Author Topic: Rear Master Cylinder  (Read 1060 times)
Offline MattFreeman
  • What Have I Done?
« on: November 02, 2010, 11:59:06 AM »
Does anyone know if a modern master cylinder will push the rear caliper on '76 cb750F1?
Re: Rear Master Cylinder
« Reply #1 on: November 02, 2010, 12:04:26 PM »
It should but I can't say for sure. That double piston setup is pretty sensitive and even if a modern master weren't as powerful it may not be a bad thing bad not locking up as easily.
WilliamA
« Reply #2 on: November 03, 2010, 04:49:29 AM »
If the bore is the same it should only be a matter of matching the the stroke to your existing one.
Offline MattFreeman
  • What Have I Done?
« Reply #3 on: February 01, 2011, 03:17:49 PM »
So does anyone know the actual bore and stroke for a F1 master cylinder?
And have a good source or way of finding this info for other master cylinders.
Has anyone used one that works correctly?
Offline KRONUS0100
  • MAD MATT THE MANIAC
« Reply #4 on: February 01, 2011, 03:49:38 PM »
hey Matt, look for my post about this...........it under the Title.....REPLACEMENT CB750F rear Master Cylinder.  i used one off a 2006 gsxr600.  2 little brackets to manufacture, and a bushing for the top bolt.  it works.
MATT
Offline MattFreeman
  • What Have I Done?
« Reply #5 on: February 02, 2011, 10:54:33 AM »
Thanks, I saw that.
Did you measure anything, or did you get lucky?
Offline KRONUS0100
« Reply #6 on: February 02, 2011, 12:15:05 PM »
mostly got lucky...but i did the research before I jumped on the rear master from the gsxr.  I had tried for about 2 months to try and fit the one of my 81 GS1100E...just to big all the way around.  I am Also member of the GS Forums, and talked to a few peeps there.  When I found the one on ebay, I emailed the kid as to why he wanted so little.  He had bought the bike back from the insurance company and was parting out the good stuff....less than 8k miles...so almost new part to my door under 1500 bucks total....I was actually surprised that it fit as well as it did.  I used 2 pieces of scrap steel to make the mount brackets, and washers to space it out from inside of frame.  When you spin the wheel real good by hand and tap the pedal...the wheel stops.....no slow stopping.  This master is designed to stop a 600 pound bike from roughly 160mph...and has 15mm bore....so it should work real well...so far I am impressed....hope to ride the bike in the next month when winter storms go away.
MATT
Offline MattFreeman
  • What Have I Done?
« Reply #7 on: February 02, 2011, 12:55:50 PM »
Cool thanks. :)
Do you know the bore of the original Honda part?
Offline KRONUS0100
« Reply #8 on: February 02, 2011, 02:03:49 PM »
offhand I think the stock bore is 14?  not sure.
MATT
