Author Topic: Clutch stuck  (Read 5178 times)
Offline COMB2
Clutch stuck
« on: November 07, 2010, 04:22:40 PM »
Been doing a bike rebuild. Nothing internal on the motor though. The motor ran and clutch worked before I started the project. I drained the oil from the motor due to removing it for the frame. It has been sitting dry for 5 months. Put oil in it today and tried disengaging the clutch but it will not at all. The bike moves like normal in neutral but I gear it will not disengage. I even disconnected the cable and pulled the clutch arm up by hand to make sure I was getting full range to disengage it and still stuck. I read some other post and seen some say that the plates can get stuck together.
Do you think with it setting dry for 5 months the plates need to soak up some oil to break free?
Re: Clutch stuck
« Reply #1 on: November 07, 2010, 10:58:49 PM »
there just stuck,itll break free when you start it and clunk it in gear.
Re: Clutch stuck
« Reply #2 on: November 07, 2010, 11:18:20 PM »
Before you just stuff it in gear, they sometimes will disengage by revving it a few times with the clutch pulled in.
Offline CB750faces.com (Lecram)
  • CB750faces.com
    • Buy High Quality Honda gauge parts online!
Re: Clutch stuck
« Reply #3 on: November 07, 2010, 11:22:05 PM »
I shouldn't do that. You need a lot of force to loose the plates, even when the plates are stuck together a little. It could damage the engine.
You should do better to open the clutch and separate the clutch plates.
Re: Clutch stuck
« Reply #4 on: November 07, 2010, 11:57:03 PM »
mines stuck every time i ride it,i live on a steep hill so i coast off and select second,with no clutch,i get to top with no clutch then i pull it in and rev it to brake it free.if i try to engage first itll stall.every time when its cold.
  • CB750faces.com
Re: Clutch stuck
« Reply #5 on: November 08, 2010, 01:58:45 AM »
That's different from standing dry for 5 months (or 23 years for my CB750).
I have tried to do it in your way, but the clutch stayed stuck. And I didn't had the courage to do that again.
Offline COMB2
Re: Clutch stuck
« Reply #6 on: November 08, 2010, 02:49:10 AM »
Thanks guys. Now I just need to figure out the timing so I can get it to run and break it loose. Any how to on the timing with a dyna s ? I tried static timing but guess I'm not doing it right
Offline 333
  • Time for change
Re: Clutch stuck
« Reply #7 on: November 08, 2010, 06:29:08 AM »
I had a 125 that did the same thing.  What I did was to put it in gear with the motor off and the clutch pulled in and rock the bike back and forth until the clutch let go.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline DavePhipps
  • Reading the entire Hi-Perf forum
    • Hillside Technology
Re: Clutch stuck
« Reply #8 on: November 08, 2010, 11:44:08 AM »
what bike do you have? 2 other memeber have had this lately with a CB500. I'm one of them. Ours turned out to be a broken lifter rod.
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Re: Clutch stuck
« Reply #9 on: November 08, 2010, 11:52:46 AM »
its a 500,its done this since ever,new clutch and friction discs,new adjuster,the rod is fine,most of my dirt bikes have done the same thing.get used to it.rocking it would work but i can do it smoothly down my hill.
« Last Edit: November 08, 2010, 11:54:35 AM by dave500 »
Offline 333
  • Time for change
Re: Clutch stuck
« Reply #10 on: November 08, 2010, 04:21:42 PM »
At the risk of hijacking this into an oil thread, could the ultimate culprit be an oil not made for motorcycles?  It is the only substance that comes in contact with the friction plates.  Either that, or the carb float stuck, and gas flowed into a cylinder and past the rings, contaminating the oil, and gas is the damaging substance.
That having been said, let me tell you how I fixed the 125 I mentioned a couple posts back.  Someone gave me a 10 year old 1981 CB125S with 380 miles on it. The original buyer never went to DMV, so the "title" was a certificate of origin.  I did a carb overhaul, stuck a new battery in it, and upon starting, I found the stuck clutch.  I had been using Honda HP4 in all my bikes, but decided not to in this case until the motor got broke in(per Honda's recommendation).  I used the method I described earlier, but if the bike sat for a week, I'd have to do it again.  Once the bike had 600 miles on it, I switched to the HP4.  It maybe stuck one more time, and the issue disappeared.
