Author Topic: Help deciding...  (Read 2050 times)
the_cruz
Help deciding...
« on: November 16, 2010, 09:34:20 PM »
Hey guys... I am currently looking to buy my first bike ever.  I have never ridden before so this will be a whole new experience for me.  Since this is my first bike I am not looking to go all out and spend many thousands of dollars on it.  Looking on craigslist and such I have found several reasonably priced bikes and I'm torn between an 1981 CB750 and a 1992 Nighthawk 750.  I really like the vintage look of the '81 and it is $1000 with "17,000 MILES, NEW TIRES, CHAIN, SPROCKET, BATTERY".  The Nighthawk on the other hand is $2000 and a very good looking bike and looks like a nice mix of a cruiser and sport bike.
So my questions:
Which would make a better beginner's bike?
Are parts more available for one over the other?
Does one have a better track record in regards to reliability?
Any other bits of advice are appreciated.  Thanks.
-Daniel
Offline Gordon
  • 750K1, 550K2
Re: Help deciding...
« Reply #1 on: November 16, 2010, 09:38:23 PM »
Neither is a SOHC4.
the_cruz
« Reply #2 on: November 16, 2010, 09:39:25 PM »
Oh... I'm sorry. Didn't realize.  Are they DOHC?
Offline Gordon
  • 750K1, 550K2
« Reply #3 on: November 16, 2010, 09:41:23 PM »
Yep.
Not to worry, though.  We have an active "Other Bikes" section where this post will be moved to.
the_cruz
« Reply #4 on: November 16, 2010, 09:42:14 PM »
Thanks.  How embarrassing.  First post and I already messed up. ;)
I will look for it over there...
« Reply #5 on: November 17, 2010, 06:11:57 AM »
Thanks Ok, there still Hondas and good bikes.
When it comes to buying an older bike, I suggest getting one that appears that has been maintained and taken care of
[as opposed to just parked against a tree in the back yard].
Go look at both, and talk to the owners, that will give you a better idea. And will will start learning about bikes.
Of course, most guys here will tell you to keep looking for a SOHC!
One more thing, unless you are a big guy [6', 220+], I'd suggest starting with a smaller bike than a 750, maybe a 400 or 550.
Good Luck.
Offline Alan F.
« Reply #6 on: November 17, 2010, 06:19:40 AM »
I've got a 92 750 nighthawk, for your first bike it'll do fine.  With a stock exhaust and stock carburetor jets it won't be too much to handle if you're careful.  There aren't many adjustments to be made on one of these bikes, cam chain tensioner is hydraulic and automatically adjusts itself once the bike is warmed up and running, electronic ignition system has no adjustments, you'll have to learn to maintain a drive chain but thats no biggie, Tire pressure, change oil and filter and spark plugs and air filter now and then too just like any other bike, other than that it's an apliance. You can put hundreds of miles on one every day without much worry. Mine has 45K miles on it and as long as it has enough oil in it, it's happy. (previous owner was unkind I think) I'm still on the original clutch at 45K. Get one with a center stand if you can. 2 grand seems a little steep though for a 92 since they made them until 2003 and there are plenty of younger bikes available. I've seen a few 200-2003's in Boston craigslist with rediculously low mileage going for $1600 or so. 2 grand for a low mileage, gently ridden, cream-puff isn't totally out of the question though if it's got newish tires/chain etc.
I wouldn't call it a cruiser or a sportbike though, it won't handle like a sportbike or be as comfortable as a cruiser. It's a very capable all around bike though and depending on the style of riding you want to do it can be outfitted for touring, can be modified for light adventure riding, or can be made more sporty to some extent....  Sort of along the same lines as a sohc 750 can be.
Parts availability is not even a concern yet, these bikes also had a long production run and all parts are still available new from honda. The 81 had some unique parts and that style of bike was only from 79-82
the_cruz
« Reply #7 on: November 17, 2010, 06:03:08 PM »
Thanks for the replies.  Well the '81 CB750 is out... Got a look at it today... It is too much of a project for me at this point.  As far as bike size goes, I'm 5'8" 220lbs... I am considering going with something a bit smaller than a 750... .Those just seem to be the most available and I think it is a bike that I would be happy with for many, many years... I'm definitely looking to go with easier to handle vs power.  Good part is I have a very easy commute to work and live in a very bike friendly town... So I should be able to log a lot of time getting in low traffic areas...
Offline BeSeeingYou
« Reply #8 on: November 17, 2010, 06:25:07 PM »
I am not really a fan of "buying a smaller bike to learn on".  Then you have to sell it and buy a bigger one when you outgrow it.  Get whatever size you want to end up with.  If you can ride a 450/550 you can ride a 750.  It's only intimidating the first few times and then you get used to it.  That was my experience anyhow when I bought an XS650 having never ridden a bike before and drove it home from the dealer. :D
the_cruz
« Reply #9 on: November 17, 2010, 06:34:07 PM »
This is my current thinking but I'm trying to stay open-minded about things and listen to people with experience.  My brother bought an 1100cc, I think, as his first bike and he is a much smaller guy than I am.
Offline Alan F.
« Reply #10 on: November 18, 2010, 05:19:20 PM »
There's always the 83-85 650 nighthawk, shaft drive and all the same plusses as the 91-03 750's
Power was just a little less, and the bike was a little smaller too.
