Author Topic: 1978 cb750K8: Hole In Frame ** Advice Needed **  (Read 2301 times)
Offline liPPy
  • 1978 cb750k
« on: November 09, 2010, 10:45:40 PM »
I've just started work on my first ever bike, a non-running '78 cb750.
The bike is filthy and been left outside for a while. I started stripping it down tonight. After finding the foul smelling remains of a dead mouse in one of the exhaust headers I got to removing the kickstand when I noticed a slight bulge on the frame about 10cm from the kickstand mount.
Further inspection revealed a small hole. Pictures below.
How big of a problem is this and what do I need to do to take care of it??
As stated earlier, this is my first project and I really am learning as I go along, so any advice is hugely appreciated!
Thank you!
From directly below:
Offline Hasenkopf
  • Really, I'm not an
  • This space for hire.
Re: 1978 cb750K8: Hole In Frame ** Advice Needed **
« Reply #1 on: November 09, 2010, 11:46:41 PM »
looks like water got inside and froze..... if the frame isn't too badly rusted with pinholes you could weld it back up, drill a small drain hole, or keep the bike inside from now on
I like berries.
Offline Toxic
« Reply #2 on: November 10, 2010, 04:29:40 AM »
+1 on it looking like a frost split.
But you are going to thoroughly strip the whole frame and inspect all the welds anyway so welding it up won't be  a big deal.  I wouldn't just weld it up and assume the rest of the frame is good.  There looks to be allot of surface rust on it.
Offline liPPy
  • 1978 cb750k
« Reply #3 on: November 10, 2010, 05:50:56 AM »
Thanks for the quick response.
And you are correct, I'm stripping everything off and powdercoating the frame. Inspecting the rest of it will be no problem.
So once I confirm no other damage I can weld the gap and smooth it out before it goes to the powdercoaters.
The welded crack will not compromise the strength of the frame?
Offline Toxic
« Reply #4 on: November 10, 2010, 06:06:59 AM »
[/quote]
[/quote]
Not at all if it is done right..  I have seen much worse fixed up.  Stripe it bare and see what you have got.  Personnally I like to take the frame to a sand blaster.
Offline Roach Carver
« Reply #5 on: November 10, 2010, 06:31:53 AM »
this is really REALLY common. I fixed mine by cutting another frame and placing a patch over it. A friend of mine tacked it over the area of the hole. looks ok. The way it was explained to me is that you dont weld it solid because there is a small amount of flex in the tubes and if yuo try to make it solid it will just crack.
Offline MoMo
  • Ride like you're invisible
« Reply #6 on: November 10, 2010, 06:37:04 AM »
I had a similar problem with a CB400f, had a welder shape a plate and weld it to the frame.
Offline liPPy
  • 1978 cb750k
« Reply #7 on: November 10, 2010, 08:57:27 AM »
Nice one. I'll add it to the ever growing list  ;)
Offline Ouch
« Reply #8 on: November 10, 2010, 10:01:56 AM »
not trying to thread jack...but what type of welding would due? Would Tiging somthing like that be the best way to go?
« Reply #9 on: November 10, 2010, 07:03:13 PM »
 Tap it back a bit if you can and mig weld it. If you dont grind weld all the way down, it might? be better.. thats the easy fix.
 I got a 77F here where the split is much longer and the frame swelled up to 1/8 INCH or MORE  :o in spots, the stretched area is about 3 inches long.. looks like a snake that swallowed a pig... :o