Re: Clutch stuck
« Reply #11 on: November 08, 2010, 04:40:07 PM »
Wait a minute.  I thought the consensus of the forum was that Honda got all the engineering wrong for their bikes, and everything needs to be home engineered/altered/customized/"upgraded" to put things right.  Why on earth then, would you use oil that Honda recommended?
You must be one of those "purists" that's now popular to sneer at.   ;D
Offline COMB2
Re: Clutch stuck
« Reply #12 on: November 08, 2010, 07:08:16 PM »
Manual just said SAE10w-40 so I just got some regular old oil. That wrong ? It didn't say anything about bike oil. Did I mess up? What should I get?
I did get it broke loose today after some major rocking back and forth
Offline 333
  • Time for change
Re: Clutch stuck
« Reply #13 on: November 08, 2010, 08:15:02 PM »
No, you didn't mess up.  At least not for sure.  But if it reoccurs like it did with my 125, I'd try the Honda HP4, the version with Moly.  In recent years, they have made a version without the Moly, but originally was only available with it.
Let me take this opportunity to clarify when and on what bikes this oil should be used.  This oil should not be used on bikes with automatic transmissions or on any bike/scooter with a centrifugal wet(oil) clutch.  That is what the non Moly version is for.  And back in the day, Honda had a list of what bikes could use it, and the recommendation that the oil should only be used in engines that have been broken in, citing that the oil(with the Moly) lubricates so well, that new engines would not break in properly.
Re: Clutch stuck
« Reply #14 on: November 08, 2010, 09:34:28 PM »
i use atf in two stroke wet clutch gear boxes.,like dirt bikes.
Offline 333
  • Time for change
Re: Clutch stuck
« Reply #15 on: November 08, 2010, 09:50:30 PM »
How well did it shift?
Re: Clutch stuck
« Reply #16 on: November 08, 2010, 09:53:16 PM »
The issue is that the manual specified SAE 10w-40 with an SE rating.  Cars of the era also used that grade oil.  That particular grade w/rating is not widely available today, cars do NOT use it, and the Honda manuals aren't updated and distributed to all owners automatically.  Auto catalytic converters required a formulation change to auto oil.  For the most part, this makes many auto targeted oils unsuitable for motorcycle use.
The owner needs to be sure the oil purchased meets the actual requirements of the vehicle.  So, go by what the Honda dealer recommends/offers for use in their legacy machines, or become VERY educated about the formulation details of the oil selected for use.
Their are lots of oil threads with differing opinions, interspersed with brand loyalty, information, and misinformation about oil suitability for wet clutch operation.  Some of these threads can be found in this forum.   ;D
Re: Clutch stuck
« Reply #17 on: November 09, 2010, 02:19:59 AM »
triple three thats been in all my two strokes,they shift perfect.clutch no clutch,i always changed it every few long weekends,its cheap,came out cleanish during summer,winter we would cross creeks and it would show a bit cloudy,each to their own favourite oil or beer!
Offline pdxPope
  • Hit Shit, Hat Shat, Hut Shut,
Re: Clutch stuck
« Reply #18 on: November 09, 2010, 09:48:17 AM »
Lloyd........you made a funny!!
Progress, my man. Definite progress.  :D
-JP
The flowers say "Let's go shopping together..."
While the unicorn whispers "...for adult toys."
Offline paulmac
  • Keep the shiny side up.
Re: Clutch stuck
« Reply #19 on: November 10, 2010, 02:51:11 AM »
Grab a zip tie and pull the clutch lever in but not all the way with the zip tie, put it into second gear and walk away for 5 minutes. When you return just rock the bike gently back and fourth, it will release the plates. It works for me every time. If that doesn't work then you will have to take the cover off and release them manually.
