Author Topic: Running light issue on '76 550k  (Read 845 times)
Offline Nortstudio
  • Not nearly an
  • Just getting started...
    • MotoPreserve
« on: November 18, 2010, 07:33:33 AM »
I had to disassemble my bucket wiring to put on drag bars, and after reassembly, everything is working a-ok except the runnig lights on the rear turn signals.
The flasher function on those same lights works fine. And the running light/flashers work fine on the front lights as well.
I opened it back up and checked it, and everything seems plugged into the right connections based on my notes.
Any thoughts?
1976 CB550K...in progress
1975 CL360...eventually custom
2009 Husqvarna TE610
a blog about wrenching in Brooklyn, NY
“Success is dependent on effort.”
~Sophocles
Offline Gordon
  • 750K1, 550K2
Re: Running light issue on '76 550k
« Reply #1 on: November 18, 2010, 08:33:54 AM »
The only running light on the rear is the tail light.
« Reply #2 on: November 18, 2010, 09:01:41 AM »
It dont got nor is supposed to have rear running lights (except the red one in the rear light)
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #3 on: November 18, 2010, 11:17:22 AM »
Thanks guys. I could have sworn that the rear were lit up always, but I could be wrong. Little strange that the front flashers would be always on and not the rear???  Is this normal with your bikes?
~Sophocles
Offline Gordon
  • 750K1, 550K2
« Reply #4 on: November 18, 2010, 11:35:44 AM »
This is normal for all vehicles in the U.S. and probably most other countries.  Running lights on the front are yellow and red on the rear.  If yours were previously wired to be running lights then it was done by a PO and the bulbs were changed from the stock single element to dual element.
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #5 on: November 18, 2010, 11:53:53 AM »
Thanks for the clarification.
Appreciate the help.
~Sophocles
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #6 on: November 18, 2010, 01:35:27 PM »
I'm enjoying your posts nortstudio I went through the same exact things just a couple of months ago that you're going through now.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #7 on: November 18, 2010, 01:38:59 PM »
If I recall correctly, you and I are lined up on a bunch of stuff.  My next big thing is to deal withe the timing.  Ran out of room.  Need to try the TT method of gaining some adjustment back by shimming the plate near the three screw posts...
~Sophocles
