Author Topic: 78 Carb Question ??  (Read 1082 times)
Offline tmac
78 Carb Question ??
« on: November 14, 2010, 03:41:35 PM »
Guys , My bike is all back together and running great but there is a vacuum tube or maybe a vent tube from my carbs that I really cannot find a place where it goes so there is a screw in it for now. MRieck told me to ask U guys your thoughts on the possibility of maybe a P.O. either changing the original petcock or if these carbs even belong on this bike. The reason for my question is I am having a cold start problem. Please advise & Thank You very much !!! Tim
bollingball
Re: 78 Carb Question ??
« Reply #1 on: November 14, 2010, 03:51:37 PM »
That small tube is a vent tube it should be open and you can strap it above the top of the carbs. If they pd42b's with the keyhole top cover. Is this a (K) model?
Offline Nikkisixx
« Reply #2 on: November 14, 2010, 09:23:26 PM »
Yup, probably the vent tube. Route a line like ^ said.
For the cold start problem - did you adjust the fast idle on the choke?  Also: I have found that pumping the throttle a couple of times before hitting  the starter to squirt a little extra fuel helps stoke the fires as well.
Offline tmac
« Reply #3 on: November 15, 2010, 12:09:59 AM »
Yes its a K8 & thank u
Offline cookindaddy
  • I sure love this bike!
« Reply #4 on: November 15, 2010, 02:25:45 AM »
My K8 PD carb vent tube has a small screen filter plugged into it, to prevent particles from getting drawn down the tube? I think that is original (the way they came from Honda).
George with a black 78 CB750K (in Lion's Head, Ontario, Canada)
Offline tmac
« Reply #5 on: November 15, 2010, 04:33:01 PM »
Thanks Guys!!
Offline mick750F
« Reply #6 on: November 15, 2010, 05:48:36 PM »
   Originally there is no screen in the carb vent tube. It would have to be a pretty small screen...The factory set-up had the vent tube attached to the top of the air cleaner by a clamp/bracket and hanging down behind it.
Mike
Glosta, MA
Offline tmac
« Reply #7 on: November 16, 2010, 07:12:42 PM »
Thats how I put it back, Thank you very much!!
« Reply #8 on: November 17, 2010, 07:33:13 AM »
For cold start problems check that your choke is closing completely. There is fast idle cam, but that only comes into play after the motor starts.
Offline Nikkisixx
« Reply #9 on: November 17, 2010, 08:47:41 AM »
Hey BobbyR: After a rebuild I had hard starting problems with the fast idle set too high -4500 RPMs  :o  - and I propose that with the slides open too far it changes the fuel/air mix too much and causes hard starts.  What do you think?
