Author Topic: CB500 vs CB550 exhaust  (Read 7761 times)
mustanger67
« on: March 13, 2006, 06:43:26 pm »
Now that I know about my carb interchangability, (see previous post), my next question is about exhaust.  My "72" CB500 has aftermarket 4 into 2 exhaust on it.  I want to replace these with original 4 into 4 mufflers.  Will the CB500 and CB550 exhaust interchange?  Any modifications to do this?  Thanks, Jerry
Offline csendker
  • Chris; '75 CB550 & a Crusty 'ol boat
Re: CB500 vs CB550 exhaust
« Reply #1 on: March 13, 2006, 07:27:37 pm »
I believe the 500 & 550 are esentially the same engine; block at least.  The exhaust should attach to the block OK, but I'm not sure how "drop-in" freindly all of the mounts & hangers are.  Need the experts to elaborate on this one.  Also, I assume the K's (stock 4-4) as the F's had a stock 4-1.  And the 4-4's had an internal condensation issue (read that rotting out) if the typical ride was short, not allowing them to heat up enough.
Actually runs --> 1975 CB550-K1
Projects ---> Crusty old boat
Gallery --> http://www.sohc4.us/gallery/v/members/personal/Christopher/?g2_navId=xada3c7ff
« Reply #2 on: March 13, 2006, 09:13:31 pm »
All the Cb500 and 550 stock 4 into 4 exhausts were the same, mounts and all, EXCEPT the 77and 78 Ks.
mustanger67
« Reply #3 on: March 13, 2006, 09:17:50 pm »
Thanks for the info.  Now if I can find a decent set of exhausts.  Thanks again.
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #4 on: March 14, 2006, 01:33:38 am »
If you have the $$, go for NOS (new old stock - in other words, new exhausts that have been in someone's warehouse for 30 years).
David Silver has them at about $120 each plus shipping.
If you buy any 4-4 exhaust, don't forget that you'll need the hangers and the little rubber links and clamps that you will see on the parts diagram.
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
smithrelo
« Reply #5 on: March 14, 2006, 12:44:29 pm »
Steve, I just looked at David Silvers....I can't seem to find the 4-4.  I find 4-2 or 4-1 but didn't see a part number for the 4-4.  Can you help?
I'me thinking I'll order them, if I could figure out the exact parts numbers, and would the attachment thingys come with them, or would those be seperate part numbers?
Linda-trying to figure this out
« Reply #6 on: March 14, 2006, 01:05:56 pm »
http://www.davidsilverspares.co.uk/cgi-bin/dss2-cgi/Catalogue.pl
QTY
2 - CB550K0/K1/76 : Exhaust sealing ring between top and bottom silencer  ....  £5.60
1 - CB550K0/K1/76 : Exhaust unit, Left hand lower - No. 2 cylinder  ....  £79.00
1 - CB550K0/K1/76 : Exhaust unit, Left hand upper - No. 1 cylinder  ....  £79.00
1 - CB550K0/K1/76 : Exhaust unit, Right hand lower - No. 3 cylinder  ....  £79.00
1 - CB550K0/K1/76 : Exhaust unit, Right hand upper - No. 4 cylinder  ....  £79.00
4 - CB550K0/K1/76 : Exhaust port gasket  ....  £1.40
1 - CB550K0/K1/76 : Exhaust rubber stand stopper  ....  0.5
You should be able to reuse all your old clamps, brackets, nuts and bolts.
smithrelo
« Reply #7 on: March 14, 2006, 08:33:51 pm »
Thank you!  I pasted that info into a file, and will see what shipping will be.
Thanks again!
Linda
stingray
« Reply #8 on: March 15, 2006, 02:46:14 pm »
Interesting site for restorers.  How come they don't show pictures of their parts?
I'd like to see a picture of those silencers before I lay down the cold hard.
    • TVAM
« Reply #9 on: March 16, 2006, 01:18:07 am »
Some of the aftermarket stuff comes with pictures (exhausts etc) and I have noticed photos creeping into the lists for some of the models  (400?)
