Author Topic: Air Filter & Stack Filter Kit for 550's & 750's / The end, see post #898, pg 36  (Read 252923 times)
Offline Tintop
Re: Air Filter & Stacks Combination for 550's & 750's
« Reply #50 on: November 25, 2010, 05:02:22 PM »
And report on its behaviour..... ;D ;)
We are about 12 hours away from being covered in the white stuff. :(  Any setup testing I do will be indoors.  What I should have added to my previous post -
... I will of course fit one to my 550 immediately, and post pictures.  The 2nd filter will be sent to my tester south of the equator, to get real world 750 setup test results.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
« Reply #51 on: November 25, 2010, 05:56:56 PM »
"South of the equator tester" ready and waiting.............  ;D
Offline Tintop
« Reply #52 on: November 25, 2010, 06:26:22 PM »
OK, as the filters are on their way to me, and the 1st 750 stacks are do about the same time, my tester it seems is getting antsy. ;) :)
I have asked Terry to do the 750 testing, to which he has agreed.;D ;D  The plan is to ship him a complete unit, about the middle of next month (2 weeks).  The best part is that Terry will be trying it on all his bikes.   This will supply setup info on different pipe, and displacement configurations.
So Mick, we should all start getting 'real world' fed back just in time for Xmas. :)
77 CB550 Cafe build
« Reply #53 on: November 25, 2010, 06:45:00 PM »
I doubt the "tester" is using stock carbs on the various "test vehicles". How are you planning to manage fitting 750 stacks on these various machines carb sets?
Good work fellas....test away.
Offline Tintop
« Reply #54 on: November 25, 2010, 07:20:31 PM »
Thanks bwaller, sure you don't want to try 750 carbs on that race motor of yours?  You could always bore them. ;) :)
Terry has had the stock carbs on all his bikes, including the 836.  I would expect in that situation to see good throttle responce, and very strong bottom / mid range.  However, the carb throat size will restrict top end vs a Mikuni or CR.  How much, is but one of the questions he will be answering. ;) :)  My expectation is that, in day to day street riding, any performance trade off will be well worth it.  So while he won't get every pony out of it, there should be a torque curve that even a V8 would envy.  Good thing it has that lockup clutch. ;) ;D
77 CB550 Cafe build
« Reply #55 on: November 25, 2010, 07:38:56 PM »
Bored 750 carbs are my backup plan, but I think the Mics should make it go!
Offline Tintop
« Reply #56 on: November 25, 2010, 08:12:41 PM »
Syscrush and I were talking about the FAST School.  His comment was he was one of the slow guys.  Said that was great because now I knew I would have someone to ride with. :)  Also someone to share watching you go by every couple of laps, while you test those bionic Mics. ;) :)
77 CB550 Cafe build
« Reply #57 on: November 25, 2010, 11:05:52 PM »
Excellent
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
« Reply #58 on: November 26, 2010, 05:11:33 AM »
This is all so well thought out. Tintop whenever I read your posts it is like getting a lesson in mechanical engineering, chemistry, racing, motorcycles...llamas? This has to be the most well thought out/ researched approach for an airfilter.....my bike thanks you. The guy in China making those $5 pod filters is cursing your name. ;D
Keep up the great work, we are all benefiting!
Offline Tintop
« Reply #59 on: November 26, 2010, 05:54:49 AM »
Thanks Frankenstuff, coming from someone who has contributed so much to this site, your comment is greatly appreciated.
77 CB550 Cafe build
« Reply #60 on: November 26, 2010, 07:55:05 AM »
quote]
Are we planning a track day? I'm hardly a lightning bolt, so I need to do laps, that's for sure
« Last Edit: November 26, 2010, 07:56:36 AM by bwaller »
Offline wannabridin
  • Patience made me a
  • -Garrett
« Reply #61 on: November 26, 2010, 10:38:38 AM »
Cant wait to hear the test results!!! And see how it looks installed!  Then of course, to give you some money! :)
Offline Tintop
« Reply #62 on: November 26, 2010, 12:31:11 PM »
I'd like to 'air out' the 550 at least once without baffles.  So I thought I would check out what spring track days are being offered.  Sounds like Syscrush would be up for it.  Probably prefer Shannonville, as it is alot more forgiving of 'rusty rider' mistakes than Mosport.
