Author Topic: hydraulic clutch cb750?  (Read 17160 times)
Re: hydraulic clutch cb750?
« Reply #25 on: November 17, 2010, 08:09:12 AM »
Here is some plusses;
 More consistent feel, ie no cable lubing, stretching/wear, freezing issues.
 Smoother  actuation.
 Matched levers on handlebars for better looks.
,Braided lines as well.
Offline jaguar
« Reply #26 on: November 27, 2010, 05:22:35 PM »
http://cgi.ebay.com/ebaymotors/02-Honda-VTX1800C-VTX1800-1800-clutch-slave-cylinder-/200545555495?pt=Motorcycles_Parts_Accessories&hash=item2eb1725427#ht_1987wt_945
think this would be low profile enough?
is there a ratio type thing to think about when piecing this together?  much like the ratio for calipers and masters when talking about brakes.
i really would want to do this if it could be hidden under the "tin" cover
also anyone know a master that would look right with the F3 brake master that im using?  i would want something with a similar look
Offline jaguar
« Reply #27 on: November 30, 2010, 05:08:23 PM »
Ok so i bought a master that will match my CBR F2/3 brake master and a slave.
the set up is a cbr1000f (same as ST1100) master and slave from cbr1000 or V30.
i crossed the OEM part numbers on bikebandit and got some good deals on Ebay.
2002 ST1100 master $29 shipped
1984 V30 slave $16 shipped.
i have NO idea if the slave will fit under the "tin" cover but it looks very low profile.
anyone have any good impute?
how about a source for a adjustable rod to use between the slave and clutch?  something from McMasters?
thanks for any help
Offline turboguzzi
« Reply #28 on: December 01, 2010, 02:46:56 PM »
stupid question from a non CB750 owner....
750 have a mechanical PULL ,mechanism in the clutch cover
Most if not all hydraulic clutches actuators activate the clutch via a PUSHrod thorugh the primary shaft.
(leaving aside dirt bike with a cyl pulling on the mechanism lever)
How do you guys plan to use a PUSH cylinder to PULL the clutch?
just wondering...
TG
« Last Edit: December 01, 2010, 02:49:31 PM by turboguzzi »
Offline Bill/BentON Racing
    • BentON Racing
« Reply #29 on: December 01, 2010, 06:35:21 PM »
 ;D TG,I sure don't know but when you pull stock you are really pushing....they just going to eliminate the pull part. ;)
I prefer cables myself.Bill....add an actuator rod to slave cylinder?
BentON Racing Website
BentON Racing Facebook
