, 08:50:47 PM »
Nice. My buddy Brady Walker has been putting together the AHRMA displays at the IMS shows.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #828 on: February 06, 2019, 09:52:18 AM »
I took some time this weekend to go the Minneapolis Motorcycle Show.
I answered a lot of questions. It’s amazing how many people have at least heard of a sandcast.
Cool. The Chicago show is this weekend, I am looking forward to it. Unfortunately I will have to drive. Back in 2008 or so it was in the low 60's and I was actually able to ride my FJ1200 and MC parking was free.
Offline Tews19
  • I am no
« Reply #829 on: February 07, 2019, 07:55:39 PM »
Danny, any info about this event? Is it saturday and sunday?
1970 Honda CB750 survivor.
Offline Bankerdanny
« Reply #830 on: February 07, 2019, 08:00:23 PM »
Yes. It's in Rosemont a couple miles from O'Hare Airpotrt. I go most years.
http://www.motorcycleshows.com/city/chicago-il-0
Offline wi.st.rod
« Reply #831 on: February 08, 2019, 07:53:37 AM »
Looking forward to seeing this progress.
Offline markb
  • When I finish my current project I might be a
« Reply #832 on: March 08, 2019, 07:57:50 AM »
My latest project is working on restoring brake disks. For now I have a NOS K1 disk until I can replace it with a correct restored one. I made a special tool for grinding the disks on a surface grinder.
I’m still experimenting but here’s where I am so far. Before…
…and after.
If you’re interested here is a thread that shows a little more detail about what I’m doing starting at reply #45.
http://forums.sohc4.net/index.php/topic,175601.25.html
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
« Reply #833 on: March 08, 2019, 09:09:23 AM »
From what your tool looks like, your grinding not only takes out wear but can also address any warping.  Can you also "thin" the rotor surface to lighten the disc?
Offline markb
« Reply #834 on: March 08, 2019, 02:53:47 PM »
I think that's correct. The outside of the disk is now parallel with the mounting surface on the hub. When I flip it over to do the inside, the disk will be sitting right on the turntable so both side will be parallel to each other. I haven't done that yet. I'm going to wait until I get a courser wheel.
The wheel is thinner after grinding but not much. I only took about 0.005" of it. It would take a while to lighten it with this method.
Offline Can550
« Reply #835 on: March 08, 2019, 05:17:10 PM »
Like it a lot
« Reply #836 on: March 12, 2019, 06:44:01 AM »
Looks great!
Offline Godffery
  • Godffery's Garage
« Reply #837 on: March 12, 2019, 07:41:59 AM »
I provide a drilled & Thinned Rotor service if your looking for lighter.  (Roughly half the weight of stock)
https://godfferysgarage.com/wp-content/uploads/28336422_332195967288423_6739062907242179043_o.jpg
Offline markb
« Reply #838 on: May 20, 2019, 07:07:40 AM »
I’ve finally finished restoring the brake rotor. I think it turned out pretty good. The masking was a challenge because of the spokes and the rivets on the inside.
I tried different tapes and trimming with an exacto knife but couldn’t get decent results. I finally made a tool that has a hole the same size as the diameter of the rivet with a flat land around it.
Then I drilled the same size hole on the other end and machined an angle to make it sharp.
After trying masking tape, vinyl tape and some others I found that the tape that worked the best was duct tape. The flat end of the tool formed the tape around the rivet head.
Then the sharp end trimmed the tape perfectly.
Here’s a pic of the finished product on the outside…
…and the inside. Now #97 finally has a correct rotor!
« Reply #839 on: May 20, 2019, 08:59:20 AM »
Nice detail solution.
Offline markb
« Reply #840 on: June 01, 2019, 06:55:27 AM »
IT RUNS!!  ;D I took #97 out for a short test ride last night. It’s tuned up, carbs synced and sounds great. I only went about a mile. Ran it up to 60 and through all 5 gears. Everything works. I have about a 15 second video (28MB) of it running that I would like to post but not sure how to do that. Can anyone point me in the right direction?
Offline fastbroshi
  • Puppet
« Reply #841 on: June 01, 2019, 07:21:52 AM »
Youtube might be the easiest way, or maybe Imgur.  Not sure if you can upload vids there though.
Just call me Timmaaaaay!!!
Offline markb
« Reply #842 on: June 04, 2019, 06:21:31 AM »
I think I got it to work. Click on the link below. It's a short video. I'll try to post a longer one later. But at least it proves it runs.  ;D
« Last Edit: June 04, 2019, 06:23:24 AM by markb »
Offline Tews19
  • I am no
« Reply #843 on: June 10, 2019, 08:07:34 PM »
Excellent work! She sounds very smooth!
Offline fastbroshi
  • Puppet
« Reply #844 on: June 10, 2019, 09:26:31 PM »
I must be getting old, because wow, that sounds good even with a quiet exhaust.
Offline markb
« Reply #845 on: June 11, 2019, 12:29:29 PM »
It's not as quiet as it sounds on my phone. I plan to post another video showing it rolling down the road and I'll get a good shot from behind.  ;)
Offline markb
« Reply #846 on: June 16, 2019, 12:27:09 PM »
I decided to take #97 to a show (one of the reasons I wanted to make sure it runs).
It was a pretty big local show. There was close to 200 bikes there. After I saw the picture on the flyer I knew I had to bring mine. Both the local chapter of the AMCA and the local chapter of the VJMC were there.
Here’s a pic of it on display. It was nice that they put it on a stand right near the entrance. It definitely got a lot of attention. I was hoping it would do well.
It did better than I could have hoped for. The local VJMC has cool trophies, large, nicely polished and chromed metric wrenches. I got one for Best In Show.  :)
The AMCA was also judging and I got the Junior First Award (first time entered) with 100 points!  :o  :D They did comment about the chrome finish on the taillight bracket but didn’t deduct any points. Maybe it helped that in was the 50th anniversary for the bike (to the month) and the only sandcast there.
The icing on the cake though was the editor of the AMCA magazine was there and took pictures of #97.  ;D He said they will be in the September/October edition. So like I said I couldn’t have asked for more. I feel very lucky and grateful for all the help I’ve gotten from the SOOC and SOHC4 sites. Thank you guys for all your help and support.
So I got the bike home and drained the gas tank, petcock bowl and carburetor bowls. I blew air down the fuel lines (lightly) with the drain screws loose and cranked the engine over for about 10 seconds (it ran for about 2 seconds) to try to suck any last gas out of the carbs. I don’t even know if that does anything, it just seemed like a good idea. Short of actually removing carbs and cleaning them is there anything else I should do? Should I actual pull them or not? It might be a while before the bike runs again. Although after the success this weekend I am toying with the idea of going to Barber.  ;)
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #847 on: June 16, 2019, 08:09:43 PM »
Wow, the #97 legend continues!
What an inspiration, I’m wondering where I could get my hands on a sandcast now, dangerous.
1973 CB 750 K3
« Reply #848 on: June 17, 2019, 10:02:01 AM »
Congratulations! The bike looks amazing.
Offline markb
« Reply #849 on: June 18, 2019, 06:10:44 AM »
Thanks guys.
Anyone have any comments about my storage preparation? I was also thinking about fogging the cylinders, maybe changing the oil, etc.