1st up will be photos of it on my 550, then the test results from Terry.  You don't have to wait though, I'm always open to receiving money. ;D ;D ;D ;D
77 CB550 Cafe build
Offline Syscrush
  • Sold. :(
« Reply #63 on: November 26, 2010, 01:00:31 PM »
I'm up for it at Shannonville if I can work out a way to get my bike prepped and to the track.  I've done a track day at CMP where I rode there the day before, prepped the bike at the track, rode all day, then switched it back to road-duty and rode home.  I'd be down with something similar in this case, although I'd also be open to riding over to someone's nice heated garage, doing the prep there, and riding along in his bike hauling rig. :)
« Reply #64 on: November 27, 2010, 01:47:26 AM »
Just one small correction Brian, as Brent knows that I'm running 32mm CV's on my gold 836cc K2, but I took the CR's off my K1 fitted with the hot 836 and am back to running stockers. (I hated the CR's, I've got some modded 33mm Mikuni smoothbores for my 1060cc RC engine and I've used them before on a Suzuki 1100 Drag bike and they were great)
I've got a K6 top end on my F2, so I'll be able to compare Brian's filter set up on both extremes, a stock as a rock CB750, (albeit with electronic ignition and 4 into 1 pipe) and on a worked 836 with 12:1 pistons, JMR stage 3 head, Megacycle 125/75 cam, etc etc. I'm going on a months leave in a couple of weeks, so I'm looking forward to putting in a lot of riding! Cheers, Terry. ;D
Offline Tintop
« Reply #65 on: November 27, 2010, 03:45:26 AM »
Thanks for the update Terry.  With your 'herd thinnlng', I kind of lost track of what was still in the barn.  For those interested in the results, the F2, and 836 will cover both ends of the spectrum. ;) :)  Many thanks again for taking this on. - Brian
77 CB550 Cafe build
« Reply #66 on: November 27, 2010, 04:13:07 AM »
I'm very happy to be of help Brian, although I'm happier with the stock Keihin carbs over the CR's in most respects, I wasn't happy with the K&N pods on my hot 836cc engine, and while the stock airbox appears to work better with a K&N filter installed, it's still far from perfect, so I'm really hoping that your setup will provide the best option, and it'll certainly look better than either pods or the old airbox! Cheers, Terry. ;D
Offline SF
  • I burn gas very well
« Reply #67 on: November 27, 2010, 06:10:59 PM »
tintop is there going to be any type of change in jetting regarding Australia vs Ontario for the anti pod ? I dont know ... just askin... cuz ... i dont know :P
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
« Reply #68 on: November 27, 2010, 06:22:48 PM »
No one will know until the testing is done..  One thing i will say is that if both places are the same distance above sea level then there will no difference in settings if both bikes have similar specs, there are two many variables to say, "this kit will use the same jets and needles world wide"
Offline Flying J
« Reply #69 on: November 27, 2010, 06:24:21 PM »
You'll need reverse venturi jets due to the Coriolis effect.  ;D ;D
Offline Zaipai
    • My Home page
« Reply #70 on: November 27, 2010, 07:55:55 PM »
I agree, if they help out better then the foam pods I have I will plunk down some green backs on them also.
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline Tintop
« Reply #71 on: November 28, 2010, 06:43:44 PM »
That's my take on it Mick.  What I am hoping to get from Terry's tests are a baseline / starting point.  This should get you very close, or maybe there if your engine has the same specs as the test bike(s).
77 CB550 Cafe build
Offline Tintop
« Reply #72 on: December 02, 2010, 07:46:56 PM »
Quick update.
The 1st two filters have arrived from the UK, and I will pick them up on Saturday.  First thing will be to drill holes for the stacks.  If nothing else gets in the way I should be able to post photos of it installed on my 550 by Sunday.  As soon as the modified 750 stacks arrive, I will ship Terry his test unit.  At this point that looks like it will be late next week.
Then the fun can begin. ;) ;D
77 CB550 Cafe build
Offline Flying J
« Reply #73 on: December 02, 2010, 09:11:14 PM »
Good thing you got your bike running. CAnt wait to see.
Offline Tintop
« Reply #74 on: December 03, 2010, 04:18:51 AM »
I'll will post some photos of the install, probably on Sunday when I get back home.
77 CB550 Cafe build
