Author Topic: Mounted an FRZ rear wheel  (Read 1495 times)
Offline Lumbee
    • My pics...
« on: March 14, 2006, 07:32:49 AM »
...I picked up this wheel off Ebay a few months back, and finally got around to cutting spacers and getting it mounted.  I'm posting this for the benifit of those who might be interested in mounting a wheel like this (sport bike) to there [otherwise] stock 750.  While this is a chop, the process would work on a stock bike.  Out of the box the wheel lined up pretty well.  However, there were two problems.  #1-Spacers to center the wheel between the frame rails (or swingarm).  #2-Axle was to small for the axle plates.  The axle plates on my chop, and in the stock 750 swingarm are around 20mm or 3/4 of an inch.  The axle for the FZR wheel was 17mm.  I decided to kill two birds with one stone by creating (actually having one of my fellow class mates create) what I'm calling a stepped spacer, see the first pic below.  The narrower portion fits in the axle plates, and adds about 1.5 mm on either side of the 17mm axle so it fts snug in the axle plates, while the larger poriton acts as the lateral spacer for the wheel.  This was for the left side next to the sproket.  The right side was easy, as the brake caliper arm acts as a lateral spacer.  I simply created at spacer 1.5mm thick to act as a sleeve for the axle so it would fit snug in the axle plate.  The last challenge will be to mount the brake caliper.  This should be fairly easy as the caliper mounts to an arm that [as I said earlier] acts as a wheel spacer.
The wheel is from a 95 Yamaha FZR600.  These are plentiful on Ebay, and those who want a modern sportbike wheel, this is a good choice as all you need to is make the spacers and deal with routing the break pedal and line.  The tire is a 130, so it clears the chain by about an inch.
« Last Edit: March 14, 2006, 07:36:45 AM by The great "Lumbee" »
"I'm not a welder, but I play one on HondaChopper.com"
Offline dusterdude
Re: Mounted an FRZ rear wheel
« Reply #1 on: March 14, 2006, 10:41:50 AM »
is that wheel a 17
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Lumbee
    • My pics...
« Reply #2 on: March 14, 2006, 11:01:54 AM »
...not sure...I think its the same as this one:
http://cgi.ebay.com/B162-94-1994-Yamaha-FZR600-FZR-600-REAR-WHEEL_W0QQitemZ5657903905QQcategoryZ31411QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
...which is an 18...I can look when I get home...
Offline ohiocaferacer
  • www.OHIOCAFERACERS.com
    • OHIO CAFE RACERS
« Reply #3 on: March 14, 2006, 11:09:39 AM »
The FZR600 rear wheel is an 18" wheel.......thats what i'm using on my CB350RR project.
Heres a diagram of the rear brake caliper, that I made a while back....more info at my website.
http://www.ohiocaferacers.com/CB350RRBrakeDiag.jpg
Later,
Greg
« Last Edit: March 14, 2006, 11:12:12 AM by ohiocaferacer »
Offline Lumbee
    • My pics...
« Reply #4 on: March 14, 2006, 11:12:41 AM »
Greg, did you mount it with spacers simular to what I described?
Offline dusterdude
« Reply #5 on: March 14, 2006, 11:27:02 AM »
thanks for the info guys
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
    • OHIO CAFE RACERS
« Reply #6 on: March 14, 2006, 11:32:07 AM »
Nope....everything matched the CB350 and didnt have to do anything other than slide it into place. Very easy swap on the CB350s.
I will have to run a 120 series tire....just to give a little better clearance with the chain. The 130 cleared it....but I want more...those chains bounce around alot and dont want to eat a tire.
Later,
Greg
« Last Edit: March 14, 2006, 11:34:08 AM by ohiocaferacer »
Offline dusterdude
« Reply #7 on: March 14, 2006, 11:34:33 AM »
lumbee,just to make conversation,its funny you made an adapter like that.whoever made the rear disc setup on my panhead back in the 80`s did the same thing.kinda cool huh.
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline Lumbee
    • My pics...
« Reply #8 on: March 14, 2006, 12:10:01 PM »
...duster, I guess great minds think alike!   ;D
Offline dusterdude
« Reply #9 on: March 14, 2006, 12:27:30 PM »
sure do
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Objectionableone
« Reply #10 on: March 14, 2006, 04:26:33 PM »
Very Nice!
