Author Topic: Air Filter & Stack Filter Kit for 550's & 750's / The end, see post #898, pg 36  (Read 203000 times)
Offline CaféElite
  • 1975 CB550
Re: Air Filter & Stacks Combination for 550's & 750's
« Reply #225 on: January 07, 2011, 11:18:54 AM »
Is there going to be any additional fees around shipping to get these into the states (ie: customs)? Any way to get an idea what shipping will be?
CB550's
Kansas City..
Religion is like masturbation, do it at home and keep it to yourself
Offline Kong
« Reply #226 on: January 07, 2011, 02:52:17 PM »
I would not pretend to know much about Honda carbs but if I were a carburator-guessing kind of monkey I'd say that its quite possible that no carb changes from stock will be required at all with these things.  I think their main fetching point is that they retain a velocity stack to straighten out the airflow before it reaches the actual carb, something lost in a Pod-bike.  They may flow better overall, which may or may not necessitate a slightly larger main jet and possibly a small needle height adjustment (1 notch?) and at worst topping it all off with a little bit more fuel added with the adjustment screw (in for early carbs, out for late).  That regimen would add just a little fuel more or less evenly throughout the RPM/throtle-opening range.
Just my suspicions, but I don't think they are too far off.
PS: I'd have been happy to pay the full amount this morning, and if it will help with placing the first order for component parts I'd be happy to pay the remaining ballance due in full, I'm not worried about you skipping the country with all the loot.   ;D
« Last Edit: January 07, 2011, 02:54:37 PM by Kong »
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
Offline 05c50
  • 05c50
    • Classic Motorcycle Solution
« Reply #227 on: January 07, 2011, 03:11:33 PM »
 ;D he's already across the border!
..............Paul
Offline Tintop
« Reply #228 on: January 07, 2011, 04:49:12 PM »
Easiest & least expensive way to the US is post.  You can use this postal code as the ship from - L7E 1C2
..............Paul
Yeah, and with the snow we've had lately, not going very far. ;) :) :)
Thanks for the support guys.
« Last Edit: January 07, 2011, 04:52:24 PM by Tintop »
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline brah pitt
« Reply #229 on: January 08, 2011, 05:44:37 AM »
So, is it possible to still get in on first batch if i send deposit now? Also, can you update first post with payment instructions.
« Last Edit: January 08, 2011, 05:51:30 AM by brah pitt »
Offline Tintop
« Reply #230 on: January 08, 2011, 06:02:11 AM »
Yes to the 1st question.  Also I will update the 1st post with instructions as suggested.
77 CB550 Cafe build
Offline brah pitt
« Reply #231 on: January 08, 2011, 06:10:03 AM »
excellent, payment on its way.
Offline Tintop
« Reply #232 on: January 08, 2011, 06:15:53 AM »
Thanks brah pitt
77 CB550 Cafe build
Offline juice
« Reply #233 on: January 08, 2011, 11:58:32 AM »
hey tintop,
you placed me in the mucho interested for order but at the pace my rebuild is going, i'm far from ready to buy stacks.
I'll leave my spot to someone else and i'll buy from the 3rd order probably.
Daily driver: SV1K 2003
In the works: CB550K 1978
Offline Tintop
« Reply #234 on: January 08, 2011, 02:31:19 PM »
hey tintop,
not a problem.
77 CB550 Cafe build
Offline Kong
« Reply #235 on: January 08, 2011, 03:37:02 PM »
If I'm not mistaken that's why we have NAFTA (North American Free Trade Agreement - with emphasis on the "Free" part), there shouldn't be any import duty at all.  Just one big happy family in the greater international sense; well and as it should be.  When sending things out of the US the sender simply fills out the green slip at the Post Office, about the same information as you'd fill out for Registered Mail; what's in the package, where's it going, how much is it worth, new or used I think may be on there too, don't remember exactly.  I suspect it isn't much harder to send things south.
1978 Honda CB550K
1977 Honda CB550K
Offline Syscrush
  • Sold. :(
« Reply #236 on: January 09, 2011, 12:37:03 PM »
The caveat is that if you ship with a courier, they act as their own brokerage for marshalling the item across the border, and the fees for that are high ($40-50 regardless of the value of the item).  The trade-off is that it will clear the border without delay.  If you ship by regular mail (Canada Post / USPS), you don't pay the brokerage fee, but you also get no guarantee (or feedback) about how long your item will sit at the border to clear customs.  Could be 2 hours, could be 2 months.
Offline Tintop
« Reply #237 on: January 09, 2011, 02:25:21 PM »
+1 on the extra 'brokerage fee'.  I planned on using Post as much as possible, just for that reason.  Going to check into the USA duty situation.  Should be duty free, as it is assembled in Canada, and uses US made parts (stacks).  Generally I have found that Post is 6-10 days either way across the border.
