Author Topic: Air Filter & Stack Filter Kit for 550's & 750's / The end, see post #898, pg 36  (Read 200747 times)
Offline Tintop
Re: Air Filter & Stack Filter Kit for 550's & 750's / Now Shipping (see 1st post)
« Reply #775 on: February 24, 2012, 05:06:34 PM »
The local post office is open tomorrow, so still time to get a stack set out. ;)
Its in there, I just sent it.  Thanks again
Rec'd, will be in the post tomorrow AM, thanks.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline Syscrush
  • Sold. :(
« Reply #776 on: February 28, 2012, 01:49:26 PM »
Mine arrived today.  Thanks for everything.
Offline eworth
« Reply #777 on: February 29, 2012, 06:46:19 PM »
 Looking forward to receiving it.
« Last Edit: February 29, 2012, 06:48:35 PM by eworth »
Offline Grnrngr
Got mine today! yeah!! had to go to the Post Office to get it, I was home all day yesterday, no one knocked, when I checked my mail there was the little card saying he "attempted to deliver.." ah well...looks excellent!!
'72 CB750-K2 "PopCycle"
'73 CB750-K2 "Barney"
'77 CB750A
'83 Virago 500 (red)
'83 Virago 500 (black)
Offline eworth
Mine arrived today also.  Thanks TT.  Hope to install this weekend.
Offline SOHC Digger
  • I'm not an
Got mine yesterday.  Excellent!
Offline srbakker
  • Spam & Eggs
On the doorstep after my work day today.  That's a good way to end the day - thanks again!
1975 CB750 K5
2007 Triumph Tiger
2007 Triumph Speed Triple
1971 Kawasaki F7 175 Enduro
Offline Tintop
Glad to hear they are all arriving. 8)
77 CB550 Cafe build
Offline hapakev
  • Your Standard
Haven't received mine yet, but I am hoping they show up before the weekend.
Smoking Jack
1978 CB750F(ish)
Offline SOHC Digger
  • I'm not an
Mounted!  Hell Yeah!
Offline KC3
  • Nature abhors a change in flux - David Griffiths
TT- got a question for you... Does the filter have any significant water resistance properties? I am currently running pod filters with outerwear pre-filters (see pic below). I am considering also purchasing an outerwear pre-filter for your veloci-nator stacks unless your filter will do the trick alone. (My bike hates water!)
Also..it runs pretty good right now..I'm very interested to see what kind of power increase it will get. If not quantitative data, I'd at least like to get some butt dyno data and compare.
I currently have my '76 550f with 4into1 exh with a home-made can (glass packed with minimal baffles). I dropped in a 650 cam. 022A carbs (i think??) or 069A..can't remember (can you tell by the pics?) with #115 mains and stock otherwise. Very clean carbs and runs the best it ever has currently. (I'll look at the number tomorrow)
Excited to see what some well engineered stacks can do for her! Thanks for all your hard work on these!!
By the way..put me down for some blue ones. I messaged you (kkaerich) but forgot to specify the color. If all you have is black though, and it would be more than a month to get blue, then I will go for black.  :D
KC
« Last Edit: March 09, 2012, 10:48:48 PM by KC3 »
Whether you think you can, or think you can't...You're right. -Henry Ford
Offline orkid1989
  • “Life is too important to be taken seriously.”
figured i would post some pics of the intake. this is on a 1971 cb750k.
“Experience is the name every one gives to their mistakes.” Oscar Wilde
Offline Tintop
As the only bike I ride in the rain is my VF750F, can't really comment on that.  However, my opinion would be that the filter oil,  placement of the stacks, and the back plate would mitigate ingestion to some extent.
77 CB550 Cafe build
Offline Tintop
Thanks to all those who have taken the time to post pictures.  Seeing it on SOHC Digger's chopper is really 8) 8) 8) 8)
77 CB550 Cafe build
Offline IRISHCBRACER
    • My first build - 1976 CB550
The filter is awesome although I made a new mounting plate to reduce the foam compression with the tubing supports being close on the CB550, I was able to move the filter 18mm away from the tubing  ;D I will be anodizing the new plate black and modifying the clutch cable bracket to relocate the cable entry.
Offline Tintop
Very nice work.  Only draw back to that solution is it goes against the (current) filter clearance rule.  Basic rule is that you should have, as a minimum, the same internal clearance as the throat ID.  The 550 carbs are 35mm, and the filter (45mm - 10mm filter material) just meets this.  To get it to squeeze in, I drill the holes above the centre line (drops filter slightly), and modified the back plate mounting point on the stacks from stock.  The result adds just enough horizontal clearance to allow for a 45mm filter (without crushing the support wire).
All that said, I will be interested to hear how your revision works.
As for a next order.  The price will have to go up by $25/kit, as all my costs have increased.  The deposit amount will also change from $60 to $100.  So I need to know how many are still interested.   As soon as I get 8 firm orders (with deposits), I can proceed.  Currently all my available funds are going into getting my vintage sidecar ready for this season's racing.  So unfortunately, I can't fund this out of personal $'s anymore.  Also I will only be offering kits, no stacks only in the future.
77 CB550 Cafe build
Thanks!
Your filter set-up is great, I am just picky about the foam compression on my Cafe project and had the capability to make the new designed plate.
I noticed your flat plate holes are off center, I did read up on the min filter to throat clearance before I made the new offset plate. Since I now have a step/offset I made the holes centered to bolt on the filter, this will give back some clearance. I think with the nice wire support and holes been centered will work out just fine.
Offline Tintop
Looking forward to seeing some pictures when you get it all installed.  Thanks for the support for the kit!
77 CB550 Cafe build
Offline geminimotors
Time travel! Here's a shot of the Anti-pod on a 70's F1 car It's in the last photo in the gallery: http://jalopnik.com/5894846/ron-howards-f1-film-rush-will-make-the-70s-look-sexy/gallery/1?popular=true
Offline kyre
    • CB400F / 466 Build Thread
No 400f love?
CB400F / 466 Build Thread (currently in progress)
http://forums.sohc4.net/index.php?topic=105027.0
Offline Tintop
That's the Tyrrell six wheeler, an interesting bit of engineering in it's day.  Object was to decrease frontal area, while increasing the front tire contact patch area for better cornering grip.  And yes, the F1 Ford DFV filters were the inspiration. ;) :)
77 CB550 Cafe build
Offline peckcj
I'm in for buying a kit.  How do I get on th next order?
Offline Tintop
send me an email at - brian.robinson7@sympatico.ca and I will add you to the 'interested list'.  I plan to contact all next week to confirm information (eg. version required / name / address)
77 CB550 Cafe build
Offline peckcj
Email sent  :)
Offline peckcj
Are there any updates to the new order?
