Author Topic: Later float valve on CB750K0  (Read 596 times)
Offline AshimotoK0
  • CB400/4, 69 CB750K0, '69 CB250SS, CB350K1 CB500K0
« on: November 13, 2010, 04:48:00 am »
I have just tried a K7 float valve 'needle' - (the one with the conical rubber/polymer  tip)  in my k0 carbs and it seems to seal OK I am currently rebuilding (re-plating all of the steel parts BZP at the mo). Will this work OK - seems to me it would seal better than the all metal ones.
Cheers
Ash
“Alright friends, you have seen the heavy groups, now you will see morning maniac music. Believe me, yeah. It’s a new dawn.”
Offline Bodi
Re: Later float valve on CB750K0
« Reply #1 on: November 13, 2010, 06:56:06 am »
If they fit right there is no problem. Naturally you have to adjust the float levels.
Offline AshimotoK0
« Reply #2 on: November 13, 2010, 08:22:19 am »
Brilliant - think I will use them instead to avoid the dreaded leaks which can ruin your engine paint finish
Cheers
ash
Offline metalmechanix3
« Reply #3 on: November 13, 2010, 09:49:26 am »
One trick to help seat seal is to use valve laping compoud on q-tip to polish seat, just make shure to remove all residue of compound. Rubber tip float valve should work fine.
Offline Bodi
« Reply #4 on: November 13, 2010, 04:18:56 pm »
I generally lap with brasso or solvall. This does not work with rubber tips but I've revived dribbly brass tip float valves many times by lapping the needle to the orifice.