77 CB550 Cafe build
Offline Kong
« Reply #238 on: January 09, 2011, 02:32:19 PM »
TinTop,
For whatever its worth the set of shocks you sold me took 3 days, from date of posting, to arrive at my door.  I presume the air cleaner will be about the same size, probably a lot lighter package, and would have similar markings.  As for distance, I am about 80 or 90 miles south of Pittsburgh, PA.  There was no indication that the package had been inspected in any way, all wrapping was intact.  As you may recall this was somewhat recently, but before the holiday rush.
« Last Edit: January 09, 2011, 02:33:57 PM by Kong »
1978 Honda CB550K
1977 Honda CB550K
Offline Syscrush
  • Sold. :(
« Reply #239 on: January 09, 2011, 06:09:31 PM »
I buy a fair bit of stuff from the states and use USPS as much as possible.  Stuff almost always comes within a week, BUT it's worth remembering that there is no guarantee at all on delivery time and if you call up customs to ask how long your package will be stuck at the border they'll tell you to go pound sand.
Maybe 1 time out of 15 something gets stuck for 2 weeks or more.  Not often.  Order your bike parts over the winter when it's usually less time-critical. :)
Offline Tintop
« Reply #240 on: January 09, 2011, 06:11:40 PM »
I've never had anything take longer than 10 days coming up here.  Even the stacks, when I account for the security hold, & holiday closings, took 6 days.  Post is by far the least expensive.  That said, I will certainly ship by whatever other means is requested.
77 CB550 Cafe build
Offline CaféElite
  • 1975 CB550
« Reply #241 on: January 10, 2011, 09:00:49 AM »
I figured I woud verify since I ordered some swaybars for my 240 a couple years ago from a company in hockey land and got a nice little brokerage bill outside the company (UPS I think) quoted shipping fee. I wasnt so much pissed about the cost but lack of knowledge of getting hit with the cost.
deposit sent via paypal
« Last Edit: January 10, 2011, 09:23:17 AM by CaféElite »
CB550's
Kansas City..
Offline Tintop
« Reply #242 on: January 10, 2011, 09:27:25 AM »
UPS is the worst for the 'brokerage fee'.  I avoid using them just for that reason.
77 CB550 Cafe build
Offline Syscrush
  • Sold. :(
« Reply #243 on: January 10, 2011, 09:36:03 AM »
Are they more expensive than FedEx?  I never paid close enough attention to notice a difference.  It hurts to get dinged $40 for a $10 item, which might have distracted my otherwise strong analytical skills.  ;)
Offline Tintop
« Reply #244 on: January 10, 2011, 09:59:58 AM »
UPS is $40.  Kind of kills a good deal when a $10 part gets another $15 for shipping, then gets hit with $40. ::)
77 CB550 Cafe build
« Reply #245 on: January 12, 2011, 01:50:33 PM »
Hot and humid here, and I feel like #$%* as I've got a bloody cold! It could be much worse though, I live in Melbourne but I'm watching the news from Brisbane where massive flooding has just devastated the city, very sad watching the images of the terrible destructive force that has forced thousands of people out of their homes and tragically, has taken several lives, with many people still missing. I'm glad to have received a message from Mick (Retro Rocket) that he's OK, and he thinks that Dave (Dave500) is OK as well.
Anyway, I'm trying to get my K1 back together after painting the frame, but I hope to have it close to finished today, as Brian (Tin Top's) anti-pod kit has arrived for testing, woohoo! ;D
Offline Tintop
« Reply #246 on: January 12, 2011, 04:39:00 PM »
Very good news that Mick, and it sounds like Dave, are both OK.  From the news over here, the flooding sounds like it has caused a lot of damage, and as you said, taken some lives.
Glad to here the kit has arrived.
77 CB550 Cafe build
Offline Flying J
« Reply #247 on: January 12, 2011, 05:17:55 PM »
Whats the time frame on the 550 kits?
Offline Tintop
« Reply #248 on: January 12, 2011, 06:42:24 PM »
I had planned on placing the order with ITG by now.  However, as Terry just rec'd the test unit, I will wait until early next week, for those holding off, awaiting tests.  It is about a month from when I contact ITG, to when I will have them ready to ship out.
To speed things along, I could limit this 1st quantity to a total of 15 (10 already accounted for).  Both use the same frame and back plate (different holes); and confirm the ratio of filters (heights required) later.
77 CB550 Cafe build
Offline odiewan
« Reply #249 on: January 14, 2011, 10:16:58 AM »
Hey TinTop. Very interested in this.
Can you put me down for a set for a 750K3?
Have you had any word on jetting recommendations?
One other thing: what about anodizing the aluminum parts? I guess you would have to have enough in each color to justify an anodizing run.
CB750K3
2009 Aprilia RS125
2001 Aprilia RSV Mille R
2002 Suzuki SV650S
1979 Vespa P125X
