Author Topic: fmctm1sw 75 CB550K  (Read 23532 times)
Offline fmctm1sw
Re: 75 CB550K: Clean and assemble stage...
« Reply #25 on: November 30, 2010, 07:32:52 PM »
Cleaned up the axles a bit.  I've never had a bike that I would be able to assemble and stay clean in the process.  Got to work on the rear rim and forks and I should be able to get it on wheels (until I get new tires)..
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Zaipai
    • My Home page
« Reply #26 on: November 30, 2010, 08:21:30 PM »
Really the best way is to do one thing at a time and clean up after each thing, including your hand's tools and workbench. Seems like a pain however it does really keep the rebuild clean. After that you will be happy you did it..
Hang in there..
.: Scott :.
Its my Avatar..
75 CB550F  |
« Reply #27 on: December 01, 2010, 08:07:22 PM »
nice, clean, job! Pun intended!!
Offline fmctm1sw
« Reply #28 on: December 05, 2010, 07:44:38 AM »
Rear rim work.  And found out my bearings are shot...  I hit the spokes with a brass brush.  It didn't seem they were as much rusty as they were coated in crud.  They may rust now but they look nice at the moment!  The spocket and cover were coated black too just like the hub.
*edit* oh and is that area behind the spocket supposed to be greased?  I'm guessing no...
« Last Edit: December 05, 2010, 07:49:38 AM by fmctm1sw »
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Goofaroo
  • general nuisance
« Reply #29 on: December 05, 2010, 08:48:36 AM »
It's looking great!  I'm doing a similar project right now in which I'm thoroughly disassembling everything for a cleaning but leaving some patina.
If you are interested I've got a tip that you may want to try on the spokes. Take an old t-shirt or some similar material and cut it into strips about an inch wide and a foot long. Then take some Barkeeper's Friend (available at Lowes or the grocery store) and mix up a paste that you can dip the strips into. Once you have the strip saturated with the paste you can lay the wheel down and start on one side looping the strip under each spoke and pulling it back and forth as you work up and down the spokes. Keep the strip saturated and as they wear out just grab another one. It takes a little time but you'll be very pleased with the results. You'll also figure out all kinds of other uses for the Bartender's Friend.
Watching your thread closely and anxious to see how it turns out.
Cheers!
« Last Edit: December 05, 2010, 08:52:32 AM by Goofaroo »
1972 CB500 four
1972 CT90
1974 CT90
1978 BMW R100S
1983 CX500
1986 GL1200 Aspencade
1986 CH150 Elite Deluxe
1984 NH125 Aero
2005 Genuine Stella 2T
2007 KLR650
2002 KLR250
1985 XR350R plated
1994 DR350SE
2004 Concours ZG1000
1987 KDX200 C
1992 KDX200 E
2010 BMW F800GS
Always room for one more.
Offline fmctm1sw
« Reply #30 on: December 07, 2010, 05:06:37 PM »
My paint job sucks...  Scratches and chips with ease..   >:(  Definitely lessons learned for next time.  I'm mocking up the bike mainly to see what hardware I'm missing.  Shouldn't be anything major, a few bolts here and there.  Still need a speedo though and new tires though.
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
« Reply #31 on: December 07, 2010, 06:34:46 PM »
Have you considered painting your frame with clear?
Offline Zaipai
    • My Home page
« Reply #32 on: December 07, 2010, 06:54:21 PM »
Looking good from the pictures. The new rubber is a wallet killer for sure but one of those things you really don't want to go cheap on. Really good work on that rear rim.. Looks much much better!
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline fmctm1sw
« Reply #33 on: December 18, 2010, 07:16:38 PM »
Moved along today.  I mocked up the engine mount hardware like I've been doing for the other nuts and bolts.  Turns out I'm missing the lower bolt for the front pair of motor mounts.  Come to think of it, this bike had a engine guard on it when I disassembled it.  No biggie.
The brake lever was an adventure.  After much thought on how the spring went back on, I looked at my 350Fs  ::)  I then spent a good 45 minutes mocking up a foot peg and mounting the rear wheel to make certain the lever mechanism didn't come too far forward and hit the swingarm.  I never noticed anyone talking about this and I wondered why considering it was a pretty exacting evolution.  I got it mocked up and before I took it back off, I scribed a mark in it so I would know the proper position of the brake lever to the shaft.  That's when I noticed it...  Two little dimples that you simply lined up, one on the shaft and one on the lever  ???  My calculation was right on though!
I got the wire harness, battery box, and electronics box, air box back on and cleaned up the front fender.  Oh, and found a brake caliper mount in a big box of brake parts I have.  Maybe tomorrow I'll hook the motor up to my HF leakdown tester.  I know the engine isn't frozen but outside that it's anyone's guess...
*edit*  And I had the fork tubes on backwards....  Took me 15 minutes to figure out why my fender was weird...
« Last Edit: December 18, 2010, 07:19:06 PM by fmctm1sw »
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline fmctm1sw
« Reply #34 on: December 18, 2010, 07:31:27 PM »
One more photo but blurry.  Air box in and not much left to do with the chassis.  I have some work to do on the handlebars though.  I need to install one switch and the other has the turn signal switch frozen..
