Author Topic: hydraulic clutch cb750?  (Read 15839 times)
Offline jaguar
« on: November 12, 2010, 05:18:37 AM »
was looking at one for the bikes on the BOTY thread and saw a cb550 with a hydraulic clutch
did some searching and found that you can use a Magura XS650 set up on the CB750?
seems to show that i mounts under the cover and its out of sight.
anyone have more info on this?
pros and cons?
cost?
any one running one?
  • Moderator
Re: hydraulic clutch cb750?
« Reply #1 on: November 12, 2010, 05:51:54 AM »
CycleX do one Jag, I'll find a link for you.
Sam. ;)
  • Moderator
« Reply #2 on: November 12, 2010, 05:55:37 AM »
Seems It's still in the development stage.
http://www.cyclexchange.net/index%20pics/Hydraulic%20Clutch%203.JPG
Sam. ;)
« Last Edit: November 12, 2010, 06:25:31 AM by SamCB750A »
« Reply #3 on: November 12, 2010, 07:19:41 AM »
 Fishead on here has built some clean-looking ones that use the tincover..
Offline Ricky_Racer
« Reply #4 on: November 12, 2010, 09:01:18 AM »
Jag, do you have a link for the small Magura(?) slave cylinder that will fit underneath the stock clutch cover? I've been unsuccessful in my search. Thanks!  RR
Offline NitroHunter
  • Radical Street / Strip Turbo
  • A man's motorcycle is a reflection of the man
« Reply #5 on: November 12, 2010, 05:11:45 PM »
In the mid 80's I built a hydraulic clutch for my SOHC 750.
  Here's my "Hydra-Slide" dragster clutch story.   ::)
  I machined a clutch cover to accept a hydraulic slave cylinder, as I remember it and the master cylinder were from an Interceptor (?). It stuck out of the side a little but looked pretty cool. The purpose was a simple drag start launch management system for a turbo bike, similar in concept to a fuel cars 'cannon' - Hydraulic controlling of throw out bearing movement. A flow control (needle / check) valve for engagement speed adjustment. Made a centrifugal flyweight clutch lock-up plate. 12v solenoid line lock activated by a microswitch at the throttle linkage. It actually was a rather simple setup - once all the machining was done. 2 semesters of Machine shop 'Independent study' at the local community college got it finished.
  Application at the track was another story.
  Barbecued not just 1 but 2 used clutch packs strait away. Tried adding counterweight but then lots of bogs. Pumped the turbo hard to make some boost, then got too much tire spin and crashed. So I quit and went Funnycar racing.
 I still have that cover, adaptor, and lock-up, but no idea where the rest of that POS set up went to.
Robbie the NitroHunter                      Fuel Coupe Hired Gun                  NHRA T/F 640
DRAGBIKE USA XH/MB Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=127179.0;attach=332735
DRAGBIKE USA XH/SS Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=63940.0;attach=103300
Young mans glory days in the lanes: http://forums.sohc4.net/index.php?action=dlattach;topic=45685.0;attach=66341
Offline jaguar
« Reply #6 on: November 12, 2010, 06:18:34 PM »
http://www.fishheadbigbrakes.com/services.html
thats really the best pics that i can find.
info is scarce too
RR we seem to be playing Email/phone tag.....you around this weekend?
Offline fishhead
  • Why don't you go.....Well, you know the rest.....
« Reply #7 on: November 15, 2010, 06:48:48 AM »
  I've been getting a lot of emails on this.
I stopped making the hyd clutches because I ran out of the Magura units I was using and I haven't been able to find others, they have probably been discontinued. I originally had a box of them and when they ran out, I couldn't find others to continue offering the kits with. I found out that they were hard to find when I sold a XS650 Hyd clutch kit and had to remove the Magura unit of my CB750 to make the kit with. My CB 750 will get a larger slave cylinder that will stick through the "tin" cover.
  Magura has gone to the "Jack" units that basically replace the clutch cable (It looks like it would keep the stock adjuster, ball ramp,etc) and only replace the cable with a hyd unit. It seems like this approach would be easier and would require less fabrication/machining. The main differences between the different application "Jack" units would be the length of the "clutch cable" end and the length of the stroke. I don't know what application would be best for the hyd clutch assembly for the CB 750.
 Here's a "Jack" unit.
http://cgi.ebay.com/ebaymotors/MAGURA-HYDRAULIC-CLUTCH-KIT-DR-D-HOT-START-KITS-0120494-/220692093662?pt=Motorcycles_Parts_Accessories&hash=item3362461ade
Magura also uses mineral oil in their systems, often called Magura Blood. It is not compatible with any brake fluid and if you put brake fluid in the Magura stuff (labeled "Mineral Oil only"), it will destroy the seals and in turn destroy the Magura unit.
Quote from:  Vanna White
Photobucket slide show (Fishhead Big Brakes)
http://s111.photobucket.com/albums/n130/dgfischer/Fishhead%20Big%20BRakes/?albumview=slideshow
« Reply #8 on: November 15, 2010, 08:08:47 AM »
  Interesting..