I guess it's a case of the 21st Century finally catching up with a company that sells NOS Honda stuff.
As long as it's genuine Honda NOS - why do you need a photo?
SOHC4 Member #2393
2015 Tiger 800 XRT
« Reply #10 on: March 16, 2006, 03:00:56 am »
Believe it or not those aint NOS. Honda still manufacture them!!!!!(Chrome quality aint quite as good as 30 years ago but its pretty good) BUT NOT the 77/78 ones. If you aint got them you will also need the exhaust hanger brackets, easiest way is to e-mail dave silver and ask how much for a COMPLETE system with shipping BUT BE ADVISED your customs man will want a "cut" before you can actually have them. Also try www.westernhillshonda.com as even if they are a bit dearer you dont pay import duty. If you really want i can give you all the part numbers
    • TVAM
« Reply #11 on: March 16, 2006, 03:29:46 am »
So they're "NNS" (New New Stock!)
So why don't they make the 77/78 zorsts Bryan?  (speaking as someone who has 3 out of 4 rotted out - the only good one is the one that DS has!)
SOHC4 Member #2393
2015 Tiger 800 XRT
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #12 on: March 16, 2006, 04:48:18 am »
  Hey Two Tired,
                    On the 77-78' exhausts, is the rear bolt up the difference or is there more? I have a 77'
  and a 78'. I've got a system for the 78', even though it's not in the best of shape. Thanks.
                                        Later on, Bill
Member # 1969
Offline csendker
« Reply #13 on: March 16, 2006, 07:59:25 am »
Part no.'s & $$.
« Reply #14 on: March 16, 2006, 10:17:31 am »
  Hey Two Tired,
                                        Later on, Bill
As far as I know the 77-78 frames and exhausts were the same and should interchange without problem or other interference issues.
If you are asking if these exhausts will fit on previous models of 550, there are a lot of variables.  K/F for one.  I would be concerned for not only the frame attachments, but interference with brake lever arms and side stand too.  There is also the jetting issue as well.
Offline Ted Nomura
« Reply #15 on: March 16, 2006, 11:37:39 am »
CB550 engine is just a CB500 Four with a bigger bore to correct the lack of power that most owners were complaining. The reason why 77-78 CB550K exhausts were not being made now is because they were less popular than the original style mufflers but they are usually cheaper to buy if you can find them. I saw a couple of 1971-1976 CB500 and CB550 Fours fitted with 77-78 type exhausts so I guess they can fit too.
1969 Honda CB750, two 1970 CB750, two 1972 CB750K2, 1971 CB500, 1975 CB550, 1976 CB400F, 1968 CL450, 1973 CL450, 1974 CB450, 1970 1/2 SL350K1, 1971 SL350K1, 1972 SL350K2, 1972 CL350, 1972 CB350, 1983 CB1000C, 1976 Kawasaki KZ900A4, 1976 KH500A8, 1979 KZ400B, 1983 ZN1300, and so on and so on...
    • TVAM
« Reply #16 on: March 16, 2006, 11:53:50 am »
Harry (Teicher) and myself have scoured Europe for these exhausts.  Maybe they are rarer here because we only had the 550K3 with that system and then for only 77-78 and in relatively small numbers as everyone wanted a GS. The earlier 550s were all Fs.  Maybe I should get a set of 500 pipes (and a US "550Four" sidepanel badge)
I can almost here TT muttering...   jetting... jetting...
SOHC4 Member #2393
2015 Tiger 800 XRT
Offline dusterdude
« Reply #17 on: March 16, 2006, 01:09:31 pm »
you know it
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
« Reply #18 on: March 16, 2006, 01:49:52 pm »
hmmm... seems I don't have to.
However, the info is interesting.  Might explain why the older 4 into 4 is available in the UK and sparse here in the states.  I think the K3 4 into 4 is hard to find anywhere these days.
