Author Topic: 750 5mm valve conversion  (Read 3791 times)
Offline ttr400
    • ttr400 Projects and Billet parts.
« on: November 11, 2010, 09:51:22 AM »
Can anybody of you 750 guru's out there help with some info that I need.
i have the kibblewhite 5mm valve conversion kit and need to know the installed valve spring height, plus the installed length seat pressure.
Many thanks Kevin
CB400F- 492 Yoshi Racer.
Cb400F- 466 Yoshi Cafe.
CR750 D Mann Replica.
VFR750R- RC30 - 1988.
www.ttr400.com
Re: 750 5mm valve conversion
« Reply #1 on: November 11, 2010, 10:32:03 AM »
Kibblewhite says 1.370" to 1.380 Kevin.
Offline ttr400
« Reply #2 on: November 11, 2010, 10:52:57 AM »
Thanks Mike, I searched all over the kibblewhite site and could not find those specs.! Any idea of spring pressure. 75lbs ? or more?
Kevin
www.ttr400.com
« Reply #3 on: November 11, 2010, 10:59:31 AM »
Kevin
75lbs will be enough Kevin. You are running that 125-75 if I remember correctly?
Offline ttr400
« Reply #4 on: November 11, 2010, 11:21:54 AM »
Great. Yes the 125-75. thanks Mike.
Kevin
www.ttr400.com
Offline turboguzzi
« Reply #5 on: November 11, 2010, 05:40:34 PM »
mmm.... hows the reliability record with 5mm stems?
Can understand that with a dohc but with rockers and high lift your bound to increase big time side loading on the stem,
TG
« Reply #6 on: November 11, 2010, 06:33:19 PM »
TG
The valve/retainers are half the weight. You'd have to run about 1/3 more spring with the 6.5mm valves. The guide is so big and long it picks up heat, load etc. I was told this set up was tested to 14,000 RPM for extended periods with negligible wear on the guide, stem and rocker arm.
« Reply #7 on: November 11, 2010, 06:35:10 PM »
TG
How is the reliability with you stock 550 stuff?
Offline turboguzzi
« Reply #8 on: November 12, 2010, 04:25:30 AM »
TG
close to perfect i think :)
Didnt tear down after this last season but on all other tear downs valve play was in spec, and that's with guides cut to the port roof, at least on the inlet.
had some 93' GSXR750 valves laying around with tiny stems and the right diameters, they were tempting to use at the time but I skipped because of $$$ but also because they looked like they would simply buckle at one point...
  • Moderator
« Reply #9 on: November 12, 2010, 06:22:09 AM »
Ran them for 3 seasons in the CR Yossef, no issues what so ever.
Sam. ;)
Offline simon#42
  • liverpool
« Reply #10 on: November 12, 2010, 10:27:32 AM »
had them in my f2 for a couple of years now , done just over 25,000 miles and all seems well . am hoping it will cure the guide wear problems , will run it for another year then have a look
Offline BLUE71TURBO
« Reply #11 on: November 12, 2010, 10:54:12 AM »
  How much is this 5mm conversion ?    ???
« Reply #12 on: November 12, 2010, 10:56:56 AM »
Just curious...What about converting to smaller stems would make one think they would wear less? Hard to make that sentence sound right. Its a sincere curiosity, not a poke.  And I hope they have given you better performance than stock.  Are they (valves and guides) of better material or such?
Am considering them for future project but its a K head.
« Reply #13 on: November 12, 2010, 12:50:46 PM »
1,100.00 for forum members.  That includes 34mm intakes/28mm exhaust valves, guides,springs,Ti retainers,spring bases, keepers and lash caps
« Reply #14 on: November 12, 2010, 12:52:25 PM »
Much better material MC. Nice thing is the intake valve is 34mm (same as the F2) and when you open the seat up to 90% of the intake valve OD you start moving some charge.
« Reply #15 on: November 12, 2010, 01:30:42 PM »
Thx. Got my current project to finish, then on to the "rat". "Moving more charge" sounds fun.
Offline simon#42
  • liverpool
« Reply #16 on: November 12, 2010, 01:48:37 PM »
i agree with mike about the quality , they are a very nice piece of kit indeed .  my logic for the improved guide wear was , although the stem is about 20% smaller they weigh 50% less so proportionately they should be better  . also as mike has already said the spring rates are around 30% less which should also be kinder on the cam and followers which cant hurt .
« Reply #17 on: November 12, 2010, 01:53:41 PM »
Ah good points.
But is the spring rate 30% less than stock or 30% less than HD would be otherwise?
I'm sold on the conversion, just looking for education.
« Reply #18 on: November 12, 2010, 04:24:47 PM »
What is interesting is Simon used the 5mm, 32mm intake valve on the exhaust side of the F2 to solve problems. I remember him posting something about, questioning if that is what he did and getting an affirmative answer. Well done on his part....a lucid solution.
« Reply #19 on: November 12, 2010, 04:33:51 PM »
Ah good points.
There you go MC. Anybody putting one of these kits in a stock cam bike is missing the boat.