 If you can get the seals for the other hyd unit we could build the unit again.. or use a more common kit, and build the rest..
Offline Ricky_Racer
« Reply #9 on: November 15, 2010, 08:50:33 AM »
Thanks for the info, Dan. The slave cylinder you were using looked closest to a KTM application, but as you found, it seems to no longer be available. And the price of somewhat similar used KTM clutch cylinders is pretty high. Looks like the external mount (R1, Interceptor, Ducati, Yoyodyne, etc.) may be the most feasible/low-buck way to go.
Sure do like the hidden ones though....   :-\   RR
a700guy
« Reply #10 on: November 15, 2010, 12:11:08 PM »
Ktm has all but stopped using magura and gone to a brembo unit, better feel and uses brake fluid.....something to look into, look into a 250SX clutch unit and you should find it straight away.
Offline jaguar
« Reply #11 on: November 15, 2010, 12:44:54 PM »
Is that a low profile set up?
Offline Ricky_Racer
« Reply #12 on: November 16, 2010, 03:54:21 PM »
Kinda, sorta... but I don't know if it has a bleed valve or not. There are a couple similar Magura types that do.  ::)  RR
Offline BLUE71TURBO
« Reply #13 on: November 16, 2010, 04:27:01 PM »
Here's an aftermarket setup for a early kz1000.  Just to give ya an idea in what it looks like.  Hope it helps.   ;D
     http://cgi.ebay.com/ebaymotors/Kawasaki-Z1-KZ900-KZ1000-Hydraulic-Clutch-Kit-/380134748525?pt=Motorcycles_Parts_Accessories&hash=item5881cbf16d
Offline DavePhipps
  • Reading the entire Hi-Perf forum
    • Hillside Technology
« Reply #14 on: November 16, 2010, 04:52:05 PM »
PLease don't whack me over the head with something when I ask this. Why do this modification? There doesn't seem to much benefit from it.
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline Ricky_Racer
« Reply #15 on: November 16, 2010, 04:53:52 PM »
Because we can;D  RR
Offline DavePhipps
« Reply #16 on: November 16, 2010, 05:09:27 PM »
Because we can;D  RR
That's a fine reason to do it, that I can totally agree with. Mods can be fun!
However, I'm still wondering if there is a benefit that I'm not aware of?
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
« Reply #17 on: November 16, 2010, 06:07:13 PM »
One reason is that some of these big engines can use heavy clutch springs and the rider doesn't have to worry about carpal tunnel. ;)
« Last Edit: November 16, 2010, 06:10:15 PM by bwaller »
« Reply #18 on: November 16, 2010, 06:29:54 PM »
I have a Barnett clutch in mine and the extra lever pressure is the reason why i wanted to try this, everyone i have spoken too is trying to talk me out of doing it. I have an early gsxr 750 hydraulic set up and was going to look at converting that....
Offline DavePhipps
« Reply #19 on: November 16, 2010, 08:34:48 PM »
Now that's a justification,, even though bwaller's response seemed a bit tounge in cheek.
From a personal experience the hydralic clutch on my old interceptor always felt vague, not enough feedback for my tastes.
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
« Reply #20 on: November 16, 2010, 08:36:34 PM »
The one on my GSXR1100 was good, light and easy to use....
Offline BLUE71TURBO
« Reply #21 on: November 16, 2010, 10:54:54 PM »
                  What reason would these people try to talk you out of this conversion ?  If ya wan't to try something new and different
        I say go for it.  You might even make some $$$ out of your idea and labor.   ;D
« Reply #22 on: November 17, 2010, 03:52:23 AM »
I have been told that it isn't as reliable and lacks feel but my experiences tell me different......I'll look into it....
Offline turboguzzi
« Reply #23 on: November 17, 2010, 04:33:32 AM »
got hydraulics both on my VFR and my GSXR, first one works almost as good as a cable, the later quite abrupt. Never having to lube a cable or having it breaking on you in the middle of nowhere are a plus
So getting better leverage is good in theory, in practice i doubt if you'll find a good range of MC's and slaves cyls to get the right ratio/feel.
In the other hand, the slave arm length and hence ratio on a cable setup can be easily changed, see here
TG
Offline MidnightLamp
  • Wrenchy wrenchy wrench!
« Reply #24 on: November 17, 2010, 07:52:32 AM »
I've seen it done on brit bikes where you run into the 'Why do I only have 1/64 inch of clutch travel for 1 inch of cable pull?!?' problem. A local guy used to run a VFR750 clutch cylinder on a unit BSA. It directly pushed on the clutch, and he was using a series of shims and spacers to get the throw just right. He seemed somewhat satisfied with it, but then switched to a powerstands setup and was very happy.
http://www.powerstands.com/acb/showdetl.cfm?&DID=43&Product_ID=198&CATID=17
'75 CB750 - Racer
'69 CB350 - Racer
'68 Enfield 350/440(flat top) - Steet
'54 Enfield 350 - Resto
'74 Commando 850 - Restomod
'67 Enfield 750 (TT7) - Resto