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Zaipai
    • My Home page
« Reply #35 on: December 18, 2010, 08:50:54 PM »
Good idea to test fit the bolts, wish I had done that. It was not until after I had the motor in that I could not find two bolts and one nut and ended up at the hardware store just before closing trying to match up what I needed.
Looking good..
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline Jordan
  • What a Long strange trip it's been
« Reply #36 on: December 19, 2010, 06:20:29 AM »
Looking good, but the photo of the foot brake area just doesn't look right to me, probably just a matter of final adjustments but the engine/foot peg nut/bolt seems to contact the brake arm and the adjusting nut and bolt has no threads left to move it away. I haven't looked at mine lately I'm just making an observation of the photo.
Offline fmctm1sw
« Reply #37 on: December 19, 2010, 07:55:04 AM »
I found that a little odd as well.  I'm pretty sure I have it all lined up correctly though.  I'll look at my 350Fs and see what they look like...
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline fmctm1sw
Re: 75 CB550K: motor work
« Reply #38 on: January 04, 2011, 05:40:25 PM »
Got into the motor tonight that was seized.  It looks like the only thing wrong was the pistons froze.  The crank was free but I had to cut the cam chain to get it apart.  I actually have another engine from an F bike that I was going to use but I think I can salvage this one.   I snapped a few pictures so I would know how to get it back together.  I also noticed the gears are unlike any I've seen in my 350F/400F motors I've torn down.  I don't remember the dogs having that shape...
*edit* and since I can no longer avoid removing the rotor since I need a new seal set, I need one of those pullers...   :(
« Last Edit: January 04, 2011, 05:46:16 PM by fmctm1sw »
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline fmctm1sw
« Reply #39 on: January 04, 2011, 05:41:26 PM »
dogs...  and a lot of that red gunk is from the acetone/transmission fluid mix I soaked it with...
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Zaipai
    • My Home page
« Reply #40 on: January 04, 2011, 06:12:49 PM »
Well your almost over the hard part. Take your time and keep taking pictures for ref..
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline fmctm1sw
« Reply #41 on: January 15, 2011, 07:39:39 PM »
Continuing to chip away.  Used the $$$ I got for Christmas to get some odds and ends.  I got the shaft out that I had mentioned in another thread by using a rotor I had laying around and an engine mount bolt.  Worked great.  Now to clean and blast the cases...
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Zaipai
    • My Home page
« Reply #42 on: January 15, 2011, 08:35:49 PM »
Any progress is good progress!!! Keep forging ahead.
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline fmctm1sw
« Reply #43 on: January 17, 2011, 06:23:52 PM »
Cleaning up the motor.  I never realized how fast you can burn through a can of brake cleaner or starting fluid when you are cleaning these up...
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline fmctm1sw
« Reply #44 on: January 17, 2011, 06:24:50 PM »
And I got my rotor off the crankshaft.  Local hardware guy had the right size bolt so I saved on the flywheel puller...
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline fmctm1sw
« Reply #45 on: January 18, 2011, 06:29:33 PM »
More photos.  First time it's ever seen the light of day.  Of all the things to lose, I can't find the bolts that hold the gauges to the bracket and the left mirror mount is stripped (no mention of that in the auction  :-\)  I plan on blasting the cases tomorrow and my engine paint is on the way as well as the oil seals for the bottom end.  I plan on putting it into the frame with the top end off so I don't get everything scratched up...
edit:   oh crap, I need to do the brakes too...
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline fmctm1sw
« Reply #46 on: January 24, 2011, 09:18:58 AM »
Back to some painting.  I blasted some brake and engine parts.  One lesson learned was to make sure everything is 100% degreased.  I used POR-15's aluminum engine enamel.  I used a brush but I got brush strokes in it.  Wouldn't look bad from 15-20 feet but I'm going to sand it and try to do a better job by spraying it.  Seals and stuff supposed to arrive today...
« Last Edit: January 24, 2011, 06:35:26 PM by fmctm1sw »
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Zaipai
    • My Home page
« Reply #47 on: January 24, 2011, 05:56:37 PM »
It does not look bad, however I see what you mean. I am sure the next round will yield better results..
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline fmctm1sw
« Reply #48 on: January 24, 2011, 06:34:33 PM »
.: Scott :.
Scott, thanks for following.  I'm definitely happy with the brake caliper I (almost) finished and I sanded and sprayed the oil pan and filter housing.  It doesn't say much, but it's probably my best painting yet.  I plan on giving the engine a good once over for sand tomorrow again and hopefully painting it...
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Zaipai
    • My Home page
« Reply #49 on: January 24, 2011, 07:02:15 PM »
Yes, that is much better, you have to be happy with that. You are probably better at it then I am.. I have only ever done rattle can paint jobs.. However for Christmas I did get an air compressor, not a big one but it should be good enough for small paint jobs.. At least I hope so.
TTYS,
.: Scott:.
Its my Avatar..
75 CB550F  |
